2008 Durango Ticking #912595
01/24/11 01:58 PM
01/24/11 01:58 PM
Grandville, Michigan
Dustya440 Offline OP
I have a 2008 Durango. It has the 4.7 with 100,000 miles on it.
When I start it up it always ticks loudly for at least a few minutes, sometimes longer.
It seems to be getting worse but the weather has been extra cold also.
I've read that an exhaust bolt might be broke but I don't see any broken ones.
The truck runs great and I don't really have any other problems with it.
But the ticking seems to be getting worse.
I don't want to keep driving it if I'm hurting it.
Any ideas or thought?
1969 Road Runner J Code 1970 Road Runner VOA 1971 Dart Swinger 1971 Cuda Vert 1973 Duster Pro Street 2003 Z06
Re: 2008 Durango Ticking [Re: Dustya440] #912596
01/24/11 03:27 PM
01/24/11 03:27 PM
Bolingbrook, IL
HemiRunner Offline
super street
HemiRunner  Offline
super street
Bolingbrook, IL
4.7s were notorious for spitting rocker arms due to the lifters seizing up. You may have a lifter starting to go bad.
I have taken several apart where the lifter seized & it broke the rocker & the hole in the head when it jammed everything up. A few others it just spit the rocker out & was able to replace the lifters & it was good to go.
No way of telling for sure until the valve covers are pulled & they are checked. I'd eliminate an exhaust leak first though.
Blown & Injected, need I say more? 71 Road Runner 04 Dodge Ram 2500 4x4 CTD
Re: 2008 Durango Ticking [Re: HemiRunner] #912597
01/24/11 05:09 PM
01/24/11 05:09 PM
Thanks Hemirunner for the responce.
Is there a special tool needed for the rocker arms?
What do I look for when I take the covers off?
I am not familar with the 4.7 at all.
I've been putting a ton of miles on the truck. It sounds like I better be careful.
I'm about 300 miles from home right now.
Anyone else experience this ticking?
Re: 2008 Durango Ticking [Re: Dustya440] #912598
01/24/11 08:31 PM
01/24/11 08:31 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
Give a tug on your exhaust manifold heat shields (when its cold of course) and see if any of the bolts are broke that hold the shield on. They are usually the ones to break. The 4.7 also have valve seats that like to pop out of the head also.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: 2008 Durango Ticking [Re: 71yelladustr] #912599
01/24/11 09:59 PM
01/24/11 09:59 PM
I didn't realize that there were so many issues with the 4.7.
I'll check the shields after I park it in the shop in the morning.
Anyone else?
Re: 2008 Durango Ticking [Re: Dustya440] #912600
01/24/11 10:02 PM
01/24/11 10:02 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
My 4.7 started a very light ticking at 9000 miles at start up.It has 143,000 on it now,so I don't worry about it.
Nautilus Racing-
Re: 2008 Durango Ticking [Re: Dustya440] #912601
01/25/11 01:12 PM
01/25/11 01:12 PM
Bolingbrook, IL
HemiRunner Offline
super street
HemiRunner  Offline
super street
Bolingbrook, IL
Dustya440,
If you find it's not an exhaust leak, pull the valve covers & check all the rockers to make sure there isn't any cracks or broken rockers at the lifter end. Also look at all the lifters, they set in a hole in the head, look for cracks there. The rockers set under the cams & I guess you would call them more followers than rockers.
I have replaced lifters & rockers by loosening the cam stands just enough to get them out. Otherwise you have to disassemble the front of the engine to get the cam chain cover off & remove the chains & remove the cams. If you just loosen the stands, pull the plugs to make it easier to spin the engine by the crank bolt as some times you have to turn it a little to get the rocker out. When tightening the stands back up go a little at a time & snug them up to make sure nothing is binding, then torque them down.
Re: 2008 Durango Ticking [Re: HemiRunner] #912602
01/25/11 03:13 PM
01/25/11 03:13 PM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
The wifes 04 DuranGO, with 4.7, ticks upon cold start. Gots 118k+, runs great. Been doing it for a while now.
Re: 2008 Durango Ticking [Re: HemiRunner] #912603
01/25/11 05:28 PM
01/25/11 05:28 PM
Hemirunner,
Does it matter if my 4.7 is a flex fuel vehicle?
Maybe a dumb question, but are all 4.7's the same cam type?
Thanks again for the info.
Re: 2008 Durango Ticking [Re: Dustya440] #912604
01/25/11 06:44 PM
01/25/11 06:44 PM
Bolingbrook, IL
HemiRunner Offline
super street
HemiRunner  Offline
super street
Bolingbrook, IL
No difference in cam design. The flex fuel only pertains to the fuel system.
