59 DEGREE 340 SIAMESE BLOCK #908517
01/19/11 07:30 AM
01/19/11 07:30 AM
Queensland Australia
moparmacka Offline OP
Does any one have close up OR clear photos of the machining required on the inside of the valley (extra head bolt bosses in the valley), when fitting Comp 8043 roller lifters. I saw a few in a MM mag on a build that AndyF did but the pics are a bit small and low res. My concern is how much can I mill off, considering the water jacket is directly under this area that requires machining.
Also is it worth machining the extra material off the lifter bosses on these blocks....does it weaken this area any?
Thanks in advance
Macka
Re: 59 DEGREE 340 SIAMESE BLOCK [Re: moparmacka] #908518
01/19/11 08:32 AM
01/19/11 08:32 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I would check Shady Dell Speed Shop web site or
contact Ryan(from the same shop) and ask him... if
its been done to a SB mopar he would know
Re: 59 DEGREE 340 SIAMESE BLOCK [Re: MR_P_BODY] #908519
01/19/11 05:26 PM
01/19/11 05:26 PM
He has helped me so much in the past, I felt funny asking him for pics as well.
Re: 59 DEGREE 340 SIAMESE BLOCK [Re: moparmacka] #908520
01/19/11 07:25 PM
01/19/11 07:25 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
i believe its mopar ACTION that has an article w a nice picture of ryans work..its a few months back,but check the website..it was a stroker 427ci i believe they were building
Re: 59 DEGREE 340 SIAMESE BLOCK [Re: fishy340] #908521
01/19/11 08:28 PM
01/19/11 08:28 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
Re: 59 DEGREE 340 SIAMESE BLOCK [Re: RyanJ] #908522
01/19/11 08:30 PM
01/19/11 08:30 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
2
Re: 59 DEGREE 340 SIAMESE BLOCK [Re: RyanJ] #908523
01/19/11 08:31 PM
01/19/11 08:31 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
3
Re: 59 DEGREE 340 SIAMESE BLOCK [Re: RyanJ] #908524
01/19/11 09:37 PM
01/19/11 09:37 PM
Brisbane Australia
572B1 Offline
572B1  Offline
Brisbane Australia
Hey Macka, I hope you have heaps of beer. Geoff will have a thurst after this job.
Re: 59 DEGREE 340 SIAMESE BLOCK [Re: RyanJ] #908525
01/19/11 10:09 PM
01/19/11 10:09 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Ryan is that a CNC program... are you doing it or is
that sent out
Re: 59 DEGREE 340 SIAMESE BLOCK [Re: RyanJ] #908526
01/20/11 08:04 AM
01/20/11 08:04 AM
WOW! That is some seriuos machine work in the valley, bet it sheds some weight! I see from photo 1 that you can machine quite a bit from the inside, where the extra headbolt boss was. Is there still plenty of meat before hiting water?
Thanks for the pics!
Re: 59 DEGREE 340 SIAMESE BLOCK [Re: 572B1] #908527
01/20/11 08:08 AM
01/20/11 08:08 AM
Didn't you hear?......between Geoff and the floods there is shortage of XXXX!!
Re: 59 DEGREE 340 SIAMESE BLOCK [Re: moparmacka] #908528
01/20/11 08:43 AM
01/20/11 08:43 AM
Brisbane Australia
572B1 Offline
572B1  Offline
Brisbane Australia
Didn't you hear?......between Geoff and the floods there is shortage of XXXX!! [/quote
He works for bundy and coke also.
Re: 59 DEGREE 340 SIAMESE BLOCK [Re: moparmacka] #908529
01/20/11 01:38 PM
01/20/11 01:38 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
Yes there is plenty of material right where the head bolt bulge is, the thin area is on both sides of the head bolt bulge where the rivets will ride in a normal roller lifter.
I've done about 30 59* R3's for roller lifters & only one hit water. Just bad bad core shift on that block, normally there is around .150" left after clearancing.
MrP yes this is my own CNC program. We've been clearancing them on CNC for about 4 years.
