correct way to install intake manifold gaskets
#914872
01/26/11 11:03 PM
01/26/11 11:03 PM
Posts: 124 Pittsburgh, PA
bigdaddywiz
Pittsburgh, PA
hi guys. ok, i have my gaskets now and i'm in the process of putting the 340 4bbl intake manifold onto my 318 and need to know the correct procedure for installing the gaskets and sealer. please keep in mind this is the first time i've ever had to install an intake manifold.
do i use the front and back gaskets or do i just use a high temp sealer? i've hear of people using these rubber gaskets and they end up popping out when torquing the bolts down. do i use sealant on both sides of the gaskets? is it easier to put the gaskets down on the heads, then lay the manifold down?
this engine noob needs to know the correct steps and tricks (if any) and i'm sure i'm making this out to be more complicated than it really is!
thanks for any tips and info!
73 Road Runner
09 Challenger R/T
Re: correct way to install intake manifold gaskets
[Re: bigdaddywiz]
#914873
01/27/11 12:05 AM
01/27/11 12:05 AM
RapidRobert
Put some clean paper towels or similar in the ports to keep debris out of them and a clean shop towel large enough to cover the flat valley also to keep debris out. I use gasket sealer (not RTV) on both sides of each of the 8 intake port cutouts on the 2 side intake gaskets and I use a dab of super glue at 3 or 4 places adjacent to the port clusters to hold the gaskets in place on the head intake faces. I do not use the supplied front and rear gaskets but clean the front/rear rails and the matching intake front/rear surfaces and use a wide carefully placed swath of clear RTV instead. Do let it set up overnight. alot of the (supplied) front/rear gaskets in the gasket kits (esp the cork ones) are too thick & can hold the intake up just a hair to where one of the front water ports will begin to seep after a period of time. #1 Clean the surfaces/keep gaskets aligned/no debris on the gaskets/surfaces & I'm a firm believer in using (the appropriate) gasket cement on any gasket whether steel shim (esp needed) or composition. Clean the bolt threads & I dip them in 30 wt oil then blow em off w shop air or even a quick shot of WD40 & go thru the bolt pattern at least 3 or 4 times to 35 lbs (kind of anal but I'm like that) & if the carb is off keep it off until you torque the intake (easier to access all the bolts in a straight line from your torque wrench). EDIT dont forget to drain a gallon or so of coolant out 1st & blow off the top of the eng also to keep loose debris out of the valley area & pull/toss any dowel pins
[Re: JoesMopar]
#914875
01/27/11 12:19 AM
01/27/11 12:19 AM
bigdaddywiz
Pittsburgh, PA
thank you very much guys! that really helps!
73 Road Runner
09 Challenger R/T
[Re: pishta]
#914879
02/12/11 01:48 AM
02/12/11 01:48 AM
Posts: 3,344 Central TX
roe
Central TX
On a smallblock, which ports are water ports?
roe
1971 Plymouth Satellite 408/904 8 3/4 3.23 SG
