Re: Got my SB E heads back from Ryan @ Shady Dell [Re: 69Cuda340S] #916033
01/30/11 03:45 PM
01/30/11 03:45 PM
Weddington, N.C.
Streetwize Offline OP
Weddington, N.C.
69Cuda340S
What cam and compression do you run?
WIZE
In Car:
Re: Got my SB E heads back from Ryan @ Shady Dell [Re: 69Cuda340S] #916034
01/30/11 03:47 PM
01/30/11 03:47 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I run Stage 2 ported e-heads by Shady Dell on my 414 and it pulls hard. The valve job was an absolute work of art.
How does it handle those BFG Radial TAs in your signature pic? Love that car BTW, enjoyed your build up when you did the motor.
68 Barracuda Formula S 340
Re: Got my SB E heads back from Ryan @ Shady Dell [Re: Bad340fish] #916035
01/31/11 11:25 AM
01/31/11 11:25 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
time to invest in wheelie bars...
2017 Grand Cherokee Overland
Re: Got my SB E heads back from Ryan @ Shady Dell [Re: patrick] #916036
01/31/11 07:41 PM
01/31/11 07:41 PM
Weddington, N.C.
Weddington, N.C.
Yeah, I get that a lot!!
WIZE
In Car:
Re: Got my SB E heads back from Ryan @ Shady Dell [Re: Streetwize] #916037
01/31/11 08:35 PM
01/31/11 08:35 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
I think that cam should work well for you. Might want less gear,unless you'll be only running 1/8 mile. Easy low/mid 10's. Have fun and report back some track numbers.
Re: Got my SB E heads back from Ryan @ Shady Dell [Re: goldmember] #916038
02/01/11 12:39 PM
02/01/11 12:39 PM
Weddington, N.C.
Weddington, N.C.
Yeah the 4.56 Gearing is something I struggled with, the 295/65 m/t's are around 30", I guess it's gonna depend on the converter slip as to whether I can pull the stripe on the big end of the 1/4 without encountering "free range" connecting rods
it'll no doubt be a blast in the 1/8th....the Rocky is only 12' long and with very little overhang, it'll be tough to do a 'Scotty Richardson' type 'Just enough to beatcha' win against.
WIZE
In Car:
Re: Got my SB E heads back from Ryan @ Shady Dell [Re: Streetwize] #916039
02/01/11 07:06 PM
02/01/11 07:06 PM
How hard was it to fit the smallblock in there? Any firewall butchery?
Re: Got my SB E heads back from Ryan @ Shady Dell #916040
02/01/11 08:26 PM
02/01/11 08:26 PM
Weddington, N.C.
Weddington, N.C.
More room than an A-body....torsion bars are nearly identical distance center to center....motor fits in like it grew there.
The trick is to cut out all the AWD crossmember out and re-weld your tube steel reinforcements to tie it back together.
When Lenny had in over to his shop I had him weld in some 2" round tube to stiffen and tie the Lower control arm supports together....might help on the Wheelie rebounds.
WIZE
In Car:
Re: Got my SB E heads back from Ryan @ Shady Dell [Re: Bad340fish] #916041
02/02/11 12:34 AM
02/02/11 12:34 AM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
The BFG Radials don't do so well at anything below 30 mph -). But I would have to beef up chassis and drive train if I went with better tires and thats not in the budget right now. Its just a toy anyway not a race car. Not very practical but it sure is fun.
Cam is 586/540 lift, 236/242 @ 50 duration intake/exhaust with 108 LSA custom ground retrofit hydraulic roller by Indio Motor Machines in CA (user ou812 on this forum). Pretty radical idle but throttle response is instant, icredible torque, and pulls hard up top.
Engines been in for two years now and been run very hard. Does not leak or use any oil and still sounds nice and tight. So far so good.
Re: Got my SB E heads back from Ryan @ Shady Dell [Re: RyanJ] #916042
02/02/11 08:43 AM
02/02/11 08:43 AM
WASHINGTON, PA
11secaarcuda Offline
WASHINGTON, PA
Intake #'s are very nice.
Exhaust are stellar.
I think with that cam , those cubes and that weight , you could forget to shift your way to low 13's.
