ERR on a factory CD player #912536
01/24/11 11:12 AM
01/24/11 11:12 AM
Gulf Coast of Florida
Russ Offline OP
super gas
Russ  Offline OP
super gas
I put a CD in,and It says ERR on the face,and spits It back out,anybody know how to fix it,Is there a CD cleaner disc I can use?
2001 Durango 5.9 Magnum 99 Durango 5.9 Magnum Parting out 99 Durango 5.9,99 Ram 1500 and 98 Ram 1500 5.9 WANTED.Ram Truck,Durango/Dakota parts and parts trucks!!PM Me. GO BUCKS!!!! Go GATORS!!!!
Re: ERR on a factory CD player [Re: Russ] #912537
01/24/11 11:24 AM
01/24/11 11:24 AM
Atlanta Indiana
Dave Watt Offline
Dave Watt  Offline
Atlanta Indiana
Are you trying to play a CDR or CDRW? Some disc players won't read them. Try a pre recorded disc to see if it works.
Also, disconnect the battery for 5 minutes, reconnect to see if the ERR clears.
Re: ERR on a factory CD player [Re: Dave Watt] #912538
01/24/11 11:28 AM
01/24/11 11:28 AM
Russ Offline OP
super gas
Russ  Offline OP
super gas
just a regular music CD,I disconnecting the battery,and tried It again,and still comes up ERR.Sometimes when I put a CD In,It just sits In there and does nothing,and I have to hit the eject button to bring It back out.
Re: ERR on a factory CD player [Re: Russ] #912539
01/24/11 01:07 PM
01/24/11 01:07 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
Just that particular CD, or any CD you try?
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: ERR on a factory CD player [Re: GO_Fish] #912540
01/24/11 01:25 PM
01/24/11 01:25 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
You can buy a cd lens cleaner kit at most anywhere that sells CD players. The same kit works on DVD players also.
Re: ERR on a factory CD player [Re: stumpy] #912541
01/24/11 03:47 PM
01/24/11 03:47 PM
S.E.Ohio
Magnumguy Online content
Magnumguy  Online Content
S.E.Ohio
Sometimes if you hit the button to advance the CD to the next song, or backwards to the end, will clear it.
If they're copies, that sometimes gives them fits.
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: ERR on a factory CD player [Re: GO_Fish] #912542
01/24/11 08:39 PM
01/24/11 08:39 PM
Russ Offline OP
super gas
Russ  Offline OP
super gas
I tried 6 different Cds,and all do the same,I put the same CDs In another player,and they worked fine
Re: ERR on a factory CD player [Re: Russ] #912543
01/24/11 09:16 PM
01/24/11 09:16 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Obviously your car does not like your taste in music...
Re: ERR on a factory CD player [Re: Russ] #912544
01/24/11 10:26 PM
01/24/11 10:26 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
Sounds like trying the CD cleaner, and/or blowing some compressed air in there.
The CD would get stuck and not eject on my GF's Ferd Escape. Had to pop the radio out of the dash and put white grease on the moving parts. You could see shiny metal where rubbing was occuring.
Re: ERR on a factory CD player [Re: GO_Fish] #912545
01/24/11 10:50 PM
01/24/11 10:50 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
Russ:
9 times out of 10, a super easy fix:
Pull out the head unit and take the casing apart to gain access to the "eye". Grab some Q-tips, dip them in clear rubbing alcohol and swab the glass lens of the eye. Wipe with lint-free cloth. Worked for me on every CD player I ever had.
However, if you listen to country, NOTHING will improve the music.
Mo' Farts
Moderated by "tbagger".
Re: ERR on a factory CD player [Re: Grizzly] #912546
01/24/11 11:28 PM
01/24/11 11:28 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
The one in the ex-wife's PT Cruiser did that. Chrysler replaced it under warranty.
The way they acted when she took it in, it must have been fairly common.
Re: ERR on a factory CD player [Re: slantzilla] #912547
01/25/11 04:49 AM
01/25/11 04:49 AM
Nevada Iowa
dodgepaul Offline
dodgepaul  Offline
Nevada Iowa
I had the same issue, go to your favorite electronics store and buy a CD/DVD cleaner. Put it in a problem solved.
1970 4spd Superbird, '69 Charger 500 Daytona clone,2015 Hellcat 6-spd B-5 Blue,1968 572 Hemi Charger,70 GTX 535 6-pac 4 spd,69 GTX 440 4-speed Super Trac Pac Car, 1973 383 Barracuda, and a couple Cummins
Re: ERR on a factory CD player [Re: dodgepaul] #912548
01/25/11 10:30 AM
01/25/11 10:30 AM
Russ Offline OP
super gas
Russ  Offline OP
super gas
Thanks for all the tips,I'll go and get a cleaner disc,and If that's doesn't work,i'll take the case apart and clean it
And Oz,just because you listen to the soundtrack of "The March Of The Penguins" Doesn't mean I don't have good taste In music!!
Now where Is my Saturday Night Fever Albumn,I know It's here somewhere!
