use all the small stuff from the 74 on the 89 engine
no,you do not need to change the dist drive
it will have the short nose roller cam,so no mech fuel pump/may have the long nose cam and no ecentric..so a stock one will swap on...this needs to be looked at with the t-cover off
t-cover may just have the block off plate at the FP location
hughes engines sells an extender for a short nose cam to run a mech pump on the tbi cam
you can swap in any retro roller cam and use the stock roller gear/hardware
I run a lunati 60710 roller cam in my 88 318
it a premag so set it up just like the old 74 318
very ez swap and hook up IMHO
