I've Gone and Done It... Six Pack #909961
01/20/11 10:06 PM
01/20/11 10:06 PM
Los Angeles, CA
Mobarge Offline OP
Mobarge  Offline OP
Los Angeles, CA
After years of hemming and hawing about it, I've finally gone and done it - I bought a Six Pack setup for my RB.
I know that the modern four barrels can generate about the same HP within 10 - 20, and the six packs can be a pain to tune, but... it's a six pack.
I've been reading a lot about the ProMax metering blocks and the jet plates and the throttle bases... the question I have is, are these worth it? Want to her from guys who have run both stock six pack setups, and those with the ProMax upgrades.
'71 SSP - SOLD!
Re: I've Gone and Done It... Six Pack [Re: Mobarge] #909962
01/20/11 10:08 PM
01/20/11 10:08 PM
SK,Canada
gregsrt Offline
gregsrt  Offline
SK,Canada
I just bought a set up 30 minutes ago, too. Did you go new or used? I found a decent set on the bag.
An association of men who will not quarrel with one another is a thing which has never yet existed, from the greatest confederacy of nations down to a town meeting or a vestry. Thomas Jefferson
Re: I've Gone and Done It... Six Pack [Re: gregsrt] #909963
01/20/11 10:10 PM
01/20/11 10:10 PM
Los Angeles, CA
Mobarge Offline OP
Mobarge  Offline OP
Los Angeles, CA
Used.
'71 SSP - SOLD!
Re: I've Gone and Done It... Six Pack [Re: Mobarge] #909964
01/20/11 10:21 PM
01/20/11 10:21 PM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
I am running the Promax stuff and I say yes there worth it. I had to do alot of monkeying around with my carbs before the Promax stuff. The jettable plates makes it alot easier. You don't have to drill the stock plates which can lead you to drill too much. The base plates are great because you can get a small flexible screw driver and adjust the rear carb.
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: I've Gone and Done It... Six Pack [Re: 70sixpkrt] #909965
01/20/11 10:28 PM
01/20/11 10:28 PM
gtx69 Offline
super gas
gtx69  Offline
super gas
I'm using all the promax upgrades.Easy to adjust the carbs.
Re: I've Gone and Done It... Six Pack [Re: gtx69] #909966
01/20/11 10:35 PM
01/20/11 10:35 PM
gtx69 Offline
super gas
gtx69  Offline
super gas
Pic
Re: I've Gone and Done It... Six Pack [Re: gtx69] #909967
01/20/11 11:19 PM
01/20/11 11:19 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
no pro-max's here. Carbs are tunable just as your old 4bbl. Looking forward to getting some track time this year. I did jump up to 70's, went with the purple springs and I'll probably have to jump up a few on the squirters. Haven't tried the new engine yet...this is the old unit...before Stage VI heads solid roller and Meth injection aren't they pretty?
Coming soon!!!!
Re: I've Gone and Done It... Six Pack [Re: Mr.Yuck] #909968
01/20/11 11:37 PM
01/20/11 11:37 PM
Northern NJ
StukaJU87 Offline
StukaJU87  Offline
Northern NJ
Eventually, I want to put a 6 Pack on my wagon but I have so much other stuff to do that it's way premature to drop the cash now for the set up.
Scott
1969 Super Bee, 383/4 speed
Re: I've Gone and Done It... Six Pack [Re: Mr.Yuck] #909969
01/21/11 04:49 AM
01/21/11 04:49 AM
Illinois, Indiana, Louisiana
ProStDodge Offline
ProStDodge  Offline
OK, so you are jetting up the center carb, which is the one you idle and cruise on. Why would you not want to have the same adjustability on the outboard carbs which are the the ones which will open on wide open passes? Trying to compensate for the outboard carbs with larger jets in the center carb will tend to lean out the front and rear cylinders, but still foul plugs around town.
