Race only water temps #908217
01/18/11 06:03 PM
01/18/11 06:03 PM
nc
E
emarine01 Offline OP
E
nc
What engine temp do you guys use just before you leave and what is the temp rise @ the stripe? Also how long does it take to shed the temp after the return lane?
Re: Race only water temps [Re: emarine01] #908218
01/18/11 07:13 PM
01/18/11 07:13 PM
South Bend, Indiana
mistress Offline
mistress  Offline
South Bend, Indiana
I leave at 180 and at the stripe its 180, but your probably talking about a car that is running gasoline in it,which i am not.
Re: Race only water temps [Re: mistress] #908219
01/18/11 07:48 PM
01/18/11 07:48 PM
nc
E
E
nc
Yep, gas it is, still good info thankx
Re: Race only water temps [Re: emarine01] #908220
01/18/11 08:10 PM
01/18/11 08:10 PM
Q
Quicktree Offline
Quicktree  Offline
Q
we leave at 150
Re: Race only water temps [Re: emarine01] #908221
01/18/11 08:16 PM
01/18/11 08:16 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Our last deal was a hot blooded BBF......staged at 160 - 165 and parked it around 195-200.
I used a tick tock switch ( Shogun industries ) ....a sequential switch that alternated the water pump and fan and it would recover in a very short time..........five minutes max.
This really helped in late rounds when there wasn't a lot of time between passes.
I know new cars run a lot hotter , but I never liked seeing over 200 personally.
And a lot of cars just didn't have much trouble with it.
I know bow tie guys who could run all day and never get over 180 with pretty decent cars........mid 10 stuff.
My Ford just didn't care for it and I did a bunch of things to try and improve it.
A shroud would have really helped too if I would have kept the belt driven fan.
Big aluminum radiator , Moroso electric w.p. drive , 1,600 c.f.m. fan and the tick tock kept it manageable , but it wasn't exactly optimum.
A little hard on the battery , so I had to make sure to charge it when I had time so it would start me in the late rounds.
Re: Race only water temps [Re: tubtar] #908222
01/18/11 09:06 PM
01/18/11 09:06 PM
Renton Washington
Triple Threat Offline
Renton Washington
160 stage temp
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Race only water temps [Re: tubtar] #908223
01/18/11 09:07 PM
01/18/11 09:07 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Back when I was running gas I had a pretty good thing going.
I would burn out @ 180. Leave @ 190, cross the line @ 200, and @ the turn off I was @ 190, and back to 180 by the time I reached the pit.
I have a very large radiator
Re: Race only water temps [Re: WILD BILL] #908224
01/19/11 12:05 AM
01/19/11 12:05 AM
nc
E
E
nc
We have been staging between 130 - 140 running 200ft in the mud crossing the line @ 180 - 190 hitting 200 on the return then shuttin down 200-210, It takes around 4 min to cool off to 100-120 with the engine off and the pump & fan on, We see a 40 to 50 degree temp rise in around 3.5 secs @ wot, I have a single pass rad with a 2800 cfm fan with no fan shroud, Don't have too much room in between the moroso electric pump and the single pass rad around 1/4", The fan is mounted in front of the rad pulling air out of the front of the truck to help clear the rad fins,so I dont run the fan during the pass, I switch it on @ the turn on to the return road, We have been gettin along with this set up for 4 seasons without overheating....But we have plans to run out of state in @ a 300ft track... so its time to up grade,Current rules state cant fool with the fire wall so I can only go forward, Trying to keep the stock grill in place so any one got any ideas
Re: Race only water temps [Re: emarine01] #908225
01/19/11 12:24 AM
01/19/11 12:24 AM
I like to see 140 F in the burn out, stage at or below 160 F, cross the line(1/4 mile temps) at or near 180 to 200 F , different motors at different times of the year make a difference As far as cool down time it depends on which car and which track More power makes more heat, takes a little longer to cool down, all comments are about gasoline motors N/A, no power adders and no fill in the blocks either
Re: Race only water temps [Re: Cab_Burge] #908226
01/19/11 12:34 AM
01/19/11 12:34 AM
North Carolina
K
keelsracing Offline
keelsracing  Offline
K
North Carolina
Spring And Fall click the fan on at 170 stripe at 185-190 stopping cool down at 130 to keep some heat in but in summer fan on at 150 stripe at 175-180 cool as much as possible for the temp and humidity
when i click the fan can sit under 2000 rpm and never see the temp rise even 3 numbers
Re: Race only water temps [Re: Cab_Burge] #908227
01/19/11 12:35 AM
01/19/11 12:35 AM
nc
E
E
nc
has anyone seen a reasonable drop in load temp with E85?
