Battery acid #90844
07/19/08 02:45 PM
07/19/08 02:45 PM
Ohio
440727 Offline OP
440727  Offline OP
Ohio
I have a 1967 Dodge Coronet R/T in which the battery leaked acid all over the inner fender well and top of the frame rail. This is the way I found the car after it had been sitting since 1976. There is no really serious damage yet but I want to prevent it from getting any worse !
My question is what is the best way to clean up, neutralize the battery acid, and primer or paint over it with ?
Re: Battery acid [Re: 440727] #90845
07/19/08 03:22 PM
07/19/08 03:22 PM
Mass
Mike Mancini Offline
Mass
Clean and scrub the affected areas with baking soda and water.
Michael L. Mancini
American Muscle Car Restorations, Inc.
65 Foliage Drive
N. Kingstown, RI
Premium Quality Restoration Services for Hi-Performance & Classic Automobiles. OE Specialists.
Instrument Specialties, Inc
www.instrument-specialties.com
www.manciniresto.com
www.performancecargraphics.com
Re: Battery acid [Re: Mike Mancini] #90846
07/19/08 03:24 PM
07/19/08 03:24 PM
Kirkland, Washington
Pacnorthcuda Offline
yeppers...hard to beat the old sodium bicarbonate treatment!
Re: Battery acid [Re: 440727] #90847
07/19/08 05:56 PM
07/19/08 05:56 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
CRC makes a spray can neutralizer that turns red if there's acid present so you can tell when you've gotten all the acid treated. Some times it's surprising how far the acid creeps.
Re: Battery acid [Re: 440727] #90848
07/19/08 07:24 PM
07/19/08 07:24 PM
Ohio
440727 Offline OP
440727  Offline OP
Ohio
Thanks a lot guys !
Re: Battery acid [Re: 440727] #90849
07/19/08 08:03 PM
07/19/08 08:03 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
Check the bottom of the frane rail for softness
going all the way back the bottom of the drivers foot well.
logan426
