Re: Hemi positve battery cable routing E body
[Re: FJ5_Fish]
#915646
01/28/11 03:58 PM
01/28/11 03:58 PM
Posts: 193 Australia
Teamx
Australia
Ok, I have the cable running down the back of the shock tower through the bracket on the frame rail then through the strap on the back of the head. Should it go in front or behind the speedo cable and were does the auto trans saftey switch harness go? Thanks Tim
[Re: Teamx]
#915647
01/28/11 04:47 PM
01/28/11 04:47 PM
Posts: 21,449 It's a dry heat
gtx6970
It's a dry heat
Sounds like you have it just like the one I'm doing. In regards to the speedo cable routing, I don't know as I don't have the speedo cable in yet.
Neutral safety wiring comes out of the unsulation , to the bulkhead connecter , then along the back of the block / over the top of the bellhsg and down to the NS switch on the trans
[Re: Teamx]
#915651
01/28/11 08:59 PM
01/28/11 08:59 PM
gtx6970
It's a dry heat
I have the lower side of saftey switch worked out but were does the other end run when it comes out of the bulk head, does it go up over the master cylinder in the two straps with the headlight harness?
Wiring exits the main battery cable about where the left shock tower is. This wiring runs along the drivers inner fender , around the booster, thru the 2 clips on the firewall then into the bulkhead
[Re: FJ5_Fish]
#915658
01/29/11 11:57 AM
01/29/11 11:57 AM
gtx6970
It's a dry heat
Jim, Mines bigger than yours
[That's not what your girlfriend told me!
Bill - couldn't resist!
SHHHHHHHHH, don't tell my wife
[Re: Teamx]
#915660
01/29/11 10:20 PM
01/29/11 10:20 PM
Teamx
Australia
