What Stall Speed Converter #911502
01/23/11 01:40 PM
01/23/11 01:40 PM
CHRGR69 Offline OP
CHRGR69  Offline OP
69 Charger 440 auto (727) stock. Need to change torque converter. Don't know where to start as far as stall speed.
Grandma always said I had "hands of gold"!
Re: What Stall Speed Converter [Re: CHRGR69] #911503
01/23/11 01:45 PM
01/23/11 01:45 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
It depends on what you plan to do with the car? If you are mainly using it for a daily driver then just go back with a stock convertor.
Re: What Stall Speed Converter [Re: CHRGR69] #911504
01/25/11 06:17 PM
01/25/11 06:17 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
We need alot more details...
Cam, compression, heads, intake, carb, weight, gear. etc.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: What Stall Speed Converter [Re: Von] #911505
01/25/11 06:27 PM
01/25/11 06:27 PM
petaluma,ca. u.s.a.
west Offline
west  Offline
petaluma,ca. u.s.a.
go with stock or call the after market company you want to buy from. they will set you up.
Re: What Stall Speed Converter [Re: west] #911506
01/25/11 06:59 PM
01/25/11 06:59 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
Partially true. Depending on what company you call you might end up with something very wrong.
Re: What Stall Speed Converter [Re: Von] #911507
01/26/11 07:03 PM
01/26/11 07:03 PM
Up in the North and Far Away
AutoEngineer Offline
Sorry, not hijack your question, but having also a 1969 Charger with 440 and wondering what might be a good choice for it too?
Current set up is Comp Cams XE284H with 1.6 ratio rockers, 9.8:1 compression, 440Source heads, Eddy RPM intake, 850 cfm BG with mech. secondaries, 4050 lbs with driver, 3.73 gears, 275/60-15 M/T's.
What would be your recommendation?
Re: What Stall Speed Converter [Re: AutoEngineer] #911508
01/26/11 07:11 PM
01/26/11 07:11 PM
Los Angeles, CA
Mobarge Offline
Mobarge  Offline
Los Angeles, CA
Based on that, I'd say a 10 inch converter, between 2,800 - 3,200 RPM stall.
'71 SSP - SOLD!