Re: I've Gone and Done It... Six Pack [Re: Mobarge] #909970
01/21/11 12:16 PM
01/21/11 12:16 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
If it were me, i'd give Ben at Promax a call, send the carbs to them and have them "work" on them, especially if they are used. Money well spent in my book, but you can do it yourself too if you want to save some dough, are logical & methodical.
Non-stick carb gaskets, proper float levels, the correct initial & total timing & advance curve in your dizzy help tremendously!
There are some great posts about setting them up on this board, but this search engine makes it a challenge to find them sometimes.
Re: I've Gone and Done It... Six Pack [Re: Mobarge] #909971
01/21/11 12:20 PM
01/21/11 12:20 PM
Houston, Tx
hemi68charger Offline
Houston, Tx
I have had a six pack on many of my 440 cars for over 25 years now. I love them. They do require vacuum. Depending on your camshaft, timing, etc, they are great. If your RB is produces adequate vacuum levels at idle, leave them stock and just put it on and enjoy...
Here's the six pack I just fired up yesterday as a matter of fact.. It's on my 440 that's totally OEM inside.
http://www.youtube.com/watch?v=JqCKWRo1V0s
Troy
Houston Mopar Connection Club
Re: I've Gone and Done It... Six Pack [Re: ProStDodge] #909972
01/21/11 12:22 PM
01/21/11 12:22 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
because they are very expensive and I can drill mine out when/if needed. The old set-up ran great w/ the stock units. I'll probably have to do some tweaking w/ the new set-up. Might need to swap out the PV as well. Stock jets are what 66? 70 isn't much considering you'd run 76-80 in a mild 440-4 bll car.
Re: I've Gone and Done It... Six Pack [Re: Mobarge] #909973
01/21/11 12:32 PM
01/21/11 12:32 PM
texas
W
Warrant_Officer Offline
W
texas
FYI..I was no 6-pack expert, but I solved days of unsuccessful tuning of my 6-pack with a ProMax metering block and plates..have not touched it it since..
Al
Re: I've Gone and Done It... Six Pack [Re: Warrant_Officer] #909974
01/21/11 12:42 PM
01/21/11 12:42 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
And if you're going to change plates and blocks,Quick Fuel Technology has a better design.
Re: I've Gone and Done It... Six Pack [Re: Mobarge] #909975
01/21/11 03:48 PM
01/21/11 03:48 PM
Bel Air Maryland USA 21014
wmwalden Offline
wmwalden  Offline
I just put this post on the site.
The info is what I have used when I got started.
https://board.moparts.org/ubbthreads/show...ID=#Post6430822
Re: I've Gone and Done It... Six Pack [Re: wmwalden] #909976
01/21/11 05:51 PM
01/21/11 05:51 PM
Harrisburg, Pa.
screamindriver Online content
screamindriver  Online Content
Harrisburg, Pa.
I've used the promax parts before...If you're at the stock level or a touch above you really don't need to spend the money...But it's a no brainer when you've got a hot engine and you need to take it to the next level of tuning...The bases are great for tweaking on the car but how often will you need to turn the screws on the secondaries after the initial set-up??? The secondary metering plates are a nice upgrade for easy tuning...And lastly, the metering block is a nice piece with a performance idle circuit that solves alot of the problems associated with a wild cam...You'll need to give Ben the engine specs for him to make sure the metering block is set up for your application....Keep in mind that billet piece does'nt have a provision for the vacuum advance if that's a concern for anyone....One thing I've never heard anyone talk about is Ben's HP style fuel bowls...They're a high luster piece with a glass sight so you can see what's going on in there...I've used those before and they're a great addition if the stock look is'nt a concern...
Re: I've Gone and Done It... Six Pack [Re: Mr.Yuck] #909977
01/21/11 09:14 PM
01/21/11 09:14 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
The factory jetting is surprisingly close. I think factory center is 62 or 63. I've run them on stock ish 383 to roller cam 512's, with either track or dyno tuning. The highest center jet I've used are 65s.
