vac. secondary #914288
01/26/11 10:09 AM
01/26/11 10:09 AM
south carolina U.S.
DOUGG Offline OP
DOUGG  Offline OP
south carolina U.S.
I'm going through a holley 750 vac. sec.[80508s]. Anyone know the factory setting for the sec. blades ? Just want to check & make sure it hasn't been monkeyed with before.
Re: vac. secondary [Re: DOUGG] #914289
01/26/11 12:33 PM
01/26/11 12:33 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
Open it up so it's not bottomed out in the bore.
I've flipped the set screw so you can access it bolted to the intake. Or even switch it out to a hex head set screw.
Then you can open it up a bit more to bleed in some air on big cammed engines.
