Re: Billet Servos 727 [Re: JohnRR] #913057
01/28/11 02:03 PM
01/28/11 02:03 PM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
I was thinking it wont hold the piston square in the bore since most of the pressure is directed to one side.
Re: Billet Servos 727 [Re: Scamp408] #913058
01/28/11 02:41 PM
01/28/11 02:41 PM
NC
440Jim Offline
440Jim  Offline
NC
The stock retainer for the rear servo is very thin, and often gets bent. The kit from mrrandy comes with a much thicker, stronger, retainer.
IMO, I would use the new spring; especially if that is the one from mrrandy. It should be, and apprears from your picture, to be stiffer than the stock one. That should help the band release during the 1-2 shift (low band apply valve bodies).
As far as the trans shop taking the shims out of the servo, that stock configuration will cushion the servo/band apply. And since the stock valve body makes real high pressure going into reverse, and the rear servo gets engaged in reverse, they might be trying to ease that application. This is why it is important to go all the way to idle when putting a torqueflite in reverse. However, in a race application, shimming it solid will improve the servo release during the 1-2 shift.
Re: Billet Servos 727 [Re: 440Jim] #913059
01/28/11 02:47 PM
01/28/11 02:47 PM
organ
maximum entropy Offline
organ
Re: Billet Servos 727 [Re: maximum entropy] #913060
01/28/11 05:13 PM
01/28/11 05:13 PM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
Alright I guess I was just over analyzing things my bad. All I wanted to do was change the fluid now look what I got into .
The springs feel close in tension just one spring is made longer for tension and the other is thicker.
Re: Billet Servos 727 [Re: Scamp408] #913061
01/28/11 05:16 PM
01/28/11 05:16 PM
organ
organ
the shorter spring is a much higher rate, most likely.
Re: Billet Servos 727 [Re: maximum entropy] #913062
01/28/11 06:18 PM
01/28/11 06:18 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The stock spring has an installed pressure of 15 pounds, with 1/2" of piston travel the pressure increases to 33 pounds.
The stiffer spring has an installed pressure of 37 pounds and increases to 77 pounds with 1/2" of travel.
Re: Billet Servos 727 [Re: John_Kunkel] #913063
01/28/11 11:07 PM
01/28/11 11:07 PM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
rear servo is all done and went onto the frt. The band strut was modified and upon closer inspection its starting to bend . Glad I this trans was all went through/rebuilt with manual VB cant shops get anything right.
