16 volt batteries #909057
01/20/11 01:11 AM
01/20/11 01:11 AM
Out West
408strokerdart Offline OP
Out West
Ok, who makes the best/lightest 16 volt battery out there? No way can I spring for a lithium battery, but looking to go to one 16v battery and since I need the charger and battery I want to get this right the first time. Lets see.....theres the turbo start, XS power, Rock....etc. the list goes on. Anyone have expertise here? looks like everything I have is compatable with 16v so I won't need one with a 12v output.
Re: 16 volt batteries [Re: 408strokerdart] #909058
01/20/11 01:18 AM
01/20/11 01:18 AM
Mobile Alabama
SB412DUSTER Offline
SB412DUSTER  Offline
Mobile Alabama
So far I like my XS S1600. I've been running it almost a year. I have a step down for my fan and water pump, they both are compatable with the 16v but sometimes I charge the battery while running both the fan and pump and they smell like they dont like that.
Re: 16 volt batteries [Re: 408strokerdart] #909059
01/20/11 01:25 AM
01/20/11 01:25 AM
Columbus, OH
Ben Holt Offline
Ben Holt  Offline
Columbus, OH
There are some affordable lithiums out there, Brian. I am a dealer for the XS lithium series. But if I were to get a regular AGM I would get the XS lightweight
Re: 16 volt batteries [Re: SB412DUSTER] #909060
01/20/11 01:27 AM
01/20/11 01:27 AM
Out West
Out West
That's a good point Laverne. I do the same thing while on the charger. Are you running an alt with the S1600?
Re: 16 volt batteries [Re: Ben Holt] #909061
01/20/11 01:29 AM
01/20/11 01:29 AM
Out West
Out West
Ben, what are the affordable lithiums? I am only aware of the XS for racing use.
Re: 16 volt batteries [Re: 408strokerdart] #909062
01/20/11 01:38 AM
01/20/11 01:38 AM
Mobile Alabama
SB412DUSTER Offline
SB412DUSTER  Offline
Mobile Alabama
No brian I dont run an alt.
Re: 16 volt batteries [Re: 408strokerdart] #909063
01/20/11 01:44 AM
01/20/11 01:44 AM
Columbus, OH
Ben Holt Offline
Ben Holt  Offline
Columbus, OH
http://www.jerrybickel.com/batteries-and-components/xs-lithium-powerpack-l925-16ck-and-charger.html
This is off of JBRC's site. The only kicker with the lithium is you HAVE to use some sort of auxiliary battery pack when charging in the pits. you basically shut the car off and charge the lithium while an external battery runs your fan, wp, etc.
We've got one in a 4 stage nitrous BBC outlaw car, and it charges in 12 minutes once we get back. Just have a 12v optima yellow top with a charger piggybacked on it and cool the car down quick
It's really easy to do...
Re: 16 volt batteries [Re: Ben Holt] #909064
01/20/11 09:15 AM
01/20/11 09:15 AM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
I run the lightweight Powermaster also. Have had them in 3 cars, dragster, firebird and dart with no problems at all.
Re: 16 volt batteries [Re: MegaDart] #909065
01/20/11 02:49 PM
01/20/11 02:49 PM
Out West
Out West
So, those running the lightweight XS....you are running only 1 battery right? Even with no alt?
Re: 16 volt batteries [Re: 408strokerdart] #909066
01/20/11 03:37 PM
01/20/11 03:37 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
I AM SWITCHING TO 16V
but elected to buy a 12-16 volt powermaster alternator. I can use it on any 12v or 16v system
as it is adjustable. This way I have no real need for the 16v charger.
as for between rounds cooling etc. a seperate line from the fan and pump plugs into a pair of 6v golf cart batteries in the trailer connected in series now making 12v . They have enough amps to use them all day and not need a single recharging. They recharge when the truck is running.
home of the
Sox and Martin Hemi Duster
Re: 16 volt batteries [Re: 408strokerdart] #909067
01/20/11 04:14 PM
01/20/11 04:14 PM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
that is correct. although I do have a 140amp alternator that I MAY put on??
Re: 16 volt batteries [Re: HEMIFRED] #909068
01/20/11 07:58 PM
01/20/11 07:58 PM
Out West
Out West
Alot of great ideas there Fred. I really want to run an alternator....not sure I've seen the "adjustable" version before. Are you going to use a step down for the fan/water pump and turn the alt up to 16V? This is the only way to keep the battery charged without a charger right? I like the idea of being able to hook up to another power source at the trailer for cooling.
Re: 16 volt batteries [Re: 408strokerdart] #909069
01/21/11 01:46 AM
01/21/11 01:46 AM
Mobile Alabama
SB412DUSTER Offline
SB412DUSTER  Offline
Mobile Alabama
Thats right for me too brian
Re: 16 volt batteries [Re: SB412DUSTER] #909070
01/21/11 05:10 AM
01/21/11 05:10 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
We use one 16 volt on a few of the cars.Don't let them lose charge or set for long periods at at low voltage,they tend to go bad and not recharge.Get the correct charger and or tender.
Re: 16 volt batteries [Re: B G Racing] #909071
01/21/11 10:12 AM
01/21/11 10:12 AM
Out West
Out West
Thanks for all of the replies. I think I have a clear direction for what I need to do.
