Master Cylinder question Race Brakes only
#910943
01/22/11 08:15 PM
01/22/11 08:15 PM
Posts: 3,456 Out West
408strokerdart
Out West
Ok, having recently relocated my master cylinder under the floor I am re-plumbing the brake system. Just want to make sure I have it the best way possible. What master cylinder port do you use for the front/rear brakes? I know there is some proportioning built into the master cylinder, but I am talking big rear tire drag only use. I will be plumbing in an adjustable valve as well, so where should it go.....front brake line or rear brake line? BTW, Chrysler 1 1/8" bore master cylinder with 4 wheel disc brakes.
Re: Master Cylinder question Race Brakes only
[Re: 408strokerdart]
#910944
01/22/11 08:33 PM
01/22/11 08:33 PM
Posts: 1,169 MI
68shifter
MI
I just went through that on mine. Wilwood said front to front and rear to rear and then I had to use a residual pressure valve in the front side, so far so good. Love the car and chassis pics by the way
68' Barracuda (4 speed)
64' Savoy (4 speed)
65' Satellite (girl tranny)
[Re: 68shifter]
#910945
01/22/11 08:36 PM
01/22/11 08:36 PM
408strokerdart
Out West
Thanks. That is the way I had them before, but just wanted to make sure that was the recommendation of others here.
#910946
01/22/11 09:03 PM
01/22/11 09:03 PM
Posts: 2,646 Plymouth Meeting, PA
bigtimeauto
Trophy Winner
Trophy Winner
Wilwood master's are that way but strange masters are opposite. I have my mopar one with the outlet closest to the mounting flange to the front brakes. No adjustable valves on my cars.
BB, TT5,Procharged 3300lb Street Car 4.79/154
[Re: bigtimeauto]
#910947
01/22/11 09:07 PM
01/22/11 09:07 PM
Posts: 3,502 SOUTH JERSEY
HEMIFRED
SOUTH JERSEY
10 lb residual valve mandatory
home of the Sox and Martin Hemi Duster
[Re: bigtimeauto]
#910949
01/22/11 09:12 PM
01/22/11 09:12 PM
Quicktree
You probably missed it but we already covered that in another thread. But for disc brakes its 2lb.
10 is to much.
[Re: HEMIFRED]
#910953
01/22/11 10:21 PM
01/22/11 10:21 PM
dartman366
Mt. Vernon, Ohio
According to Strange, both outlet port's supply the same pressure, and the outlet port nearest the pushrod supplies the most fluid volume,, typically a drag car has the largest calipers on the rear, while a street driven car has the larget calipers on the front, attach lines accordingly,.
[Re: bigtimeauto]
#910956
01/23/11 01:41 PM
01/23/11 01:41 PM
408strokerdart
Out West
That would make sense with the built in proportioning to run the front port to the back tires and the rear port to the front wheels. I might still put in my adjustable valve going to the rear brakes. Would this make sense?
#910957
01/23/11 02:14 PM
01/23/11 02:14 PM
bigtimeauto
Trophy Winner
Trophy Winner
not to me it wouldn't. If i was going to put one in a drag car it would be in the front line.
[Re: bigtimeauto]
#910958
01/23/11 02:54 PM
01/23/11 02:54 PM
408strokerdart
Out West
Is the proportioning valve simply a flow restrictor? It doesn't change the pressure if I remember correctly. So it would only make sense to place it in the line/port that has the highest volume from the master cylinder. In the case of the Mopar brand unit, this is the front port that you have going to the rear brakes....is this right? I'm not wanting to make this more complicated than it needs to be, just trying to wrap my mind around it.
#910959
01/23/11 06:45 PM
01/23/11 06:45 PM
bigtimeauto
Trophy Winner
Trophy Winner
it is a flow restricter only on a spike so if i felt inclined to add one to a drag car it would be on the front skinny tires not the bigger sticky ones.
[Re: bigtimeauto]
#910960
01/23/11 06:54 PM
01/23/11 06:54 PM
408strokerdart
Out West
Ok, that makes more sense to me. Might as well not even be there then.
Is the primary port (on a mopar brand unit) the one closest to the mounting flange?
#910961
01/23/11 07:31 PM
01/23/11 07:31 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Primary port? The big reservoir is for disc brakes in a production car... if it were me and running 4 wheel disc I would run the rear (nearest the flange) to the rears and run the front to the fronts with the prop valve on the fronts... the only reason I'm saying rear reservoir to the rears is you will be about the same volume to any of the calipers ... I have mine hooked up just the old disc/drum way and then changed to rear disc but left the lines the same way
#910962
01/23/11 07:40 PM
01/23/11 07:40 PM
Quicktree
I have never run one on any 4 wheel disc brake set up...
