mini starter for 400 #915683
01/28/11 10:02 AM
01/28/11 10:02 AM
louisiana
mopar70charger Offline OP
louisiana
could any one tell me where to get a correct mini starter for a mopar 1972 400 engine ..i recently bought one off ebay from a guy in california and got it here this week and went to install it and it wouldn't fit correctly..if i take the mounting bolts off of the starter it seems to fit in the transmission fine flush , but when i try to align the bolt pattern for both holes the solenoid body on the mini starter seems to hit the engine block.. and want align flush ..i don't understand this has anyone had this problem.....please help
Re: mini starter for 400 [Re: mopar70charger] #915684
01/28/11 10:09 AM
01/28/11 10:09 AM
Suffolk,VA
I
ireland383 Offline
ireland383  Offline
I
Suffolk,VA
I know I had to grind a spot on my mini where it was touching the block slightly IIRC.
Re: mini starter for 400 [Re: ireland383] #915685
01/28/11 10:36 AM
01/28/11 10:36 AM
Central TX
roe Offline
roe  Offline
Central TX
same here, a little grinding and then it slid right in.
1971 Plymouth Satellite
408/904 8 3/4 3.23 SG
Re: mini starter for 400 [Re: roe] #915686
01/28/11 10:39 AM
01/28/11 10:39 AM
louisiana
louisiana
where exactly did you grind it at and what did you use a die grinder..thanks
Re: mini starter for 400 [Re: mopar70charger] #915687
01/28/11 10:53 AM
01/28/11 10:53 AM
Central TX
roe Offline
roe  Offline
Central TX
I picked up a starter for a '90 truck v8 for my sig car, much smaller, lighter, and spins much faster. I used a die grinder on the metal casing that protects the part that pops out to engage the flywheel. When I bolted it up that part was rubbing the aftermarket flexplate. So a few minutes with the grinder gave me all the clearance needed. I also ground a little off the nose cone. And removethe electrical connector so your factory starter wires will bolt right to the starter. Cost me $118 or so at autozone with a lifetime warranty though.
roe
Re: mini starter for 400 [Re: roe] #915688
01/28/11 10:59 AM
01/28/11 10:59 AM
Central TX
roe Offline
roe  Offline
Central TX
Also, the starter that I picked up (any early 90's v6 or v8 truck) is supposed to fit SB, BB, and RB's too, IIRC.
Re: mini starter for 400 [Re: mopar70charger] #915689
01/28/11 11:11 AM
01/28/11 11:11 AM
Lost in the ozone again
stubbs300 Offline
Vacation
stubbs300  Offline
Vacation
Read, learn, heed this! http://www.moparts.org/Tech/Archive/elec/1.html
Re: mini starter for 400 [Re: mopar70charger] #915690
01/28/11 11:43 AM
01/28/11 11:43 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
what exactly is it hitting ? do you have headers ?a mini on a low deck with headers can have a clearance issue also
Re: mini starter for 400 [Re: JohnRR] #915691
01/28/11 12:03 PM
01/28/11 12:03 PM
louisiana
louisiana
i believe it to be hitting on the housing of the solenoid on the engine block
Re: mini starter for 400 [Re: mopar70charger] #915692
01/28/11 04:55 PM
01/28/11 04:55 PM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
I bought one of these.
I had to remove the insulated jumper terminal lug on it( simply unbolts ) and then it fell right on. This is on a street hemi with stock manifolds
http://www.dbelectrical.com/p-1318-new-m...66-snd0088.aspx
Re: mini starter for 400 [Re: gtx6970] #915693
01/28/11 11:37 PM
01/28/11 11:37 PM
Northern NJ
StukaJU87 Offline
StukaJU87  Offline
Northern NJ
That's the one I have too. Fits pretty nice.
Scott
1969 Super Bee, 383/4 speed