Should be a blast.
Agreed that the exhaust numbers are very impressive.
Ryan, do you sell these heads done, or does the customer first buy the heads from a dealer and then send them to you?
I did'nt think they were anything special. Actually the .400-.500 exhaust #'s are off a hair, & the .300-.500 intake #'s are a little off as well. The low & high lift #'s look normal for that level of prep.
I don't flow heads very often anymore...especially a head like this that I've done 100 sets of, not alot of point. I worry more about what power they make. I did a 416 last year with heads in exact same state as these, Stage 2, same valve job, same chamber prep, same stock Edelbrock valves..... 12:1, Super victor, 750 Demon, 269 @ .050 roller & 1 5/8" TTI step header, so far 10.40 @ 128 @ 3100 lbs. Going to bigger header this year, should pick up maybe .1 or so & some changes in rear suspension should help 60' as well. It's good bang for the buck $525 port job on set of "factory replacement" designed heads.... & runs low 10's.
67 Dart GT 340 4 speed
70 AAR Cuda 408 6 barrel
96 Indy Ram original owner
2011 Hemi Durango
Re: Got my SB E heads back from Ryan @ Shady Dell [Re: Streetwize] #916043
02/02/11 03:08 PM
02/02/11 03:08 PM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
That thing's got to be a handful, no?
Re: Got my SB E heads back from Ryan @ Shady Dell [Re: POS Dakota] #916044
02/02/11 03:31 PM
02/02/11 03:31 PM
Weddington, N.C.
Weddington, N.C.
I hope not, I've got a fairly mild converter (3600 stall Loose 10" T/A ) that should let me walk it out pretty quick without standing it on the bumper
If I gave it a 4500 Stall 8 incher I know it would ET quicker, but it'd be a wild willie (guardrail to gaurdrail) type ride.
We'll see how it goes, I plan to do a good bit of T&T with it before I put it on one of these narrow little N.C. 1/8th milers.
WIZE
In Car:
Re: Got my SB E heads back from Ryan @ Shady Dell [Re: 11secaarcuda] #916045
02/02/11 09:00 PM
02/02/11 09:00 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
I bought my heads from him done. He doesn't mark the cost of the heads up so no reason not to go that route if you don't already have the heads.
Re: Got my SB E heads back from Ryan @ Shady Dell [Re: 69Cuda340S] #916046
02/03/11 02:21 PM
02/03/11 02:21 PM
WASHINGTON, PA
WASHINGTON, PA
How much? You or Ryan can PM me if you like.
2011 Hemi Durango
Re: Got my SB E heads back from Ryan @ Shady Dell [Re: Streetwize] #916047
02/03/11 02:39 PM
02/03/11 02:39 PM
an8sec70cuda Offline
Wonder if they'll let a mopar powered Daihatsu into Mopars at the Rock?? seems like I saw a 340 powered TR7 there one year...but it might have just been a bracket race
I'm sure they will let it in. So NOW you're gonna bring something to race? I've never seen that charger of yours out there.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Got my SB E heads back from Ryan @ Shady Dell [Re: an8sec70cuda] #916048
02/03/11 03:33 PM
02/03/11 03:33 PM
Weddington, N.C.
Weddington, N.C.
Chip,
If I get the Rocky done I plan to get it out to the Rock. Working 60 hrs a week don't leave me much play time but I'm trying, maybe you and Dad might come up and help me change it all out? Friend's around here are pretty worthless for doing real car stuff...they'ed rather golf or watch tv.
The Charger hasn't been to the Rock for several years...but it's been there several times. What's cool is at least 2 people I know said they modeled their Charger's paint scheme after seeing mine there.
The last few years I've been working week-ends and for at least a few of them I was working 1/2 way around the world on assignment...sorry, I gotta pay the bills (putting one through college as we speak), buddy!
Chip I miss being your age and a lot younger...making good money...no kids and making extra $$$ driving a 4 speed anything and getting paid to drive other peoples rides (2 wheels or 4)because they couldn't shift, cut lights or ET as fast as me...but that was years ago.....no regrets....but also no excuses for the stage of life I'm at now...even still I know I can still drive a stick car with the best of 'em out there
WIZE
In Car:
