Valve Cover Breather Location
#911712
01/23/11 06:18 PM
01/23/11 06:18 PM
Posts: 121 Michigan
dusterjp
I am considering replacing my stock valve covers with aluminum on my 340. I was told by my engine builder to get rid of my pcv valve and put a breather in it's place so there is one on each side of the engine. Not sure which ones I am going to get yet, but after looking around at pictures I noticed that all the aftermarket aluminum valve covers have the breathers in opposite corners (kiddie corener) from one another. Is there a reason for this (perfomance or mechanical related), or is it just the way most aftermarket valve covers come. I was considering having the breather cut outs cut directly in the center of the length of the cover. The factory covers have them in the center so I can't see a reason why it should be a problem. All advice and pics is appreciated.
