Master Cylinder question Race Brakes only #910943
01/22/11 08:15 PM
01/22/11 08:15 PM
Out West
408strokerdart Offline OP
Out West
Ok, having recently relocated my master cylinder under the floor I am re-plumbing the brake system. Just want to make sure I have it the best way possible. What master cylinder port do you use for the front/rear brakes? I know there is some proportioning built into the master cylinder, but I am talking big rear tire drag only use. I will be plumbing in an adjustable valve as well, so where should it go.....front brake line or rear brake line? BTW, Chrysler 1 1/8" bore master cylinder with 4 wheel disc brakes.
Re: Master Cylinder question Race Brakes only [Re: 408strokerdart] #910944
01/22/11 08:33 PM
01/22/11 08:33 PM
MI
68shifter Offline
68shifter  Offline
MI
I just went through that on mine. Wilwood said front to front and rear to rear and then I had to use a residual pressure valve in the front side, so far so good.
Love the car and chassis pics by the way
68' Barracuda (4 speed) 64' Savoy (4 speed) 65' Satellite (girl tranny)
Re: Master Cylinder question Race Brakes only [Re: 68shifter] #910945
01/22/11 08:36 PM
01/22/11 08:36 PM
Out West
Out West
Thanks. That is the way I had them before, but just wanted to make sure that was the recommendation of others here.
Re: Master Cylinder question Race Brakes only [Re: 408strokerdart] #910946
01/22/11 09:03 PM
01/22/11 09:03 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
Wilwood master's are that way but strange masters are opposite. I have my mopar one with the outlet closest to the mounting flange to the front brakes. No adjustable valves on my cars.
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Master Cylinder question Race Brakes only [Re: bigtimeauto] #910947
01/22/11 09:07 PM
01/22/11 09:07 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
10 lb residual valve mandatory
home of the
Sox and Martin Hemi Duster
Re: Master Cylinder question Race Brakes only [Re: HEMIFRED] #910948
01/22/11 09:09 PM
01/22/11 09:09 PM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
You probably missed it but we already covered that in another thread. But for disc brakes its 2lb.
Re: Master Cylinder question Race Brakes only [Re: bigtimeauto] #910949
01/22/11 09:12 PM
01/22/11 09:12 PM
Q
Quicktree Offline
Quicktree  Offline
Q
10 is to much.
Re: Master Cylinder question Race Brakes only [Re: Quicktree] #910950
01/22/11 09:21 PM
01/22/11 09:21 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
brian pm i have a bran new 2lb willwood
Re: Master Cylinder question Race Brakes only [Re: Quicktree] #910951
01/22/11 09:21 PM
01/22/11 09:21 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
10 lb is for drum brakes
Re: Master Cylinder question Race Brakes only [Re: Quicktree] #910952
01/22/11 09:22 PM
01/22/11 09:22 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
10 is to much.
sorry 2 is correct I am a bit rusty
home of the
Re: Master Cylinder question Race Brakes only [Re: HEMIFRED] #910953
01/22/11 10:21 PM
01/22/11 10:21 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
According to Strange, both outlet port's supply the same pressure, and the outlet port nearest the pushrod supplies the most fluid volume,, typically a drag car has the largest calipers on the rear, while a street driven car has the larget calipers on the front, attach lines accordingly,.
Re: Master Cylinder question Race Brakes only [Re: dartman366] #910954
01/23/11 12:42 AM
01/23/11 12:42 AM
Out West
Out West
I already have the 2 lb residual valves. I should have been more specific though, I use the mopar master cylinders. Not Wilwood or Strange.
Re: Master Cylinder question Race Brakes only [Re: 408strokerdart] #910955
01/23/11 01:16 AM
01/23/11 01:16 AM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
Mine is front MC port to rear brakes with the adj proportining valve to the rear brakes.
Brian Dunnigan
Re: Master Cylinder question Race Brakes only [Re: bigtimeauto] #910956
01/23/11 01:41 PM
01/23/11 01:41 PM
Out West
Out West
That would make sense with the built in proportioning to run the front port to the back tires and the rear port to the front wheels. I might still put in my adjustable valve going to the rear brakes. Would this make sense?
Re: Master Cylinder question Race Brakes only [Re: 408strokerdart] #910957
01/23/11 02:14 PM
01/23/11 02:14 PM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
not to me it wouldn't. If i was going to put one in a drag car it would be in the front line.
Re: Master Cylinder question Race Brakes only [Re: bigtimeauto] #910958
01/23/11 02:54 PM
01/23/11 02:54 PM
Out West
Out West
Is the proportioning valve simply a flow restrictor? It doesn't change the pressure if I remember correctly. So it would only make sense to place it in the line/port that has the highest volume from the master cylinder. In the case of the Mopar brand unit, this is the front port that you have going to the rear brakes....is this right? I'm not wanting to make this more complicated than it needs to be, just trying to wrap my mind around it.
Re: Master Cylinder question Race Brakes only [Re: 408strokerdart] #910959
01/23/11 06:45 PM
01/23/11 06:45 PM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
it is a flow restricter only on a spike so if i felt inclined to add one to a drag car it would be on the front skinny tires not the bigger sticky ones.
Re: Master Cylinder question Race Brakes only [Re: bigtimeauto] #910960
01/23/11 06:54 PM
01/23/11 06:54 PM
Out West
Out West
Ok, that makes more sense to me. Might as well not even be there then.
Is the primary port (on a mopar brand unit) the one closest to the mounting flange?
Re: Master Cylinder question Race Brakes only [Re: 408strokerdart] #910961
01/23/11 07:31 PM
01/23/11 07:31 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Primary port? The big reservoir is for disc brakes
in a production car... if it were me and running
4 wheel disc I would run the rear (nearest the flange)
to the rears and run the front to the fronts
with the prop valve on the fronts... the only reason
I'm saying rear reservoir to the rears is you will
be about the same volume to any of the calipers ...
I have mine hooked up just the old disc/drum way
and then changed to rear disc but left the lines
the same way
Re: Master Cylinder question Race Brakes only [Re: 408strokerdart] #910962
01/23/11 07:40 PM
01/23/11 07:40 PM
Q
Quicktree Offline
Quicktree  Offline
Q
I have never run one on any 4 wheel disc brake set up...
