What Stall Speed Converter
#911502
01/23/11 01:40 PM
01/23/11 01:40 PM
Posts: 1,534 Florida
CHRGR69
69 Charger 440 auto (727) stock. Need to change torque converter. Don't know where to start as far as stall speed.
Grandma always said I had "hands of gold"!
Re: What Stall Speed Converter
[Re: CHRGR69]
#911504
01/25/11 06:17 PM
01/25/11 06:17 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
We need alot more details...
Cam, compression, heads, intake, carb, weight, gear. etc.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
[Re: west]
#911506
01/25/11 06:59 PM
01/25/11 06:59 PM
Von
NE Oklahoma
call the after market company you want to buy from. they will set you up.
Partially true. Depending on what company you call you might end up with something very wrong.
[Re: Von]
#911507
01/26/11 07:03 PM
01/26/11 07:03 PM
Posts: 179 Up in the North and Far Away
AutoEngineer
Sorry, not hijack your question, but having also a 1969 Charger with 440 and wondering what might be a good choice for it too?
Current set up is Comp Cams XE284H with 1.6 ratio rockers, 9.8:1 compression, 440Source heads, Eddy RPM intake, 850 cfm BG with mech. secondaries, 4050 lbs with driver, 3.73 gears, 275/60-15 M/T's.
What would be your recommendation?
[Re: AutoEngineer]
#911508
01/26/11 07:11 PM
01/26/11 07:11 PM
Posts: 1,213 Los Angeles, CA
Mobarge
Los Angeles, CA
Based on that, I'd say a 10 inch converter, between 2,800 - 3,200 RPM stall.
'71 SSP - SOLD!
