Turbo fabrication tips
#913371
01/25/11 12:23 AM
01/25/11 12:23 AM
Posts: 142 Maryland
Sick 660r
Maryland
Ive done some research but im looking for some tips from those that have cusotm setups. In a few weeks I will be having my setup made by a friend but I dont think he has ever done a turbo setup. He is a welder for a living and he has done work for me in the past so I have no doubt in his ability.
Turbo will be from supernatural. Its a 88mm GT55 with a 1.08 a/r T6 99mm GT47 turbine. I will be using flipped shorties with 1.5" primaries and 2.5" collectors. All hot side piping will be 2.5" 304 SS with v-bands. Exhauset and DP will be 5" aluminum. Wastegate will be a 60mm tial dumped back into the DP and I will have a tial bov as well.
Does anyone have tips on fabricating everything?
thanks
2000 dakota
418 magnum
paxton novi 2k
T56
Re: Turbo fabrication tips
[Re: Sick 660r]
#913372
01/27/11 09:48 PM
01/27/11 09:48 PM
Posts: 475 HEMPSTEAD TX
CUUDAK
HEMPSTEAD TX
Looks like you have everything you need! Just make sure you fab a bracket for the turbo to mount to. This should be mounted to the engine. Don't hang the turbo from the headers. This will reduce the possibility of the headers cracking.
SRT8 CHARGER "Four door bore" <img src="/ubbthreads/images/graemlins/smile.gif" alt="" />
[Re: Randy..]
#913374
01/28/11 02:16 AM
01/28/11 02:16 AM
Posts: 3,502 SOUTH JERSEY
HEMIFRED
SOUTH JERSEY
don'tb waste time and money building a fancy set of tuned headers. a simple log will take care of all your needs. I made over 1400hp with a set of 179.00 Sandersen street rod block hugger headers. The twin turbo Hemi just tested on the chassis dyno used plain old simple log headers to produce 2370 RWHP at 28lb boost. I have yet to have anything more complex in design used on any of my turbo builds. Fancy looks nice but not a must that's for sure here's the main page http://prostockhemi.com/gallery/turborr2/ my logs
home of the Sox and Martin Hemi Duster
[Re: CUUDAK]
#913376
01/28/11 09:54 AM
01/28/11 09:54 AM
Posts: 142 Maryland
Sick 660r
Maryland
Would there be any problems having the mount come off the frame if I have solid motor mounts? Its not a motor plate.
2000 dakota
418 magnum
paxton novi 2k
T56
[Re: Sick 660r]
#913381
01/28/11 03:31 PM
01/28/11 03:31 PM
CUUDAK
HEMPSTEAD TX
Mine is right behind the passenger side headlight,
[Re: prochargedhemi]
#913384
03/11/11 12:31 AM
03/11/11 12:31 AM
Posts: 142 Maryland
Sick 660r
Maryland
Im finally starting to tack the piping and im wondering what is considered enough clearance for things like the radiator hoses etc. Right now I have about 1" of clearance between the piping going into the turbine flange and my lower rad hose. If everything is wrapped do you think that would be enough?
2000 dakota
418 magnum
paxton novi 2k
T56
[Re: Sick 660r]
#913385
03/11/11 06:07 AM
03/11/11 06:07 AM
HEMIFRED
SOUTH JERSEY
if space permits you could use a braided hose which can be smaller than the rubber and still flow enough.I have -16 in and out of my radiator. another thing with the braided is you might be able to use ends with angles to make the braided hose get routed in a different manner. I had probelms and at one point came from the pump and when down under a frame tube.Then had a 90 degree end on it entering from the below the radiator
[Re: HEMIFRED]
#913386
03/11/11 06:09 AM
03/11/11 06:09 AM
HEMIFRED
SOUTH JERSEY
the top had a very bad angle to deal with because the connection points were too close. The stiffness of braided allowed it to be position and when tightened stay as put
[Re: Sick 660r]
#913390
03/23/11 10:30 PM
03/23/11 10:30 PM
Posts: 468 Dirty Dena, Maryland
dodge turbo
I would put a flex in the cross over pipe in front of the harmonic balancer, it allows expansion and contraction of the pipes. buy the kind without the braided inside
78 Adventurer 150small block turbo'd 360w/Borg S475....smoke'em
