Re: What can I use to repair a 72 RR headlight bezel?
[Re: SkynyrdTim]
#915953
01/28/11 05:12 PM
01/28/11 05:12 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
As posted by Scott Harms Smith... (He repaired grills for customers)
Start with 100% pure Acetone, buy a gallon.
Pour an ounce or so into a glass jar (small open mouth jar). Take a scrap grill and using something sharp, scrape off peelings (like pencil shavings size) into the jar of acetone. Put allot of shavings in, the acetone will gradually melt the plastic into a goo. Add enough plastic until the goo reaches toothpaste consistency. Once you have a good batch melted put the lid on the jar tightly and set it aside. Now, prep your grill as normal, V out cracks on both sides, etc. Use clamps near the joint to align the two sides flush and parallel. Smear on some plastic goo, leave it crowned up over the crack like a regular weld looks, let it cure overnight. Sand to flush the next day, fill any pinholes with JB Weld. The crack will practically disappear at this point, paint as normal
[Re: SkynyrdTim]
#915954
01/28/11 09:00 PM
01/28/11 09:00 PM
Posts: 1,923 Medina, Ohio
HEMICUDA
Medina, Ohio
My passenger side bezel has a big crack in it. It's being held together right now with glue from my glue gun. That's the only adhesive I've found that actually holds this material. Can someone tell me what type of plastic or resin these are made from? I've tried epoxy, Bondo, super glue and many other adhesives, but none seem to stick or stick for long. Any help would be appreciated!
Send me your bezel Tim, I'll fix the crack for you, all I ask is to just pay for the return freight.
Michael C. Ross - Owner B/E & A Restoration Parts, Inc. www.beaparts.com 330-725-3990
[Re: SkynyrdTim]
#915958
01/29/11 09:25 AM
01/29/11 09:25 AM
Posts: 3,712 Sacramento, Ca
Darius
Sacramento, Ca
Since this is most likely ABS, Just go to the Home Depot and buy some BLACK abs glue in the plumbing section. It does the same thing as Scott's concoction does. Cleaning the part edges with acetone is a good idea also. I repaired my GTX grille with the ABS glue and it worked great.
Driving modern convenience in classic beauty
[Re: SkynyrdTim]
#915961
01/29/11 08:14 PM
01/29/11 08:14 PM
HEMICUDA
Medina, Ohio
Here's the back of it with all the gobs of glue from my glue gun!
Not scared yet Tim. When we restore a grille, sometimes the biggest struggle is undoing the improper repair before it can actually be done correctly.
[Re: SkynyrdTim]
#915963
01/30/11 10:38 AM
01/30/11 10:38 AM
Posts: 21,085 Niles , Ohio
therocks
Niles , Ohio
If you were close Id have my kid take it to work and weld it.They have a plastic welder.He has also used LockTite glue they have for plastics.That stuff is stronger than the original piece.I had a tail light for my 57 that was new and the piece for the screw broke off.He did it at work and it held for 8 years and is still holding.The LockTite glue is expensive.I dont know what number it is but it should be on their web site.Rocky
Chrysler Firepower