Re: I've Gone and Done It... Six Pack [Re: BSB67] #909978
01/21/11 09:52 PM
01/21/11 09:52 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
can't recall what I pulled out of them I think they were 64-66's? I had 68's in it for the last cam/cpmbo (548/540 solid) Ran killer and not "gasey" at all. Outboards were stock w/ stock vaccuum springs. It did have a slight stumble if you goose it from 3k but from a dead stop it was lights out, especially when the Meth was on. I jumped up to 70's becuase this combo has more cam, more compression and much better heads. But you are right...I've had several friends run 11's in heavy b-bodys w/ almost stock units.
Re: I've Gone and Done It... Six Pack [Re: Mr.Yuck] #909979
01/22/11 12:00 AM
01/22/11 12:00 AM
Near Reading PA USA
pinkduster Offline
pinkduster  Offline
Near Reading PA USA
That's where I'm at now. I'd like to get the Promax parts for this season and see if I can pick up at all.
Re: I've Gone and Done It... Six Pack [Re: pinkduster] #909980
01/22/11 09:28 AM
01/22/11 09:28 AM
Answering the call of the wild
ThermoQuad Offline
ThermoQuad  Offline
I believe everyone has a computer so I suggest this gets copied to a file....
Attachment is a word doc.
Here is a guide to tune six packs for street engines. Revised 01-2011
Stroker or non stroker, big block or small block.
Never the final word, but close enough for now, it gets updated from time to time.
This is not for the faint of heart. If you wondered why people shy away from six paks just read on.
I have compiled and rewritten the info contained from within along with my own experience from driving a six pak car with a lot of wow! for many years.
When tuned properly Six pak cars turn on! faster & run far better than single 4 barrel cars. If you want your six pak car to run like it should do the dance and have the right tools to make it happen. Patience must be used throughout the process. Much of the information here can be used on a 4 barrel as well.
Things to Remember
Six pak engines run on the center carb and idle on all 3
The car must idle and run/drive like a normal car before attempting any secondary action or wide open throttle passes.
Six paks do not open when you whack the throttle in neutral!!!
Gasoline is flammable and will burn you.
A good vacuum gage, quality tach in the car and dial back timing light/digital tach [snap on timing light with numeric readout].
A good ignition system. MSD, Mallory or FBO mopar box, NO orange boxes or chrome boxes unless you know for sure it is early 80’s vintage. Anything made after 1988 is questionable.
Quality distributor cap & rotor
Firecore spark plug wires
Spark plugs of the proper heat range. Clean and gapped
0.040 mopar box
0.050 msd cd type ignition
Vacuum adv distributor with heavy enough springs to hold advance until 1200 rpm.
The distributor phasing has been checked and corrected as necessary
THIS IS IMPORTANT
Distributor vacuum port on carb disconnected and plugged at carb
Mopar viscous fan package
ATTENTION -195 degree thermostat- ATTENTION
THIS IS IMPORTANT
60%water-40% coolant with a bottle of water wetter
Pay attention here: If you run a lower temp thermostat, raw fuel will collect in the intake. That fuel burns off in the cruise mode and the air-fuel mixture goes lean.
This is transparent unless the a-f ratio is being monitored with a wideband a-f meter
There will be problems getting it to idle and drivability.
Make sure the timing is 15 - 18 deg btdc [advance] at idle. THIS IS IMPORTANT
Set the timing marks at 15 btdc and align the rotor with the cap-this is one reason the phasing was checked.
Car in neutral-auto or 4 sp, emergency brake set.
A good quality vacuum gage is required
Connect vacuum gauge to direct manifold vacuum source.
The heat crossover should be blocked on big & small blocks
Note: in temps below 40 degree it will take a good while to get the car warmed up. Block heaters will eliminate the long warm ups.
Automatic cars: be sure there is enough stall in the torque converter or the car may be a real pig idling in gear and have poor get-up & go.
Beware of mopar orange ignition control boxes that retard the timing etc. Orange boxes built after 1988 tend to have isues.
