can anyone tell me which gasket set for my application? #912158
01/23/11 11:46 PM
01/23/11 11:46 PM
Pittsburgh, PA
bigdaddywiz Offline OP
Pittsburgh, PA
i'm in the process of putting an intake and a 4bbl carb off a 340 onto my 318 in my road runner. after searching advance auto's site, there are like 10 different gasket and sets to choose from for 340s. can someone make it easy for me and point me to the exact part that will fit for what i'm trying to do? if possible, a part number so i can just pick it up at my local advance auto or pep boys or whatever.
i already have the carb rebuild kit, just need the manifold gaskets.
thanks!
73 Road Runner 09 Challenger R/T
Re: can anyone tell me which gasket set for my application? [Re: bigdaddywiz] #912159
01/24/11 12:40 AM
01/24/11 12:40 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
You need the 1975 318 set. It is a 318 engine you are working on.
Re: can anyone tell me which gasket set for my application? [Re: stumpy] #912160
01/24/11 12:59 AM
01/24/11 12:59 AM
Pittsburgh, PA
Pittsburgh, PA
oh, ok..i was under the impression i had to get a set for a 340 to match up with the manifold?
..this is my first engine project just so you know..
thanks!
Re: can anyone tell me which gasket set for my application? [Re: bigdaddywiz] #912161
01/24/11 01:28 AM
01/24/11 01:28 AM
md
mopars4ever Offline
mopars4ever  Offline
md
whenever i put a 340 intake on a 318 i always used the paper type 340 intake gaskets IIRC they were MR Gasket brand
Re: can anyone tell me which gasket set for my application? [Re: mopars4ever] #912162
01/24/11 01:49 AM
01/24/11 01:49 AM
Pittsburgh, PA
Pittsburgh, PA
well, after doing some searching on summits site, i'm guessing i should use the 307G? the 306G comes up if i search for it on advance auto.
http://www.summitracing.com/compare.aspx
Re: can anyone tell me which gasket set for my application? [Re: bigdaddywiz] #912163
01/26/11 02:59 AM
01/26/11 02:59 AM
Pittsburgh, PA
Pittsburgh, PA
edit. new links...
http://www.summitracing.com/search/?keyword=307g&dds=1
and
http://www.summitracing.com/search/?keyword=306g&dds=1
so which one?
thanks
Re: can anyone tell me which gasket set for my application? [Re: bigdaddywiz] #912164
01/26/11 01:14 PM
01/26/11 01:14 PM
md
mopars4ever Offline
mopars4ever  Offline
md
IIRC, I used the 307 but it appears either one will work.
