Dykes Rings question #915210
01/27/11 05:04 PM
01/27/11 05:04 PM
Roswell, GA - near Atlanta
cloneguy Offline OP
super street
cloneguy  Offline OP
super street
I have a customer who has me building a hemi for the street. He has cobbled together a bunch of parts including a pretty nice set of Venolia 11:1 pistons that were made with a top grove for a Dykes 017 Ring.
I haven't been able to find the Dykes rings for less than a lot of money and the customer wants me to substitue with a standard ring.
This is just a pump gas, naturally aspirated engine. Is it possible to substitute a standard ring and if so, does anyone know what size?
Thanks,
Tim
Martin, GA Quality Auto Restoration with Fair FIXED Pricing. Fast-N-Dangerous@comcast.net
Re: Dykes Rings question [Re: cloneguy] #915211
01/27/11 05:49 PM
01/27/11 05:49 PM
Longview, Texas
marvo451 Offline
marvo451  Offline
Longview, Texas
A Dykes ring in a street car probably isn't a very good idea. Also, you can't substitute another ring without re-machining the piston ring grooves. A Dykes ring is "L" shaped.
Re: Dykes Rings question [Re: marvo451] #915212
01/27/11 10:07 PM
01/27/11 10:07 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
This may make me seem like an A$$ but if you dont know the design properties and application uses of a Dykes ring vs. a std ring, you have no business building a Hemi. There are other aspects of Hemi assembly (set up) that need consideration that are'nt as baisic as ring type.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Dykes Rings question [Re: cloneguy] #915213
01/28/11 01:59 AM
01/28/11 01:59 AM
Thanks,
Tim
send the pistons back to Venolia (after you call them and get approval and prices and time frame) and have them recut the ringlands for a street freindly ring combination, you might want to buy the rings from them also
Re: Dykes Rings question [Re: Cab_Burge] #915214
01/28/11 02:15 AM
01/28/11 02:15 AM
Manitoba, Canada
liteweight Offline
liteweight  Offline
Manitoba, Canada
If this is a cobbled together motor that he wants to run on the street, then the 11:1 on a steel headed motor is going to rattle itself to death.Between the Dykes ringlands, which should never be used for street applications, unless he wants to replace them on a regular basis, & the amount of squeeze, he's better off with a set of street slugs in the 9:5-10:1 zone. Lots of stuff on ebay if your patient.
Liteweight
Daryl
68 Hurst LO Hemi Dart 70 hemicuda 4 spd. R code owned since 76 70 GTX 4 spd. 21,000 orig. miles 55 Ford F100 chopped,slammed,bagged & supercharged 96 Ram 2500 4X4 Twin turbo'd Cummins 550hp 1200 ft. lbs tow vehicle
Re: Dykes Rings question [Re: cloneguy] #915215
01/28/11 03:28 AM
01/28/11 03:28 AM
Thanks,
Tim
The only way you will really know the true compression ratio of those pistons is assemble one rod and piston, stick it on the crankshaft and pour a cylinder(to figure the dome volume in CC) with the dome lower than the deck. Make sure and measure how far down on the stroke you go to to get the dome below the deck( I like and use -.050 usually ) and then figure the volume for the stroke used to get the piston down below the deck. Subtract the actual volume from the claculted volume and that will be your dome volume do the rst of the math to figure the true compression ratio I have seen 10.25 to 1 comp. ratio advertised piston actually measure out to have 9.2 to 1 and some just the opposite, 10.25 to 1 be 11.7 to 1 Let us know what you decide to do, BTW welcome to the freindlly Mopar jungle
Re: Dykes Rings question [Re: Cab_Burge] #915216
01/28/11 03:37 AM
01/28/11 03:37 AM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
Quite frankly ...I like dykes rings. The first aftermarket-piston motor I ever build had those rings ....
That thing ran BIG MPH ...for what is was .... a small Racer Brown cam, JUNK heads, spinning the tires - through the muffs ... 11.86 ...119.90 mph.
