Changing Plugs #911515
01/23/11 02:15 PM
01/23/11 02:15 PM
Woodstock , Georgia
Mopar_racer_99 Offline OP
Woodstock , Georgia
Hey guys, what is everyone using as spark plugs go, with 5/8 socket, we are running accel 111 but being a 7/8 socket, I am having hard time with plug changes with the headers. Indy 440-1 heads 578 ci 14-1 comp, running on alcohol.
PS. dont send me to the spark plug web page they dont cross reference accel over to 5/8 plugs. THanks John
8.72 @ 154.6 ,68 Charger 578ci 440-1s, 3000# w/drvr, 2150 den/alt NA
Re: Changing Plugs [Re: Mopar_racer_99] #911516
01/23/11 03:14 PM
01/23/11 03:14 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
NGK part # 5258
home of the
Sox and Martin Hemi Duster
Re: Changing Plugs [Re: Mopar_racer_99] #911517
01/23/11 03:14 PM
01/23/11 03:14 PM
I have used Autolite 3910 successfully in a 14.7 to 1 comp. ratio N/A gas motor. See if you can use them, they have extended tips A NGK # 9 or 10 with thge tip type you want should work also
Re: Changing Plugs [Re: Cab_Burge] #911518
01/23/11 03:16 PM
01/23/11 03:16 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
NGK here as well. Part number is gonna depend on combo but they are all 5/8"
