Trap RPM help #909867
01/20/11 08:58 PM
01/20/11 08:58 PM
Wisconsin
sjs64polara Offline OP
Wisconsin
Automatic transmission guys, how much over max hp are you guys crossing the lights at Do you consider torque slip
Re: Trap RPM help [Re: sjs64polara] #909868
01/20/11 09:39 PM
01/20/11 09:39 PM
Minnesota
Barnstorm Offline
Barnstorm  Offline
Minnesota
Peak hp @ 7400..shift 7600 and cross the stripe @ 7600. 4.88 gear..14x32 tire. Wallace calculator says 3.64 slip.
The little old lady from Pasadena is back!
Re: Trap RPM help [Re: sjs64polara] #909869
01/20/11 09:42 PM
01/20/11 09:42 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I try for 5%-10% over peak hp and yes you should figure
in the slippage... its still RPM
Re: Trap RPM help [Re: MR_P_BODY] #909870
01/20/11 10:55 PM
01/20/11 10:55 PM
Wisconsin
Wisconsin
Wallace calculator says 6.2 slip for my 4200 9.5" Dynamic , Bummer
Re: Trap RPM help [Re: sjs64polara] #909871
01/21/11 03:50 AM
01/21/11 03:50 AM
When figuring RPM and converter slip don't forget, especially with some of the race ignition used today, that electric tach can be off, some read higher and some read lower when compared to other, high quality tachs One of the first high dollar race tachs, Autometer with the build in rev limiter,that I bought and used read 6200 RPM when the Jones Motorola mecahnical tach read 7000 RPM The ignition was a MSD 404B, one of the first race gold boxes MSD made and sold
Re: Trap RPM help [Re: sjs64polara] #909872
01/21/11 11:05 AM
01/21/11 11:05 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
That's reasonable for a converter w/ that much stall, IMO. My 9.5" Dynamic calcs somewhere in the 7+% slippage and that's about 3% better than the converter it replaced. Even a stock converter may still have 3-4% slippage, IIRC.
My engine hit peak HP at 6300-6400 on an engine dyno and crosses the traps at 6800-6900 (depending upon how good the air is). It's definitely at the point where the power curve is staring to taper off as shown on the dyno. I still have a set of older slicks that are 1+" taller than the DOT-legal radials I run now; it would be interesting to see if the MPH picked up running the taller tires that lower the max RPM on the big end.
Re: Trap RPM help [Re: sjs64polara] #909873
01/21/11 11:46 AM
01/21/11 11:46 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I have about 6.8% slippage on my 8" conv and I dont
think its too bad... I know we would all like to see
3% but I wouldnt want to change my conv (I would like
to increase the stall about 500 rpm but afraid it might
come back messed up)... mine stalls at 5600 and would
like it at 6100
Re: Trap RPM help [Re: MR_P_BODY] #909874
01/21/11 12:17 PM
01/21/11 12:17 PM
New Lenox IL
cudadon Offline
cudadon  Offline
New Lenox IL
How are you guys figuring your slippage?
Don
Re: Trap RPM help [Re: cudadon] #909875
01/21/11 12:33 PM
01/21/11 12:33 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Re: Trap RPM help [Re: sjs64polara] #909876
01/21/11 01:00 PM
01/21/11 01:00 PM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
It depends if the engine drops like a rock or hangs on after peak.
Re: Trap RPM help [Re: jim sciortino] #909877
01/21/11 02:09 PM
01/21/11 02:09 PM
I had a 8 inch Art Carr when Art first started making converters, it would drop less than 1000 RPM on each gear change The stock 11 inch street hemi converter would drop 1300 to 1500 RPM, depending on what RPM I shifted it at The 8 inch was .3 to.4 slower on the ET and 3 to 4 MPH slower than the stock converter was We ended up with a BM 069J 9 inch converter, which was .3 to .4 quicker than the stock converter was and maybe 1 mph slower, it would drop almost identicle RPM as the stock converter did on the gear changes. To figure the converter slippages I measure the circumference of the tires(actual, not what is stated by the tire company (tires wear and all tires are not create equally ) I take the circumference and the trap RPM to figure the calculated MPH and divide the actual MPH into the calculated MPH and that is the actual percent of slpppage, IE calculted MPH = 133 and time slip MPH is 127 the percent of slippage is 4.52 % (or whatever the calculator says )Tire circumference and accurate tach RPM play a big role in getting a accurate number
Re: Trap RPM help [Re: Cab_Burge] #909878
01/21/11 02:55 PM
01/21/11 02:55 PM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
My 8" coan 5000 looks like about 7.382 if im doing it right.But it looks like that could vary if it is actually going through at 6400 or 6500 and looks like it makes a pretty big difference. Looks like I should be going through at atleast 7000 or higher.
67' charger 499 RB 10.57 at 127
Re: Trap RPM help [Re: jim sciortino] #909879
01/21/11 05:36 PM
01/21/11 05:36 PM
Wisconsin
Wisconsin
My engine drops 10 hp from 5500rpm to 6000rpm but my torque drops 66 ft lbs
So now what
Re: Trap RPM help [Re: sjs64polara] #909880
01/21/11 06:15 PM
01/21/11 06:15 PM
Trumbull,CT.
Trumbull,CT.
So now what
Forget the torque. If your valvtrain can take it, gear and converter it to cross where HP drops around 40hp or so, for starters. You wouldn't believe how far past peak HP well scienced out cars go. The converter is critical not only for flash stall, but also fall-back rpm on the shift. It takes numerous changes to hit the right combination.
The fastest SS cars in the country cross at almost 10K. They make peak well below that.
Re: Trap RPM help [Re: jim sciortino] #909881
01/22/11 10:30 AM
01/22/11 10:30 AM
Wisconsin
Wisconsin
So now what
WOW , I have good stuff in my 505 but that seams a little over board for a weekend warrior like myself.
Re: Trap RPM help [Re: sjs64polara] #909882
01/22/11 01:36 PM
01/22/11 01:36 PM
My 518 C.I. low deck pump gas street motor made peaak torque at 4600, peak HP at 5800 RPM(CNC ported Eddy RPM and a stock Eddy six pak intake and stock type Holley 1970 440 vacume carbs. The car ran the quickest and fastest by shifting it at 7300+ RPM in 1st and 2nd gear, it would cross the finish line at or close to 6200 RPM best ever Way past peak anything on the gear changes work best for the results I did later change converters in the car with a different motor and pick up 4 MPH in the 1/8 mile
Re: Trap RPM help [Re: Cab_Burge] #909883
01/22/11 03:31 PM
01/22/11 03:31 PM
Wisconsin
Wisconsin
What weight car and stall
I'm listening
Re: Trap RPM help [Re: sjs64polara] #909884
01/22/11 04:08 PM
01/22/11 04:08 PM
Trumbull,CT.
Trumbull,CT.
So now what
It probably is overboard for a "WW"......but if you want to squeeze every last bit, that's how you run em'.
Re: Trap RPM help [Re: sjs64polara] #909885
01/22/11 04:25 PM
01/22/11 04:25 PM
I'm listening
The 10 inch converter would foot stall right at 2300, flash stalled 3800 to 4300 depending on which motor and the track altitude. The 8 inch converter foot stalls near 3000 RPM, flashes 5100 - 5200 RPM. The car weighs 3450 lbs with me in it, 4:10 gears.
Re: Trap RPM help [Re: Cab_Burge] #909886
01/22/11 04:36 PM
01/22/11 04:36 PM
Wisconsin
Wisconsin
thanks for the input
