7&1/4 sure grip need info
#914205
01/26/11 12:46 AM
01/26/11 12:46 AM
RapidRobert
OE rear axle from a 66 barracuda. Would this be a clutch sure grip? Rebuildable? Same SG unit as an 8&3/4?. Thank you for your time.
Re: 7&1/4 sure grip need info
[Re: Kern Dog]
#914207
01/26/11 02:09 AM
01/26/11 02:09 AM
RapidRobert
I looked on Randy's site & no clutch plate kits avail. Got my eye on one and it may be good as is & will be going into an easy driven (wintertime) daily driver 65 dart just to get around in the snow
[Re: mopars4ever]
#914209
01/26/11 02:17 AM
01/26/11 02:17 AM
RapidRobert
this would go into a minimum throttle daily driver 318 for the winter snows. Havent went & checked it out yet but spoke to the owner & he let it slip that he has done a few burnouts w it w the 273 so he knew it was a sure grip. (He just swapped in a 360/4 sp/8&3/4)
