Do 15x7 Rally and 15x6 Rally use the same trim ring ? #909755
01/20/11 05:20 PM
01/20/11 05:20 PM
Lyons, CO
MileHighDart Offline OP
Lyons, CO
just wondering if the 15x7 and 15x6 rally wheels used the same trim ring. or if anyone has tried them ?
Also, who sells a 15 trim ring that look close to the original style. Doesn't have to be exact, but close.
Re: Do 15x7 Rally and 15x6 Rally use the same trim ring ? [Re: MileHighDart] #909756
01/20/11 11:16 PM
01/20/11 11:16 PM
Ramona, CA
NicksGarage Offline
NicksGarage  Offline
Ramona, CA
I believe the later rallye wheel is 15x6.5". You can use the trim rings from those on the 15x7 but I don't think it works the other way round.
The dealers used to sell new trim rings for 15x7 wheels and they were actually the newer ones as they just superceded the old part.
I think someone is making new 15x7 rings.
Re: Do 15x7 Rally and 15x6 Rally use the same trim ring ? [Re: NicksGarage] #909757
01/20/11 11:35 PM
01/20/11 11:35 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
specialty wheels
Re: Do 15x7 Rally and 15x6 Rally use the same trim ring ? [Re: MileHighDart] #909758
01/20/11 11:41 PM
01/20/11 11:41 PM
Federal way washington
BasinStBlue Offline
BasinStBlue  Offline
older Jeep Cherokees used a trim ring that was very close.
Re: Do 15x7 Rally and 15x6 Rally use the same trim ring ? [Re: BasinStBlue] #909759
01/21/11 09:31 PM
01/21/11 09:31 PM
Lyons, CO
Lyons, CO
Thanks for the info.
Re: Do 15x7 Rally and 15x6 Rally use the same trim ring ? [Re: MileHighDart] #909760
01/22/11 12:22 AM
01/22/11 12:22 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
You can but them here.Identical including correct width.Only difference is retainer.On the car you can't tell them from OEM.Every once in a while they run a special,you can get them for less than a hundred bucks a set.
http://www.lmctruck.com/icatalog/csb/full.aspx?Page=90
Re: Do 15x7 Rally and 15x6 Rally use the same trim ring ? [Re: 62maxwgn] #909761
01/22/11 02:09 AM
01/22/11 02:09 AM
Lyons, CO
Lyons, CO
Cool, thanks
