Re: Windshield removal ...........
[Re: AverageJoe]
#915709
01/28/11 11:33 AM
01/28/11 11:33 AM
Challenger 1
Cincinnati, Ohio
Yeah - for fifty bucks or so, have it done by a pro ...........
Or buy this tool for 35 bucks and be sure not to damage your glass. The tool you bought is very difficult to use without damaging the glass. This tool is way,way better. Good luck with it, your gonna need it. You can buy just the braided brass wire for less at any auto parts store and it is NOT piano or gartar string.
[Re: rapom]
#915711
01/28/11 04:41 PM
01/28/11 04:41 PM
Posts: 708 Mechanic Falls, Maine
4BBodies
mopar addict
mopar addict
If you plan on putting in new rubber, no tools are needed. Just a utility knife to cut the rubber on the outside of the window. Then remove the window and what is left of the inside rubber gasket.
'73 's are factory installed with butyl tape, they do NOT have a rubber gasket. The above mentioned brass wire is great stuff, I usually get 3 or 4 removals from one roll. Take your time, it isn't that bad. Just my
[Re: DANA60]
#915713
01/28/11 07:52 PM
01/28/11 07:52 PM
Challenger 1
Cincinnati, Ohio
It is tough. Since they are basiclly glued in (butyl), so going to a pro maybe the way to go. Although you can get a new one installed for aprox $250.00 (sometimes alot less), so there is a savings to get it out yourself. Alot of them ending up cracking when you try to remove (even by pros), so good luck.
Have you done it?? If not how can you give advise?
The brass wire I have shown above is a very easy way to get them out without any risk of cracking them. I have cut out 5 of them so far by myself and have not even come close to breaking any glass. Once you cut 360 degrees around the windshield, it can be lifted out very easy, at least on E bodys.
[Re: RebelDart]
#915715
01/29/11 04:24 PM
01/29/11 04:24 PM
Posts: 11,632 SHELBY TWP,,MICHIGAN
72N96RR
I LOVE WEDGIES
I LOVE WEDGIES
I need to remove glass from a 73 Roadrunner - I bought the tool withe the 90 degree blade and cable/handle ----- any tips before we start ?
That tool you have is perfect IF the windshield is already cracked and needs to be replaced..If you want to reuse the glass used the wire method and make sure the edges are heated well enough to glide the wire thru with no hang ups...good luck... The 90* tool is fine but if you lean it to one side or the other just even a little you will hear a sound that you dont want to and your neighbors will not like the language...
1972 Road Runner / GTX 440 4spd Dana 3.54 Just about to turn 26K original miles..
A boat, a GMC truck, some Craftsman Tools, LOTS of Zombie Protection, and a few Goldfish..
If you love someone set them free.. If they come back it means nobody else wanted them either..!!
[Re: bboogieart]
#915720
01/30/11 04:59 PM
01/30/11 04:59 PM
Challenger 1
Cincinnati, Ohio
Why not use the right wire and leave the guitar wires to the guitarists? You could use it as well as piano wire but why would you? I am guessing you have some lying around. Try it, but the big thing as stated is take your time, windshields break easy. I have broken a few and learned it is much easier to be patient, as mentioned. Good luck.
The key here is "braided brass wire" Brass won't hurt glass, braided makes it cut great and the one's I did cut just fine cold. Nothing needs to be "heated"
It seems if the glue was heated then it would be sticky and want to stay stuck after you cut it?
I have never used piano or gitair strings but have heard guys on here say they had a hard time using instrument string. And I'm thinking it is mostly steel wire? which won't bend freely around corners when your sawing. And I doubt that it is braided. And I bet it is thicker too.
So my advise to you is to use the wire from a auto parts store and be sure to get the job done correctly. The wire has to bend around a very tight radius(the thickness of the glass) at 180 degree bends multiable times while your sawing, so the right wire is important.
PS the large T handle tool in the picture above is what is used to push the wire through the glue to get started. It's very handy.
Once all the trim is off both sides, I can cut it out in 2 or 3 minutes by myself, I have long arms.
