Re: whats the perfect converter for the 557 cam in a 440
[Re: dOrk !]
#908112
01/18/11 02:39 PM
01/18/11 02:39 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
whats wrong with the one you have?
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: shoebox]
#908114
01/18/11 03:04 PM
01/18/11 03:04 PM
Posts: 2,315 MOPAR HEADQUARTERS IN ALDEN NY
hemigod426
how much do you drive it and how far? how often do you really race? that cam is perfect for street car i like a tight 10 inch for street car. if you really want to run a # and dont care about slipage/trans heat/gas mileage ect.. go 4k stall
MOPAR OR NO CAR
[Re: shoebox]
#908116
01/18/11 04:14 PM
01/18/11 04:14 PM
Triple Threat
Renton Washington
Try it, Should be close to "ideal" for a street/strip deal.
[Re: Big Squeeze]
#908119
01/18/11 06:46 PM
01/18/11 06:46 PM
Quicktree
i guess if this stall is too loose i can have it sent somewhere for a tighten up
If anything I was going to say it was too tight....
same here
[Re: shoebox]
#908120
01/18/11 06:59 PM
01/18/11 06:59 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Its hard to say what that conv will stall at behind that 440 but I would guess in the 4500 range... which is still fine for the street
[Re: shoebox]
#908123
01/19/11 12:30 AM
01/19/11 12:30 AM
BradH
... a tci "race" 9 inch 3800 stall to start with...
If it's an actual "race" converter, it'll likely slip so badly below the lock-up point that it'll drive like crap on the street. Try it and see if you can live with it.
IIRC, 383man runs a Dynamic 9.5", as do I. I have no idea if they're configured the same, though.
[Re: shoebox]
#908125
01/19/11 07:23 AM
01/19/11 07:23 AM
Posts: 10,766 Central Valley, CA.
Quicksilver440
Central Valley, CA.
are the dynamic 9.5s all custom or is it a off the shelf converter?
I believe they always build to order...I run a dynamic 9.5 that I boughth used. It's actually too tight for my combo (built for a more powerful car).
[Re: BradH]
#908126
01/19/11 07:28 AM
01/19/11 07:28 AM
Quicktree
what we have used 5200 stall race converters on the street and they didn't drive like crap on the street. a converter doesn't stall untill power is applied.
[Re: shoebox]
#908129
01/19/11 11:00 AM
01/19/11 11:00 AM
MR_P_BODY
its a tci unit.. i called with all the numbers.. alls they could tell me is that it is a custom 9 inch race converter "probably too loose for the street". the man i bought it from is a dynamic customer, this was a "backup" converter he tried and he thought it was about 3800-4000. it was a racecar so we dont know about the drivability. im going to throw it in and see what happens!
I have a 8" thats going in my Rampage and I called T/A and talked to Paul, gave him the numbers on mine and he said its a 3800 series but after telling him my engine and vehicle specs he figured about 5000-5200 so I'll put it in and give it a try... the most I might have to do is pull it and send it out to get adjusted... one thing I liked was he said that conv is a very efficient conv with a low slippage rate
[Re: shoebox]
#908130
01/19/11 12:14 PM
01/19/11 12:14 PM
Posts: 16,925 NC
440Jim
NC
I think it is worth trying. Let us know two things: 1) How it drives pulling away from the stop light (normal traffic/slow). 2) What the WOT stall turns out to be.
Different people will tolerate different feel during normal traffic driving. If it stalls around 3800 rpm in your combo, I think it will be fine.
[Re: Labratt]
#908133
01/19/11 08:42 PM
01/19/11 08:42 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
[Re: 383man]
#908134
01/20/11 03:18 AM
01/20/11 03:18 AM
Posts: 1,153 Adrian, Mi
pro6pakRR
mopar addict
mopar addict
Adrian, Mi
I have a 440 with ootb eddy head and a 6 BBL.In a 3895# 70 roadrunner and 4.10 gears. It has a PTC 8in that stalls at 5000 rpm.Has gone 11.53@117 in street trim.
[Re: shoebox]
#908136
01/20/11 12:25 PM
01/20/11 12:25 PM
Posts: 2,177 ill
dennismopar73
ill
not a big tci (TOTAL CRAP INSIDE)fan at all but heay if it works ok, I'll take a hit there, but i run turbo action/ dynamic prefer dynamic, much better tech help but a good 9-9.5 convert should work great on a street/strip car with no bad effect, make sure tho you run a good trans cooler/lines
[Re: Quicktree]
#908137
01/21/11 11:21 AM
01/21/11 11:21 AM
BradH
I'm sure you have enough experience to know that a converter can be configured a bazillion different ways and that has a direct impact on the way it responds to things like part-throttle application below the actual stall speed. Some units still provide a reasonable amount of fluid coupling under those conditions, while others are just "slip sliding away" (to borrow a line from an old Paul Simon song).
[Re: Labratt]
#908138
01/21/11 11:25 AM
01/21/11 11:25 AM
BradH
... I run a 9.5" Dynamic,behind my modified 440, that flashes to 4500rpm,and drives like a stock converter on the street!
I won't claim mine drives like a stock converter under the stall speed, but it's a lot less "slushy" than the "brand name" 10", 3800-stall, unit it replaced. It also picked up about .2 and 2 MPH due to reduced slippage.