Re: Race only water temps [Re: keelsracing] #908228
01/19/11 12:44 AM
01/19/11 12:44 AM
nc
E
E
nc
If I run with a lite load with the fan on its hard to hit 150 even in summer,
Re: Race only water temps [Re: emarine01] #908229
01/19/11 02:32 AM
01/19/11 02:32 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Everything I have heard says yes , so that is my current build.
I won't know for sure till late spring or so , but I hope they are right.
Re: Race only water temps [Re: mistress] #908230
01/19/11 02:53 AM
01/19/11 02:53 AM
fresno ca
mikeysmopars Offline
fresno ca
Hi Mike, Dont want to hijack this thread but love your car!
Like to see some build pix of the back end of the car.
Guess i'm asking to see pix of the a$$end of your mistress!!
mike
Pm Please!!
aka mikeysmopars
Founder and CEO of the Central Valley Mopar Drag Pack
Re: Race only water temps [Re: Cab_Burge] #908231
01/19/11 09:26 AM
01/19/11 09:26 AM
Lehigh Acres, Florida
rickstershemi Offline
With my roadster & 565, the temps were identical to yours
Rickster
Re: Race only water temps [Re: emarine01] #908232
01/19/11 09:44 AM
01/19/11 09:44 AM
Highland beach Fl
P
poisondart2 Offline
poisondart2  Offline
P
Highland beach Fl
YES big difference, I have to warm the engine proir to going to the lanes to get heat in it. I heat it up to 160 and then turn the fans on it stays at 160 ! I have tried 140 and 180 but it runs the best at 160.It will go higher without fans but it will stay at the number if the fans are kept on. This is with outside temp in mid 80's we will see this summer when the temps go to high 90's.I used to leave the fans on for about 5 minutes to cool it down after a run and now I turn the fans off so it wont cool down. Best thing no pushing in the lanes just start it and drive it even if you have to sit for 20 minutes at idle. I love it!
Re: Race only water temps [Re: emarine01] #908233
01/19/11 09:59 AM
01/19/11 09:59 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Burnout at 150 or so, launch at 160 ... might hit
180 at the turn off and its back to 150-160 at the pit
using E85... I see a 20* drop just using E85... its
a little harder to get it up to temp so I watch it
pretty close in the lanes and fire up to keep it near
temp
Re: Race only water temps [Re: MR_P_BODY] #908234
01/19/11 10:34 AM
01/19/11 10:34 AM
North Cackilacky
sdaurity Offline
sdaurity  Offline
North Cackilacky
Why don't you put a larger radiator in the bed. I have done this on a few hill-n-hole trucks here around the house.
One day I will have something cool here.
Re: Race only water temps [Re: sdaurity] #908235
01/19/11 10:53 AM
01/19/11 10:53 AM
MR_P_BODY Offline
MR_P_BODY  Offline
The E85 is in the race car, my Rampage I can get a
18" X 24" in fairly easy in the fascia area... this
car/truck is going to run pump gas
EDIT
I forgot he(OP) is dealing with a truck.... sorry
Re: Race only water temps [Re: sdaurity] #908236
01/19/11 11:03 AM
01/19/11 11:03 AM
nc
E
E
nc
Super stock rules, rad in stock location, If I have to I can run a second rad in the bed but I am not @ that point yet. When I ran in the mod class I had a larger rad in the bed, no rad up front, it worked good.
