Re: whats the perfect converter for the 557 cam in a 440 [Re: shoebox] #908130
01/19/11 12:14 PM
01/19/11 12:14 PM
NC
440Jim Offline
440Jim  Offline
NC
im going to throw it in and see what happens!
I think it is worth trying. Let us know two things:
1) How it drives pulling away from the stop light (normal traffic/slow).
2) What the WOT stall turns out to be.
Different people will tolerate different feel during normal traffic driving. If it stalls around 3800 rpm in your combo, I think it will be fine.
Re: whats the perfect converter for the 557 cam in a 440 [Re: 440Jim] #908131
01/19/11 01:17 PM
01/19/11 01:17 PM
K
KOS Offline
KOS  Offline
K
i dont care for TCI.....everyone ive ever ran was inefficent. best vert would be an 8" from a reputable manufacturer.ATI,UCC,coan,TA for example.
Re: whats the perfect converter for the 557 cam in a 440 [Re: KOS] #908132
01/19/11 01:44 PM
01/19/11 01:44 PM
Clinton Twp... north of Deetro...
Labratt Offline
Good Ol Randy B!
Labratt  Offline
Good Ol Randy B!
Like Ron(383Man)and Brad(BlownBudget)I run a 9.5" Dynamic,behind my modified 440, that flashes to 4500rpm,and drives like a stock converter on the street! I've been using it for 5 yrs. now,and couldn't be happier!
Re: whats the perfect converter for the 557 cam in a 440 [Re: Labratt] #908133
01/19/11 08:42 PM
01/19/11 08:42 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I also run the Dynamic 9.5 street/strip converter behind my mild 440 in my 3700 lb 63 Sport Fury. It has 906 heads that I ported myself. I use a stock stroke 440 with the .557 MP cam and I love how it drives and races with the 9.5 Dynamic unit. Mine will flash about 4200 and has gotten me a best 60 ft of 1.57 with an 11.49 et and drives around like a stock converter. We also have the 9.5 Dynamic unit in my sons Dart that uses a .030 over 400 (406) with the .557 cam. He uses Eddy RPM heads and 3.91's with a best et of 11.45 and a best 60 of 1.60 as I use 4.30's in my 63. We both really like how well the converter works in our street/strip cars. Ron
Re: whats the perfect converter for the 557 cam in a 440 [Re: 383man] #908134
01/20/11 03:18 AM
01/20/11 03:18 AM
Adrian, Mi
P
pro6pakRR Offline
mopar addict
pro6pakRR  Offline
mopar addict
P
Adrian, Mi
I have a 440 with ootb eddy head and a 6 BBL.In a 3895# 70 roadrunner and 4.10 gears. It has a PTC 8in that stalls at 5000 rpm.Has gone 11.53@117 in street trim.
Re: whats the perfect converter for the 557 cam in a 440 [Re: pro6pakRR] #908135
01/20/11 10:59 AM
01/20/11 10:59 AM
mckinney texas
shoebox Offline OP
shoebox  Offline OP
mckinney texas
when i hear statments like "it flashes to 4XXX and drives like stock" THAT sells me on a product! ive had a 1k converter in a late model trans daily driver and it was the best thou i ever spent on that car. what a difference the right stall makes. im going to try this stall just so i dont always wonder "what if..." if it doesnt work im going dynamic!!! (are they pricey?)
Re: whats the perfect converter for the 557 cam in a 440 [Re: shoebox] #908136
01/20/11 12:25 PM
01/20/11 12:25 PM
ill
dennismopar73 Offline
ill
not a big tci (TOTAL CRAP INSIDE)fan at all
but heay if it works ok,
I'll take a hit there,
but i run turbo action/ dynamic
prefer dynamic, much better tech help
but a good 9-9.5 convert should work great on
a street/strip car with no bad effect,
make sure tho you run a good trans cooler/lines
Re: whats the perfect converter for the 557 cam in a 440 [Re: Quicktree] #908137
01/21/11 11:21 AM
01/21/11 11:21 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
... a tci "race" 9 inch 3800 stall to start with...
If it's an actual "race" converter, it'll likely slip so badly below the lock-up point that it'll drive like crap on the street. Try it and see if you can live with it.
IIRC, 383man runs a Dynamic 9.5", as do I. I have no idea if they're configured the same, though.
what we have used 5200 stall race converters on the street and they didn't drive like crap on the street. a converter doesn't stall untill power is applied.
I'm sure you have enough experience to know that a converter can be configured a bazillion different ways and that has a direct impact on the way it responds to things like part-throttle application below the actual stall speed. Some units still provide a reasonable amount of fluid coupling under those conditions, while others are just "slip sliding away" (to borrow a line from an old Paul Simon song).
Re: whats the perfect converter for the 557 cam in a 440 [Re: Labratt] #908138
01/21/11 11:25 AM
01/21/11 11:25 AM
BradH Offline
BradH  Offline
... I run a 9.5" Dynamic,behind my modified 440, that flashes to 4500rpm,and drives like a stock converter on the street!
I won't claim mine drives like a stock converter under the stall speed, but it's a lot less "slushy" than the "brand name" 10", 3800-stall, unit it replaced. It also picked up about .2 and 2 MPH due to reduced slippage.
