Re: Stock Block, 1000hp, 7000+ RPM???
[Re: gsmopar]
#908436
01/19/11 12:02 AM
01/19/11 12:02 AM
Posts: 4,590 Indy
joshking440
Lunch is on me!
Lunch is on me!
Indy
[Re: gsmopar]
#908437
01/19/11 12:18 AM
01/19/11 12:18 AM
Posts: 43,185 Bend,OR USA
Cab_Burge
I was surfing the web shopping for parts for my next build when I ran across this. I've never built anything over 500hp so I'll keep my comments to myself.
http://www.youtube.com/watch?v=J0xWrp5bX4c
http://www.racingjunk.com/category/92/Dr...er-900-HP-.html
I hae seen several 426 and 440 wedge blocks crack and break the main webs at a lot less power than 900 HP I have a 527 C.I. wedge motor(stock 440 block) that makes 800+ HP at 6500 RPM normally apsereated, two 1050 Holley domintor carbs I bought and had ductile iron main caps and ARP main studs installed because I was worried about breaking the main webs I started buying parts for that motor back in 1996 or so, long bfore good blocks where availble Shame on me I'll probally remove the rotating assembly and install a pump gas freindly smaller stroker asembly in that block to make it safe I have sense bought a World block and I will put those 800 +HP parts in it If you want a motor that will make 800+ HP and live a long, productive life, buy a good block to start with
[Re: fishy340]
#908439
01/19/11 12:38 AM
01/19/11 12:38 AM
Posts: 4,679 On the parachute mount
n20mstr
WOW did you read the RJ ad...20 invested???
Any way...way back i had my 440-1 on a stock block, Went a best of 9.09 at 147 at 3600lbs,,.....what hp is that??? That motor had stock main caps with studs, thats it...Upon dissasembly after over 200 passes it had some MASSIVE cap walk, but that was about it...GRP alum rods. Still have the block, thinking about building another engine with it for my sons duster
....BAD A$$ STREET CAR.....
[Re: n20mstr]
#908440
01/19/11 12:43 AM
01/19/11 12:43 AM
Posts: 5,618 long island NY
Ari440
long island NY
440 ci motor ?
1.39 9.85 - 137 mph
[Re: Ari440]
#908441
01/19/11 01:01 AM
01/19/11 01:01 AM
n20mstr
It was a 446 (+.030) Stock crank 3.75 GRP rods JE piston (custom) Out of the Box 440-1 and intake 9375 dominator Solid Roller cam
Pretty basic parts bolted together, went 10.20 on motor and 9.20-teens pretty consisten on a plate 93n 82f Ran a 9.09 once at Cecil Co
I used to cringe every time i used nitrous on that motor, pretty soon i just got used to it...LOL
440 ci motor ?
[Re: n20mstr]
#908442
01/19/11 10:19 PM
01/19/11 10:19 PM
Ari440
long island NY
440 ci motor ?
how much of a NOS shot is this : 150-200 hp ?
1.39 9.85 - 137 mph
[Re: n20mstr]
#908444
01/19/11 11:16 PM
01/19/11 11:16 PM
Posts: 3,112 LONG ISLAND
fishy340
LONG ISLAND
please dont bring red to the bb side! us red heads love the sb's lol
[Re: fishy340]
#908445
01/19/11 11:41 PM
01/19/11 11:41 PM
n20mstr
Tell me about that,,, there is a TON of room with a small block in the Duster. All i keep thinkging is WOW i really need to put a Small Block in my car....
[Re: joshking440]
#908449
01/21/11 11:02 AM
01/21/11 11:02 AM
Posts: 452 nc
cold85
nc