Re: Dykes Rings question [Re: cloneguy] #915217
01/28/11 01:02 PM
01/28/11 01:02 PM
Franklin, TN
23T Hemmee Offline
23T Hemmee  Offline
Franklin, TN
A point to consider, if these pistons have an .017 top ring, then they are more than likely a blown alky piston. The old NASCAR, Pro Stock and most custom N/A pistons used the .031 dykes which were available in double moly versions. I've only seen the .017 in stainless and tool steel but a moly version may be available. The blower piston has a full skirt which would lend itself well to street use and there is enough meat in the dome to lathe it down to get whatever compression you wanted and still have a decent piston crown. Yes, the dykes is not the optimum for street use but unless you're building a 100,000 mile engine, you can definitely get a couple of years of use out of them, depending on whether your customer wants the build for occasional use or a daily driver. The costs of sending the pistons back to Venolia to have the lands recut would probably be more than the increased cost of the rings, and unless things have changed drastically, their customer service for jobs like this is in the "zip" "nada" range. Just my personal experience, I'm sure others speak glowingly of them......
Ronny
6.789 @ 198.63 **.956 Brand New 60'***
4.17@ 169 1/8th mile
John 14:6
https://www.youtube.com/watch?v=TUku_hjYRh8
Re: Dykes Rings question [Re: 23T Hemmee] #915218
01/28/11 01:20 PM
01/28/11 01:20 PM
malvern, ohio
3
3ddart Offline
3ddart  Offline
malvern, ohio
another option on recutting the ring lands is to contact rebco machine inc. in augusta, kansas at 316/775/6308. that was who i had do mine as they originally had dykes ring and my car is mainly a street car. dave
Re: Dykes Rings question [Re: marvo451] #915219
01/28/11 03:30 PM
01/28/11 03:30 PM
NC
440Jim Offline
440Jim  Offline
NC
Yep,
Re: Dykes Rings question [Re: cloneguy] #915220
01/28/11 10:03 PM
01/28/11 10:03 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
I put about 50,000 street miles on a couple of dykes equipped Hemis between 1980 and 2005. They are not unstreetable at all. The engines put out excellent power and didn't noticeably smoke. I would run them again in a heartbeat. How many miles is the customer going to put on this engine 100,000? I personally think proper valveseals and guide clearance is more of an issue than running dykes rings on a Street Hemi.
Sheldon
Re: Dykes Rings question [Re: dOc !] #915221
01/28/11 10:07 PM
01/28/11 10:07 PM
michigan
sturmenater Offline
sturmenater  Offline
michigan
I tried to like dykes too but they never liked me back said they only liked other women
Re: Dykes Rings question [Re: RUNCHARGER] #915222
01/28/11 10:27 PM
01/28/11 10:27 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
Sheldon
Did you ever check to see hom much the ring-end-gap grew?
I got a puff-O-smoke as I hit the throttle .. but then it was as clean as a
Re: Dykes Rings question [Re: sturmenater] #915223
01/28/11 10:34 PM
01/28/11 10:34 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
ONLY a twisted-guy would have picked-up on something like that !
WHAT you have to get THEN is some LIPstick to put on those rings .. to make them more attractive !
Re: Dykes Rings question [Re: W.I.N. Racing] #915224
02/02/11 06:40 PM
02/02/11 06:40 PM
cloneguy Offline OP
super street
cloneguy  Offline OP
super street
Thanks to everyone for the information. And, I don't think you are an A$$ any more than anyone else from NY.
For the record, I've built quite a few engines in my 30 year career although pretty much all for the street. They include the 1,000 HP, blown, 572 inch, BME aluminum rod, pump gas street hemi in the streetrod in my icon (this will give people a chance to talk about how you can't use aluminum rods on the street) and a 900 HP, 572 inch, 12.5:1, pump gas street hemi with a proprietary cam grind (this is so you can talk about how you can't use high compression with pump gas). None of the others are as interesting although I do have a 1,000 hp twin turbo injected SB Chivy engine in the hopper.
But alas, I had never seen or heard of Dykes rings. It seems I learn something new every day.
And, I'm going to go the route of having the pistons recut.
Thank you all very much!
