Got my SB E heads back from Ryan @ Shady Dell #916013
01/28/11 05:26 PM
01/28/11 05:26 PM
Weddington, N.C.
Streetwize Offline OP
Weddington, N.C.
Great job, Very professional, Ryan is 'Da man!"
Chompin at the bitt now for Spring to see how the "little" 414 is gonna do.
Wonder if they'll let a mopar powered Daihatsu into Mopars at the Rock?? seems like I saw a 340 powered TR7 there one year...but it might have just been a bracket race
WIZE
In Car:
Re: Got my SB E heads back from Ryan @ Shady Dell [Re: Streetwize] #916014
01/28/11 07:04 PM
01/28/11 07:04 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
quality price smart move!
Re: Got my SB E heads back from Ryan @ Shady Dell [Re: Streetwize] #916015
01/28/11 07:04 PM
01/28/11 07:04 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Okay, it took 108 views (me) but I'll ask: Flow numbers??
I would think a Mopar race would let anything in if it's pwoered by a Mopar bullet, yes?
Re: Got my SB E heads back from Ryan @ Shady Dell [Re: cudadoug] #916016
01/28/11 07:06 PM
01/28/11 07:06 PM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
PICS
Re: Got my SB E heads back from Ryan @ Shady Dell [Re: Scamp408] #916017
01/28/11 07:18 PM
01/28/11 07:18 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
Based on everything I've read on here, you certainly took them to the right shop. I just hope that chassis will work with all that new found power!
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: Got my SB E heads back from Ryan @ Shady Dell [Re: Scamp408] #916018
01/28/11 07:21 PM
01/28/11 07:21 PM
Weddington, N.C.
Weddington, N.C.
Stage II level porting only
Flow #'s
LIFT--IN/EX
.100"--72.6/NA
.200"--146.9/110.8
.300"--196.3/150.1
.400"--245.8/180.2
.450"--259.0/193.8
.500"--268.6/203.4
.550"--271.8/212.9
.600"--276.6/218.6
.650"--283.5/221.6
.700"--286.6/223.8
Picked up about 30 CFM from .350 up and 40 from ~.650, not using it all up though.
12:1 414 with a 255/263 @ .050 Solid Flat Tappet .606/.608 lift (1.6's) 109 centers in at 105. Ported 340 Victor, worked 830 Holley annular.
Should go low 13's in my little 2700 pound 4.56 gear Rocky....easy ....maybe upside down and backwards
Seriously though, I had the car over at Lennys and he commented that the thing has a good bit of Natural hook in it, I'm putting a 10" T/A in front of a standard gear 904 so the stall shouldn't be more than maybe 3800 or so, so it won't be real violent off the line.
WIZE
In Car:
Re: Got my SB E heads back from Ryan @ Shady Dell [Re: Streetwize] #916019
01/28/11 07:56 PM
01/28/11 07:56 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
Flow #'s
LIFT--IN/EX
.100"--72.6/NA
.200"--146.9/110.8
.300"--196.3/150.1
.400"--245.8/180.2
.450"--259.0/193.8
.500"--268.6/203.4
.550"--271.8/212.9
.600"--276.6/218.6
.650"--283.5/221.6
.700"--286.6/223.8
Surprising to see them climb in numbers even after 650
Re: Got my SB E heads back from Ryan @ Shady Dell [Re: Streetwize] #916020
01/28/11 08:10 PM
01/28/11 08:10 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
Flow #'s
LIFT--IN/EX
.100"--72.6/NA
.200"--146.9/110.8
.300"--196.3/150.1
.400"--245.8/180.2
.450"--259.0/193.8
.500"--268.6/203.4
.550"--271.8/212.9
.600"--276.6/218.6
.650"--283.5/221.6
.700"--286.6/223.8
thats some pretty darn good numbers for not beeing all out so to speak!
that part about upside down and backwards,gives me chills one of the fastest swedish streetracecars to this date set a europen record for streetcars at a track that way back in the 90īs
Re: Got my SB E heads back from Ryan @ Shady Dell [Re: 1Fast340] #916021
01/28/11 08:18 PM
01/28/11 08:18 PM
Weddington, N.C.
Weddington, N.C.
Yeah I talked to Ryan about what would be my best bang for the buck, I really was looking for a higher RPM limit with that cam and cubes and I only plan on running .600 lift max (actually a bit less for lash).
WIZE
In Car:
Re: Got my SB E heads back from Ryan @ Shady Dell [Re: Streetwize] #916022
01/28/11 09:10 PM
01/28/11 09:10 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
should do 13's with another small car in the trunk,if that dont do min of 11's i'll kick myself in the b@#$$*
Re: Got my SB E heads back from Ryan @ Shady Dell [Re: fishy340] #916023
01/28/11 09:53 PM
01/28/11 09:53 PM
Fly Over States
P
PHJ426 Offline
PHJ426  Offline
P
Fly Over States
Bobby,
Looking good there.
My friend Steve F. had a local Chebby guy rebuild his 340 with bad results, Ryan built Steve a nice 416 and now his Duster is in the 10.20's.
I dont even know Ryan but from all the raves on Moparts about his work and proven track record I had no problem telling Steve to truck his 340 block and heads over there to Ryan and have it done right.
Hey it would be cool to have your old 508 in my HEAVY 4000# Runner lined up next to Rocky.......
Re: Got my SB E heads back from Ryan @ Shady Dell [Re: Streetwize] #916024
01/28/11 10:44 PM
01/28/11 10:44 PM
Petersburg, Va
Darrell Offline
Darrell  Offline
Petersburg, Va
Bobby that Rocky ran 14s with a junkyard 318 and won a few races along the way!!