Preparation:
Outboards: Remove the lead plugs and set the screws 1/8 turn out
Set the outboards idle adj screws out 1/8 turn ccw THIS IS IMPORTANT
Be careful when seating the idle screws to set them, gently is the word
Install the BLACK springs – Just do it, ignore everything else you have read.
Yes I repeated that, explained way below
I you have the jetable metering plates, If so read their instructions and follow them.
Center carb
Set the center carb idle adjustment screws at 1.5 turns out [ccw] THIS IS IMPORTANT
Be sure to adjust the idle screw until the throttle blades are closed and the transfer slot is exposed no larger than a square. [Carb will have to be off the car to see this] You only want about .040" of the transfer slots exposed below the throttle plates. If the idle screw is adjusted too high, you will be into the transition circuit, exposing too much of the vertical rectangular slot. Many times the idle screw is adjusted incorrectly to compensate for other issues. This puts the carb into the transition circuit and at that point you have no mixture control on the center carb.
If you have new carbs(untouched) they will have 62 jets in the center carb & a 6.5hg power valve. Starting point jetting stock 340 use 62’s, highly modified or stroker use 64’s, big blocks start with 64. stroker 65
You must know what power valve is in the center carb. Typically a 6.5
Reminder 195 degree thermostat required.
Temporarily change out the brass sight plug on the fuel bowls (all 3) with Holley’s clear sight plugs, to see the float level without no gas spills
Do not use an idle solenoid; a properly tuned car will have no “run on” issues
Factory style linkage, no progressive/ mechanical linkages!
Fuel pump: Carter street pump,. Factory style fuel lines only.
Use rubber hose only for tuning purposes
Fuel filter should be in the stock location.
Make sure the linkage is set properly. The rods should fall into the hole on the carb lever.
Check the linkage for any binding, manually open the center carb to wot and see if the secondaries will rotate open
Start car
allow engine to reach operating temp. Set idle to 1000 rpm
Fuel level adjustment THIS IS IMPORTANT, this is best done idling at 1000-1100 rpm
The slotted screw on top of the needle n seat is just a lock screw,
To adj the float level loosen the lock screw to rotate the seat nut,
Turning the adjuster nut counter clockwise will RAISE fuel level in the bowl,
Clockwise will LOWER it
Make only small 1/2 turns and wait 3 or more minutes so the fuel levels off before rechecking level. Patience!!
Center carb the fuel level is at the bottom of the sight plug hole
Secondaries just starting to come over the bottom of the sight plug hole
This is critical so get it right.
Set idle for 900 rpm
If the car won’t idle:
Is engine vacuum reading at least 2 hg higher than the power valve rating? If ok proceed, if not correct power valve issue and proceed.
Note some engines only pull 5 hg of vacuum so use a 2.5 power valve.
Advance the initial timing a bit to see if it helps idle.
Be sure operating temp is 195-210
Be sure some fool did not put light springs in the distributor.
Now set the initial timing to where it wants to be. Somewhere between 10-20 degrees BTDC. The engine will tell you by increasing vacuum and rpm at this point. In some applications the engine does not care, so set it to 12-14 degrees BTDC.
Chart:
Cams with 106-degree ctrlines seem to like initial timing set at 16-22 BTDC
Cams with 108-degree ctrlines seem to like initial timing set at 12-18 BTDC
Cams with 110-114 degree ctrlines seem to like initial timing set at 8-14 BTDC
Re-Set the idle rpm for 900-See if you have "control" over the idle mixture screws on the ctr carb.
Using a good vacuum gage adj center carb mixture to highest reading of vacuum.
This is where the digital[numeric readout] tach is better than the vacuum gage.
If you do not have control over the idle mixture you have issues that need to be taken care of before proceeding. Overjetting contributes to this
Typically if you have the center carb idle mixture screws between 1 to 2 turns ccw
you do not have to adjust the outboard idle mixture any further. Starting with the front carb, adj the mixture screws one at a time 1/16th turn ccw, after turning each screw wait and see what the engine vacuum and rpm do. Obviously if you have a wideband a-f gauge you will see what is happening.
