somebody here with a 100 amps tuff stuff Mopar alt ? #913665
01/25/11 02:24 PM
01/25/11 02:24 PM
Valencia, España
NachoRT74 Offline OP
Valencia, España
I don't care if chromed, black, polished or natural ( I would go If I do, with natural anyway, or maybe polished )... just want to see it, since all pics I have found are just referential pics
Better if the regular one, not the "one wire" alt, although a one wire alt is really the same regular alt with a mounted on regulator
Please...
I'm trying to discover is the 100 amps alt looks like this:
or like this:
dunno if you note the difference, and is not the pulley
Re: somebody here with a 100 amps tuff stuff Mopar alt ? [Re: NachoRT74] #913666
01/25/11 03:04 PM
01/25/11 03:04 PM
Vancouver, WA
MoparMarq Offline
MoparMarq  Offline
Vancouver, WA
My guess (and it is a guess) is that it is the one with the larger stator magnet...
The other one has dinky magnet
Re: somebody here with a 100 amps tuff stuff Mopar alt ? [Re: MoparMarq] #913667
01/25/11 03:08 PM
01/25/11 03:08 PM
Valencia, España
Valencia, España
yes thats my guess too ( the one on bottom )... that alt is around 1 and a half milimeter wider, and its a TIGHT fit on engine, but want to be sure.
Beside being the stator visible like the one on top is the correct look for a 74
Re: somebody here with a 100 amps tuff stuff Mopar alt ? [Re: NachoRT74] #913668
01/25/11 03:49 PM
01/25/11 03:49 PM
Ohio
LS-300 Offline
LS-300  Offline
Ohio
Does it have to be a Tuff Stuff unit or the standard 100 amp unit from the factory?
1979 Chrysler 300 1968 Barracuda project
Re: somebody here with a 100 amps tuff stuff Mopar alt ? [Re: LS-300] #913669
01/25/11 05:28 PM
01/25/11 05:28 PM
Valencia, España
Valencia, España
standart 100 amps factory is a leece neville alt... totally diff deal, requires diff bracketing, belts, and even upper hose radiator. The bigger stock piece on this look is 78 amps.
Re: somebody here with a 100 amps tuff stuff Mopar alt ? [Re: NachoRT74] #913670
01/27/11 01:26 PM
01/27/11 01:26 PM
Valencia, España
Valencia, España
tuff stuff crew haven't able to give me an exact answer
Re: somebody here with a 100 amps tuff stuff Mopar alt ? [Re: NachoRT74] #913671
01/27/11 03:21 PM
01/27/11 03:21 PM
Mesa, AZ
P
Pat_Whalen Offline
super gas
Pat_Whalen  Offline
super gas
P
Mesa, AZ
I have the 100a Tuff Stuff alternator in black. It is this one:
and has the wider stator magnet.
Re: somebody here with a 100 amps tuff stuff Mopar alt ? [Re: Pat_Whalen] #913672
01/28/11 01:39 AM
01/28/11 01:39 AM
gtx69 Offline
super gas
gtx69  Offline
super gas
Pat is that 100a tuff stuff a squareback or roundback alternator?
Re: somebody here with a 100 amps tuff stuff Mopar alt ? [Re: Pat_Whalen] #913673
01/28/11 02:09 AM
01/28/11 02:09 AM
Valencia, España
Valencia, España
ok, so, its with both housings meeting in the middle, right ?
For all of you guys what don't know, the unit ( on stock form ) with both housings meeting in the middle is wider than the one with the visible stator magnet between housings and gets some clearence problems with block and back of alt, requiring longer belts to get it away from block.
Also rear spacer need to be trimmed out a little bit to fit it easier between engine and upper bracket, if not, the alt assembly will push out the upper bracket a little bit
If you don't trim the rear spacer will fit anyway, but tighter and harder to mount
thats why I'm asking about this. I'm searching for the better fit unit, 100 amps ( already got from tuff stuff they feed out around 45 amps at iddle what is the main goal, not really the full 100 amps, what mostly sure will never require )and stock look cast or polished.
Re: somebody here with a 100 amps tuff stuff Mopar alt ? [Re: gtx69] #913674
01/28/11 02:30 AM
01/28/11 02:30 AM
Valencia, España
Valencia, España
squareback as far I know... can be modified to fit the inner parts on a roundback housing though if you care about the correct round back look
If you just care about make it works like a roundback alt ( one wired field ) just need to ground one of the brushes... a metallic washer is enough to that.
I think the main diff on bigger output alts is the stator windings, maybe also rotor windings but I don't think really diodes.
Re: somebody here with a 100 amps tuff stuff Mopar alt ? [Re: NachoRT74] #913675
01/28/11 08:02 AM
01/28/11 08:02 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Mine went in the garbage can after I blew the windings off it...
Re: somebody here with a 100 amps tuff stuff Mopar alt ? [Re: Dragula] #913676
01/29/11 11:26 AM
01/29/11 11:26 AM
Valencia, España
Valencia, España
which one ? stock or Tuff Stuff ?
if Tuff Stuff, which kind it was and PN ?
