Re: 73 Charger electrical issue
[Re: AverageJoe]
#915417
01/29/11 11:14 AM
01/29/11 11:14 AM
Posts: 329 Orange Park, FL
MRHWS
Orange Park, FL
Just a possibility, but when column was re-installed, you may have it in too far or not far enough causing linkage to be out of adjustment. Move lever to each gear mark and try to start. Ignition harness could also be fried. So many possibilities with these things.
1973 Charger SE
1974 Charger Rallye 440 Aztec
2008 Charger SRT8
[Re: MRHWS]
#915418
01/29/11 11:21 AM
01/29/11 11:21 AM
Posts: 6,097 Valencia, España
NachoRT74
Valencia, España
good one...
you never told us of is column shifter, but if it is, thats a posibility... did you try to crank in N ?
[Re: 268RTs4ME]
#915421
01/29/11 11:54 AM
01/29/11 11:54 AM
NachoRT74
Valencia, España
74s are different from 73 JUST RIGHT on cranking circuit due the interlock system
[Re: AverageJoe]
#915425
02/02/11 11:44 PM
02/02/11 11:44 PM
RapidRobert
I'd jump from the large batt stud on the starter relay to the nearby "ign" male terminal on the relay & see if it cranks & if no go I'd replace the connector back on & jump the "grn" male terminal (not the connector that's plugged on it) also on the starter relay to ground & turn the ign to start w the key
