383man, AC question ???
#91178
07/20/08 11:18 AM
07/20/08 11:18 AM
Posts: 2,535 God's Country Maryland
GODSCOUNTRY340
My '02 Diesel Ram now doesn't like to hold an A/C charge. Where should I look for the problem? While I'm talking of A/Cs, my '98 Concorde has the same problem. People in my area tell me it's likely leaking under the dash, it only holds a charge for ONE day. My Son's '98 Ram leaks out after a month, my old Neon would only hold a charge for around 2 months and now that I think about it my '94 Spirit leaked all the time. WHAT IS IT WITH MOPAR AIR CONDITIONERS ???? Thanks, How's your back doing? I hope better that my A/Cs are doing.
Re: 383man, AC question ???
[Re: GODSCOUNTRY340]
#91179
07/20/08 11:38 AM
07/20/08 11:38 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
We had a good bit of evaporator problems but that dont mean yours is leaking. Have the system charged and dye tested to make sure there is no leaks anywhere else in the system. Also sometimes if the evaporator leaks you can see comp oil in the drain tube if it's a bad leak. But like I said test the rest of the system first as I have had O-rings and lines leak also. Ron
