Pitman Arm ID - 70 Cuda #914336
01/26/11 03:07 PM
01/26/11 03:07 PM
Ft. Lauderdale, FL
solarguy Offline OP
solarguy  Offline OP
Ft. Lauderdale, FL
I need help ID'ing the pitman arm currently on my 70 Cuda 340, Power Steering. The arm has what looks like part% 2835378 on it and NOT 2835880 which my parts book shows as oem. I'm hoping this is from a later box using the less expensive pitman arm. I know there is a differnce with shaft size or such, but don't know for sutre how to tell. Can anyone run the part I have on now, and advise me as to which replacement I need.
Re: Pitman Arm ID - 70 Cuda [Re: solarguy] #914337
01/26/11 04:24 PM
01/26/11 04:24 PM
NY
twodoorpost Offline
twodoorpost  Offline
NY
2835878 is the casting number. It is the correct one (part #2835880) for your car. Casting numbers are very often different from the part number by 1 or 2 digits.
Re: Pitman Arm ID - 70 Cuda [Re: twodoorpost] #914338
01/26/11 04:33 PM
01/26/11 04:33 PM
Ft. Lauderdale, FL
solarguy Offline OP
solarguy  Offline OP
Ft. Lauderdale, FL
BLESS YOU. How the heck do you know which is the casting number and which is the part number. The ONLY number I can see on this is the 2835878 number. Now I know which to order. THANKS AGAIN
