Turbo fabrication tips #913371
01/25/11 12:23 AM
01/25/11 12:23 AM
Maryland
Sick 660r Offline OP
Maryland
Ive done some research but im looking for some tips from those that have cusotm setups. In a few weeks I will be having my setup made by a friend but I dont think he has ever done a turbo setup. He is a welder for a living and he has done work for me in the past so I have no doubt in his ability.
Turbo will be from supernatural. Its a 88mm GT55 with a 1.08 a/r T6 99mm GT47 turbine. I will be using flipped shorties with 1.5" primaries and 2.5" collectors. All hot side piping will be 2.5" 304 SS with v-bands. Exhauset and DP will be 5" aluminum. Wastegate will be a 60mm tial dumped back into the DP and I will have a tial bov as well.
Does anyone have tips on fabricating everything?
thanks
2000 dakota 418 magnum paxton novi 2k T56
Re: Turbo fabrication tips [Re: Sick 660r] #913372
01/27/11 09:48 PM
01/27/11 09:48 PM
HEMPSTEAD TX
CUUDAK Offline
CUUDAK  Offline
HEMPSTEAD TX
Looks like you have everything you need! Just make sure you fab a bracket for the turbo to mount to. This should be mounted to the engine. Don't hang the turbo from the headers. This will reduce the possibility of the headers cracking.
SRT8 CHARGER "Four door bore" <img src="/ubbthreads/images/graemlins/smile.gif" alt="" />
Re: Turbo fabrication tips [Re: Sick 660r] #913373
01/27/11 10:39 PM
01/27/11 10:39 PM
Bama
Randy.. Offline
Randy..  Offline
Bama
you wont need a 5 inch down pipe, 4 will do. and easier to package.
Re: Turbo fabrication tips [Re: Randy..] #913374
01/28/11 02:16 AM
01/28/11 02:16 AM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
don'tb waste time and money building a fancy set of tuned headers. a simple log will take care of all your needs. I made over 1400hp with a set of 179.00 Sandersen street rod block hugger headers.
The twin turbo Hemi just tested on the chassis dyno used plain old simple log headers to produce 2370 RWHP at 28lb boost. I have yet to have anything more complex in design used on any of my turbo builds. Fancy looks nice but not a must that's for sure
here's the main page
http://prostockhemi.com/gallery/turborr2/
my logs
home of the
Sox and Martin Hemi Duster
Re: Turbo fabrication tips [Re: HEMIFRED] #913375
01/28/11 02:19 AM
01/28/11 02:19 AM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
home of the
Re: Turbo fabrication tips [Re: CUUDAK] #913376
01/28/11 09:54 AM
01/28/11 09:54 AM
Maryland
Maryland
Would there be any problems having the mount come off the frame if I have solid motor mounts? Its not a motor plate.
Re: Turbo fabrication tips [Re: Randy..] #913377
01/28/11 09:56 AM
01/28/11 09:56 AM
Maryland
Maryland
There is a ton of room for the exhaust so I thought it would be better to go 5"?
Re: Turbo fabrication tips [Re: HEMIFRED] #913378
01/28/11 09:57 AM
01/28/11 09:57 AM
Maryland
Maryland
my logs
Im just flipping the shorties that came with the truck when I bought it. Not making anything fancy.
Re: Turbo fabrication tips [Re: Sick 660r] #913379
01/28/11 02:47 PM
01/28/11 02:47 PM
HEMPSTEAD TX
CUUDAK Offline
CUUDAK  Offline
HEMPSTEAD TX
I still think it should be mounted to the head or something. Since there is no motor plate anyhow! If you want to mount it to the frame you will need to install a flex joint somewhere before the flange. The bad is these flex joints tend to leak in a short period tho!
Re: Turbo fabrication tips [Re: CUUDAK] #913380
01/28/11 02:55 PM
01/28/11 02:55 PM
Maryland
Maryland
I want to mount it to the head but I want to place the turbo behind the passenger headlight and thats pretty far from the head but right over the frame rail. What about a rubber mount between the brace and the frame? Something like a tranny mount?
Re: Turbo fabrication tips [Re: Sick 660r] #913381
01/28/11 03:31 PM
01/28/11 03:31 PM
HEMPSTEAD TX
CUUDAK Offline
CUUDAK  Offline
HEMPSTEAD TX
Mine is right behind the passenger side headlight,
Re: Turbo fabrication tips [Re: CUUDAK] #913382
01/28/11 06:17 PM
01/28/11 06:17 PM
Maryland
Maryland
I have a quite a bit more space than you and I also wont be running a filter. If I dont figure something out Ill post pics and hopefully get some ideas from others.
Re: Turbo fabrication tips [Re: Sick 660r] #913383
02/07/11 12:49 AM
02/07/11 12:49 AM
Temperance, MI
P
prochargedhemi Offline
P
Temperance, MI
not a mopar but one i just did for a buddy. Biggest tip i can give is take your time and plan it all out ahead of time
I also used his existing shorties with some major modifications
Re: Turbo fabrication tips [Re: prochargedhemi] #913384
03/11/11 12:31 AM
03/11/11 12:31 AM
Maryland
Maryland
Im finally starting to tack the piping and im wondering what is considered enough clearance for things like the radiator hoses etc. Right now I have about 1" of clearance between the piping going into the turbine flange and my lower rad hose. If everything is wrapped do you think that would be enough?
Re: Turbo fabrication tips [Re: Sick 660r] #913385
03/11/11 06:07 AM
03/11/11 06:07 AM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
if space permits you could use a braided hose which can be smaller than the rubber and still flow enough.I have -16 in and out of my radiator. another thing with the braided is you might be able to use ends with angles to make the braided hose get routed in a different manner. I had probelms and at one point came from the pump and when down under a frame tube.Then had a 90 degree end on it entering from the below the radiator
home of the
Re: Turbo fabrication tips [Re: HEMIFRED] #913386
03/11/11 06:09 AM
03/11/11 06:09 AM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
the top had a very bad angle to deal with because the connection points were too close. The stiffness of braided allowed it to be position and when tightened stay as put
home of the
Re: Turbo fabrication tips [Re: HEMIFRED] #913387
03/11/11 09:39 AM
03/11/11 09:39 AM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
My experience is to mount the turbo solid where it fits. The header that is closest to the turbo will be the more difficult of the two as it has be short enough that you can still have room for the collector and a pipe to dump into the turbo. The other side will have a little give, so building that header to match the first makes the most sense In most cases. I refused to remove my fender wells so I was harder on myself than need be.
Re: Turbo fabrication tips [Re: joshking440] #913388
03/11/11 09:42 AM
03/11/11 09:42 AM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
Another view
Re: Turbo fabrication tips [Re: joshking440] #913389
03/15/11 12:45 AM
03/15/11 12:45 AM
Maryland
Maryland
So this is what i have so far. The passenger side will blend in where the 3-2.5" reducer is. I will locate the wastegate on the 90* before the turbo. Does anyone have suggestions or see any issues I may run into?
I did the best I could lining up the 3" pipe but it was complete crap to begin with. I will never order from RPS again.
Re: Turbo fabrication tips [Re: Sick 660r] #913390
03/23/11 10:30 PM
03/23/11 10:30 PM
Dirty Dena, Maryland
dodge turbo Offline
dodge turbo  Offline
I would put a flex in the cross over pipe in front of the harmonic balancer, it allows expansion and contraction of the pipes. buy the kind without the braided inside
78 Adventurer 150small block turbo'd 360w/Borg S475....smoke'em
