Keith Black oil pumps #911707
01/23/11 06:08 PM
01/23/11 06:08 PM
Munich, Bavaria
docford Offline OP
docford  Offline OP
Munich, Bavaria
I'm looking for a pressure oil pump for my roadrace HEMI. It now has some intriguing NASCAR pump from the early 70s and I never found anything like that in any catalog. This HEMI 426 engine has an internal scavenge pump with a -16 exit that feeds a dry sump tank. Idealy the pressure pump should have a -16 or at least -12 inlet and two -10 connectors for the oil cooler. It need to be driven of the regular MOPAR big block oil pump shaft. Do you think that a Keith Black oil pump would do that ? Do you have other suggestions ?
Re: Keith Black oil pumps [Re: docford] #911708
01/24/11 02:55 AM
01/24/11 02:55 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Is it the one with the chain off the crank that drive the pump. I think the cranks are special for those.
Re: Keith Black oil pumps [Re: autoxcuda] #911709
01/24/11 02:57 AM
01/24/11 02:57 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Pic of the front section of the pan.... There's picture of the setup in the 74 Petty Racing Part Catalog.
Re: Keith Black oil pumps [Re: autoxcuda] #911710
01/24/11 03:02 AM
01/24/11 03:02 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Might want to contact Milodon.
They have a 100% new bolt on big block oil pump with better gear design than stock. They have been displayed the winter racing shows, but I don't think they are quite on the market yet from what they said.
Re: Keith Black oil pumps [Re: autoxcuda] #911711
01/24/11 04:26 AM
01/24/11 04:26 AM
Hinterland SE Qld Aust
SG duster Offline
SG duster  Offline
Im sure he is taking about one of these... ajustable pressure up to 120psi at 7500rpm,
