727 fluid level ? #912557
01/24/11 11:44 AM
01/24/11 11:44 AM
Ridley Park, Pa.
69MOPE Offline OP
super gas
69MOPE  Offline OP
super gas
Ridley Park, Pa.
Where is the fluid level on 727's in relation to the case and/or internals. I am adding an aftermarket locking dipstick tube and am trying to get the level figured out. I don't have an original tube to check. I was hoping someone has been thru this already. The measurement i am looking for is how many inches above the pan rail?
Re: 727 fluid level ? [Re: 69MOPE] #912558
01/24/11 12:00 PM
01/24/11 12:00 PM
detroit area
moderncylinder Offline
detroit area
what im told is that the level should be at the place where the dipstick goes,, right at the top,,,,
i was told like if the car was running you could pull the dipstick tube out and what ever spills out didnt need to be in there...
i measured from the dipstick flange to the bottom of the dipstick,, then made a mark up from the bottom of the dipstick at the point
Re: 727 fluid level ? [Re: moderncylinder] #912559
01/24/11 12:19 PM
01/24/11 12:19 PM
ill
dennismopar73 Offline
ill
always remember grass hopper
tranny fluid increases with heat
Re: 727 fluid level ? [Re: 69MOPE] #912560
01/24/11 05:44 PM
01/24/11 05:44 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The FULL mark on the dipstick is about 1/4" above the flat area where the dipstick tube is inserted into the case.