If you are 2 turns out on the ctr carb idle mixture and the idle is still too lean, the outboards need to contribute more fuel to the idle. Open the idle mixture screws another 1/8 turn ccw. Now they will be out a total of ¼ of a turn ccw. Now go back and rset the idle mixture and rpm.
Beware of issues such as poor intake sealing, carb gaskets backwards, the wrong pcv valve, a vacuum leak from the brake booster or other places, wrong pwr valve etc.
Recheck idle rpm and set to 900
Drive car like a normal person, no wide open throttle. Is the car rich? Jet down 2 steps until you find the min jet size. You will know when you are lean as you will have no power.
Most times you are over jetted.... Do not over jet!
Over jetted carbs will have poor idle control.
Now reset the initial timing again. Somewhere between 10-20 degrees BTDC. The engine will tell you by increasing vacuum and rpm some point and then falling off. In some applications the engine does not care, so see chart.
Re-Set the rpm for 900-See if you have "control" over the idle mixture screws. Using a good vacuum gage adj each mixture screw to highest reading of vacuum. If you have a wideband afr meter set to 14.7 See how close you are between the vac gauge and af meter.
Recheck idle rpm and set to 800-950 depending on engine build, hook up vac adv and make sure car still runs/drives properly.
How do you know when you are "there”?
The engine when hot restarts immediately without touching the throttle
The car will idle at 700-900 rpm in neutral and the response is crisp.
There is no smell of raw gas in the exhaust.
The bottom of the intake is not soaked with fuel. Open a carb and look in
The spark plugs are clean and white.
The engine when cold starts easily, runs and drives smoothly from the get go.
When the engine is rev’d and the throttle released it immediately returns to idle.
The vacuum advance is hooked up and the car drives well
OK if you made it this far it’s time for the Secondaries
The reason you put the black spring is to delay the opening of the secondaries until the engine is ready for it. The engine will run fine on just the center carb till at least 3000 rpm. The air fuel mixture spikes lean when the secondaries open, but at higher rpms this is transparent and has no affect on performance. The opening of the secondaries should be seamless, but very apparent and usually scary to the uninitiated.
The secondaries rods should be disconnected and removed and the vac signal blocked. Go out and drive the car on the center carb and determine what rpm the car starts to fall off in power. Take note.
Reconnect carb linkage and vac lines, be sure to set the length of the rods properly.
Now go for a drive and see what rpm the six pak hits,
Hold first gear or 2nd gear, run up to 2500 rpm and floor it. What should happen is the secondaries open without any hesitation and the cars gets up and really goes.
The long vacuum hoses for the outboard carbs need to be exactly the same length.
Pulling a vacuum on the hose should make the vacuum pod open the throttle blade and hold a vacuum
The best way to dial in the secondary air fuel ratio is with a wide band air fuel meter.
A fine tuned seatofthepantsometer and spark plug reading will work for the more experienced.
If you made it this far and the car is bogging when the six pak opens you need to go back and recheck starting at the top. Bogs are usually from the secondaries opening too soon!!
Notes:
Automatic cars with too tight of a converter will cause significant idle rpm drops when in drive, the car will not run at it’s full potential so be sure to use the correct converter for the application.
Some cars like staggered jetting.
If the initial timing exceeds 12 degrees BTDC with a MP distributor typically the advance curve will need to be modified so the total timing is not more than 34 degrees BTDC.
Chart to shorten the slots if you have a non adjustable mopar distributor.
Distributor degrees X 2 + initial= total
32-36 total advance typically
dist. degrees / slot size
6.............. .340
7............... .355
8............... .375
9............... .390
10.............. .405
11.5 ........... .420
12.............. .435
13.............. .445
14.............. .460
15.............. .475
16.............. .490
17.............. .505
18.............. .520
6431845-6packtuning.doc (333 downloads)