Can't way to see it at the Rock flipping backwards this year!! Will make a cool youtube video!
Re: Got my SB E heads back from Ryan @ Shady Dell [Re: Darrell] #916025
01/29/11 02:07 AM
01/29/11 02:07 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Intake #'s are very nice.
Exhaust are stellar.
I think with that cam , those cubes and that weight , you could forget to shift your way to low 13's.
Should be a blast.
Re: Got my SB E heads back from Ryan @ Shady Dell [Re: tubtar] #916026
01/29/11 04:15 AM
01/29/11 04:15 AM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
Should be a blast.
Agreed that the exhaust numbers are very impressive.
Re: Got my SB E heads back from Ryan @ Shady Dell [Re: Darrell] #916027
01/29/11 04:17 AM
01/29/11 04:17 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Not to Jinks things, But thats a mid 10.?? ride IMO once dailed in. mike
Re: Got my SB E heads back from Ryan @ Shady Dell [Re: POS Dakota] #916028
01/29/11 11:06 AM
01/29/11 11:06 AM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
Should be a blast.
I did'nt think they were anything special. Actually the .400-.500 exhaust #'s are off a hair, & the .300-.500 intake #'s are a little off as well. The low & high lift #'s look normal for that level of prep.
I don't flow heads very often anymore...especially a head like this that I've done 100 sets of, not alot of point. I worry more about what power they make. I did a 416 last year with heads in exact same state as these, Stage 2, same valve job, same chamber prep, same stock Edelbrock valves..... 12:1, Super victor, 750 Demon, 269 @ .050 roller & 1 5/8" TTI step header, so far 10.40 @ 128 @ 3100 lbs. Going to bigger header this year, should pick up maybe .1 or so & some changes in rear suspension should help 60' as well. It's good bang for the buck $525 port job on set of "factory replacement" designed heads.... & runs low 10's.
Re: Got my SB E heads back from Ryan @ Shady Dell [Re: RyanJ] #916029
01/29/11 12:05 PM
01/29/11 12:05 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Nice, I hope to have enough $$$ left over for a stage two once Ryan gets done fixing all the carnage on mine. Going on another 416 as well.
68 Barracuda Formula S 340
Re: Got my SB E heads back from Ryan @ Shady Dell [Re: Bad340fish] #916030
01/29/11 01:01 PM
01/29/11 01:01 PM
Weddington, N.C.
Weddington, N.C.
I run mostly 1/8th mile, if it stays on at least 2 wheels (not saying which 2) it ought to run somewhere in the 6.5-6.7 once it's sorted out. that would be mid-ish 10 in the quarter, not sure how the super sleek aero is gonna feel on the top end though!
Everybody comments how squirrelly they assume it's going to be but actually the only time you gotta be extra careful is in the bleach box, once it's pointed it goes very straight. I'm also used to driving a 90" wheelbase Cobra thats 300 pounds lighter and has about the same power/torque as this one will have. The block is really set down pretty low in the chassis and it has a full box frame that is super rigid.
My thoughts are now about whether to just keep running the generic 1 5/8" A body headers (which drop right in to the rocky like they were designed for it)....or roll the dice and go to a 1 7/8" which would be about the perfect size for it but may not fit as well
Re: Got my SB E heads back from Ryan @ Shady Dell [Re: RyanJ] #916031
01/29/11 04:27 PM
01/29/11 04:27 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Should be a blast.
Modesty will get you nowhere.
Most of my information is based on the work of others , but I'll offer up these numbers based of stock J heads
FLOW #’s
LIFT------ASCAST---------PORTED
.100”----62.1/46.6---------62.1/51.8
.200”----112.1/99.4-------135.2/103.5
.300”----156.6/128.3-----198.7/135.2
.400”----193.2/137.3-----239.8/158.7
.450”----200.1/138.3-----253.9/169.7
.500”----200.1/139.7-----258.4/182.9
.550”----200.1/140.8-----264.9/186.3
.600”----200.8/141.5-----254.6/186.3
All #’s at 28” of Water
2.02”/1.60” MP Stainless valves
They came from some guys web site.
And I assumed Eddies to be light weight ported J heads based on these numbers
AS CAST OUT OF BOX
LIFT-----IN/EX
.100”----72.5/N/A
.200”--131.1/107.0
.300”--182.9/151.8
.400”--216.6/181.2
.450”--227.7/182.9
.500”--235.9/185.6
.550”--238.7/185.6
.600”--242.2/185.6
.650”--243.2/185.6
.700”--243.2/185.6
So I see these numbers here
LIFT--IN/EX
.100"--72.6/NA
.200"--146.9/110.8
.300"--196.3/150.1
.400"--245.8/180.2
.450"--259.0/193.8
.500"--268.6/203.4
.550"--271.8/212.9
.600"--276.6/218.6
.650"--283.5/221.6
.700"--286.6/223.8
and I am thinking that as a percentage of gain , and an exhaust to intake ratio , those numbers fairly sparkle.
That they don't go flat anywhere is a testament to your skills , which as the kids are prone to saying these days , would be mad.
Those are going to be some really good working heads.
Re: Got my SB E heads back from Ryan @ Shady Dell [Re: tubtar] #916032
01/29/11 09:00 PM
01/29/11 09:00 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
I run Stage 2 ported e-heads by Shady Dell on my 414 and it pulls hard. The valve job was an absolute work of art.
