trw piston? #910695
01/22/11 02:34 PM
01/22/11 02:34 PM
okla.
sam64 Offline OP
sam64  Offline OP
okla.
i have set of trw l2295's that were in a motor i bought,upon intial run in a crack appeared in a cylinder.i need piston wall clearance and where on those pistons to measure them so i can have a block bored.thanks,sam.
Re: trw piston? [Re: sam64] #910696
01/22/11 03:14 PM
01/22/11 03:14 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
maybe it's just because it's early morning here & i'm not seeing/thinking straight, but what are you asking? i understand you have a cracked cylinder but after that i'm lost.
Re: trw piston? [Re: sam64] #910697
01/22/11 03:28 PM
01/22/11 03:28 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Sam,
That piston will be -.005 clearance in a standard application.
You measure at the centerline of the pin for proper piston diamter.
RIP Monte Smith
Re: trw piston? [Re: CompWedgeEngines] #910698
01/22/11 03:40 PM
01/22/11 03:40 PM
SW Ohio
AAR-B4 Offline
AAR-B4  Offline
SW Ohio
Sam,
Measure across the skirt at the bottom. Pistons skirts are typically tapered and elliptical.
Correct me if I'm wrong.
Re: trw piston? [Re: AAR-B4] #910699
01/22/11 03:51 PM
01/22/11 03:51 PM
Syracuse,NY
Syracuse,NY
That is incorrect ( for these pistons). TRW skirt design is different than many " modern" skirts. Every manufacter specs a different measurement location. TRW happnes to be from the centerline of the pin, down, just below the pin hole. Not the skirt.
If they are a coated TRW, then you go with a given bore dimension,provided by them, not an actual measurement.
RIP Monte Smith
Re: trw piston? [Re: CompWedgeEngines] #910700
01/22/11 07:53 PM
01/22/11 07:53 PM
okla.
sam64 Offline OP
sam64  Offline OP
okla.
c.w. thanks they are not coated,rebel,when you wake up its says so i can get a block bored[as in another one thats not cracked] .
