Re: 1965 318 Poly ? Rebuild or swap to LA 318? [Re: 65rbdodge] #91391
05/30/10 09:59 PM
05/30/10 09:59 PM
HAMILTON,ONTARIO,CANADA
RED73RALLYE Offline
RED73RALLYE  Offline
THE 318 POLY CAN BE BORED OUT .100 AND THIS ENGINE WILL BE ONE HECK OF A STUMP PULLER
Re: 1965 318 Poly ? Rebuild or swap to LA 318? [Re: dogdays] #91392
05/30/10 11:32 PM
05/30/10 11:32 PM
Desert Tracker
HYPER8oSoNic Offline
Desert Tracker
I have seen a few P-600s go over the 'bay and have yet to see one with the Rochester bolt pattern. They are relatively rare. For those who think that Weiand is still making the 2-4s for the Poly, get real. I wish that they were still making the 7503, but that's been gone a year. I don't have a catalog old enough to show tthe Weiand 2-4 manifold. Offenhauser AFAIK never made an intake for the Plymouth Poly. They might have made intakes for Chrysler or Dodge Polys but not for the one that turned into the 318.
They are a good engine but the two problems that I talked about in an earlier postt are still there.
R.
Ain't it the truth? GOOD MOTOR.
"Stupidity is Ignorance on Steroids"
"Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
Re: 1965 318 Poly ? Rebuild or swap to LA 318? [Re: HYPER8oSoNic] #91393
05/31/10 12:10 AM
05/31/10 12:10 AM
Mi,U.S.A.
mike s Offline
mike s  Offline
Mi,U.S.A.
Camcraft also has cams for the poly.The cumbustion chamber is almost identical to the 2008 up 4.7L Chry V-8.The cyl heads can be ported to very close to the same numbers as an Edelbrock magnum with custom valves which are available.A friend is fabing an aluminum custom intake (single 4 bbl).Easy to stroke with available cranks.Overbore .060 easily more with sonic check.
Well worth the added expense.
Leave the gun.......take the Cannoli's....Mike
Re: 1965 318 Poly ? Rebuild or swap to LA 318? [Re: mike s] #91394
05/31/10 01:21 PM
05/31/10 01:21 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
I have and have owned an example of every Mopar V8 in pretty much every size, up to the late '70s. I'd stick with the Poly, good engine. Have one now with 103K, stock, excellent street motor. IIRC, the '65 Torqueflite has some 1-year-only features, primarily in the shift mechanism.
I'd be inclined to run a stock cam in a car that heavy, and find or adapt a higher-ratio rocker to get some lift; you'd maintain strong vacuum but pick up HP & TQ. Should be a junkyard or swap meet 4-bbl intake somewhere, and improving the exhaust of course helps.
Re: 1965 318 Poly ? Rebuild or swap to LA 318? #91395
05/31/10 03:44 PM
05/31/10 03:44 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
Were any of the LA 318s internally balanced? We would have to use the 65 torque converter, so if the newer 318s are externally balanced, we would need to add a weight to the old converter, correct?
All the poly 318's were internally balanced, as were all LA 318's until ???? AFAIK, the late magnum 318's are also internally balanced, but I could be wrong.
all 318's are internal balanced....an LA top end bolts to a poly block, too, you just need an LA cam...
2017 Grand Cherokee Overland
Re: 1965 318 Poly ? Rebuild or swap to LA 318? [Re: patrick] #91396
05/31/10 04:10 PM
05/31/10 04:10 PM
NC
SLOW67 Offline
SLOW67  Offline
NC
Sonic check the poly block, if its got enough material bore it to 4.04 and put a set of stock 340 pistons in it, add a steel 273 crank and stock rods and have yourself a 340 We did this in a friend of mines boat and it turned out pretty well.
Re: 1965 318 Poly ? Rebuild or swap to LA 318? [Re: Dennis_K] #91397
06/01/10 07:15 AM
06/01/10 07:15 AM
West Tennessee
rbstroker Offline
rbstroker  Offline
West Tennessee
I had a new 1965 Sport Fury in 1965. It had a 318 and AC. Made a few trips between Detroit and LA area. It was great on gas. I finally changed the 2bbl setup to a Carter AFB by using an earlier intake (1958 I think), had dual exhaust made up, and was very happy with the increase in performance. I didn't do it, but changing the 2.76 gear to a 3.23 would probably make a huge difference all by itself.
This is the land of the free because of the brave
Re: 1965 318 Poly ? Rebuild or swap to LA 318? [Re: rbstroker] #91398
06/01/10 09:25 PM
06/01/10 09:25 PM
I'm wondering when someone will notice that the OP's question was posted two years ago.
Re: 1965 318 Poly ? Rebuild or swap to LA 318? #91399
08/18/10 12:25 AM
08/18/10 12:25 AM
Iowa, US
oldsklharo Offline
oldsklharo  Offline
Iowa, US
Well if he is not around anymore I will take all advice given above and put it to good use!! I am a 66' Coronet 440 owner and it has a Poly in it. I want to build something strong and different.........something you don't see every day and you guys have made my day!!!!
Thanks, Mike
Re: 1965 318 Poly ? Rebuild or swap to LA 318? [Re: patrick] #91400
02/28/13 08:49 AM
02/28/13 08:49 AM
Earth
Rob C Offline
Rob C  Offline
Earth
Sorry for the thread revival, but while the Poly & LA head will bolt to each others respected blocks, there useage on each others blocks is a no way, now how, no go!
Water cooling ports are the issue.
Otherwise, the blocks are extremely close to each other. More like a evolution on the LA.
