Opinions for best no puke oil evac tank... #907926
01/18/11 10:45 AM
01/18/11 10:45 AM
Sask, Can.
72demon416 Offline OP
Sask, Can.
I'm going to be installing a Moroso vac pump in the future and I want a tank that doesn't puke like a 16 year old kid at a keg party. So the consensus has been to stay away from the Moroso but is there a brand out there that is clearly better than the others?
Re: Opinions for best no puke oil evac tank... [Re: 72demon416] #907927
01/18/11 11:14 AM
01/18/11 11:14 AM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
Star products. http://www.starvacuumpumps.com/catalog/ The other key to keeping the tank clean is to have the motor sealed up tight. We run the rear main seal backwards. Very very little oil ends up in the tank.
Dan
Brewers Performance Inc.
4-speed transmission and parts specialists
PH 937-947-4416 or 937-698-4259
FAX 937-947-4419
www.brewersperformance.com
Re: Opinions for best no puke oil evac tank... [Re: 72demon416] #907928
01/18/11 11:31 AM
01/18/11 11:31 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I did some research before purchasing mine. Star and Moroso like to run dry. G.Z. needs to have some oil run through it which I feel is going to happen anyway. I decided to pull from the fuel pump block off. I'm running a Jessel so there is no timing chain. It appears to be a "dead" area as far as winndage. Will it work well? Time will tell.
Doug
Re: Opinions for best no puke oil evac tank... [Re: dvw] #907929
01/18/11 08:44 PM
01/18/11 08:44 PM
Sask, Can.
Sask, Can.
maybe I should have said- is there any to stay away from?
Re: Opinions for best no puke oil evac tank... [Re: 72demon416] #907930
01/18/11 09:31 PM
01/18/11 09:31 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
moroso tank with the filter on top..cut a piece of tube sock and put it around the filter..i made 12 passes and had maybe a 1/2 a shot glass of oil.
Re: Opinions for best no puke oil evac tank... [Re: 72demon416] #907931
01/18/11 09:53 PM
01/18/11 09:53 PM
MR_P_BODY Offline
MR_P_BODY  Offline
90% of the battle is where you pull the vac from
and the baffling
Re: Opinions for best no puke oil evac tank... [Re: MR_P_BODY] #907932
01/18/11 10:16 PM
01/18/11 10:16 PM
Sask, Can.
Sask, Can.
I guess being that it's my post I can hijack it and change direction right? LOL. So where is the prefered fitting location for most small blocks? I know that the front of the valve cover is a recommended spot or the above a rocker stand- but I was thinking of using the factory breather location instead...
Does anybody have a picture of how they baffled their valve covers that worked out good? I've got hundreds of ideas of what will work but I only want to do this once.
Thanks guys
Re: Opinions for best no puke oil evac tank... [Re: 72demon416] #907933
01/18/11 10:25 PM
01/18/11 10:25 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Well I pull from right above the wide rocker stand
near the front... I made a interlocking U set up that
was sealed to the valve cover(one U fit inside the
other so the open of the U over lapped)
Re: Opinions for best no puke oil evac tank... [Re: MR_P_BODY] #907934
01/18/11 10:33 PM
01/18/11 10:33 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Moroso = total junk.
Re: Opinions for best no puke oil evac tank... [Re: Bob_Coomer] #907935
01/18/11 11:07 PM
01/18/11 11:07 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
I use this tank from moroso. I run my hose into the lower one and cap off the upper one. No problems here.
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Opinions for best no puke oil evac tank... [Re: bigtimeauto] #907936
01/18/11 11:46 PM
01/18/11 11:46 PM
Sask, Can.
Sask, Can.
So if it overfilled what would happen- oil would come out the upper port if it wasn't capped off?
Re: Opinions for best no puke oil evac tank... [Re: 72demon416] #907937
01/18/11 11:52 PM
01/18/11 11:52 PM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
No matter what tank you use if it becomes overfilled it will come out. I drive may car on the street so the extra volume works great. The bonus of this tank is the spraying oil has room to seperate and fall to the bottom instead of blowing out the breather.
Re: Opinions for best no puke oil evac tank... [Re: 72demon416] #907938
01/19/11 12:21 AM
01/19/11 12:21 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Most any of those tanks you need to direct the air
flow down in the tank so it doesnt spray the mist
and get caught up in the exiting air
Re: Opinions for best no puke oil evac tank... [Re: bigtimeauto] #907939
01/19/11 01:17 AM
01/19/11 01:17 AM
Sask, Can.
Sask, Can.
That's essentially what I'm after right there. Most of my driving is on the street and while I expect to have to empty it on regular basis there is a chance I may forget sometime. Are all these tanks open inside or is there any that have a down spout/tube attached to the fitting to direct the mist down?
Raff- this baffle your talking about...How big is it? are you talking a few inches overlapping the fitting or the length of the cover? the ends of the "u"'s- are they closed or open?
Re: Opinions for best no puke oil evac tank... [Re: 72demon416] #907940
01/19/11 09:36 AM
01/19/11 09:36 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I drew up a quick sketch ... I made it with a backing
plate that way if you have a nut for the inside of
the valve cover for the breather fitting you can
use the nut to hold it in place(I didnt have a nut
because I tapped the valve cover).... the inlet side
(side where the printing is) is towards the exhaust
on mine because of push rod oiling
Re: Opinions for best no puke oil evac tank... [Re: MR_P_BODY] #907941
01/19/11 10:37 AM
01/19/11 10:37 AM
Sask, Can.
Sask, Can.
Thanks for drawing it out as I has a different visualization for it.
Re: Opinions for best no puke oil evac tank... [Re: 72demon416] #907942
01/19/11 12:01 PM
01/19/11 12:01 PM
Mo.
supercomp Offline
supercomp  Offline
Mo.
This moroso fitting works just fine for us.
Re: Opinions for best no puke oil evac tank... [Re: supercomp] #907943
01/19/11 01:18 PM
01/19/11 01:18 PM
north west, IN
larry890 Offline
larry890  Offline
north west, IN
I like that moroso tank, mine is quite a bit shoter. Ive been battling this problem since i put my pump on, so keep up the suggestions.
Re: Opinions for best no puke oil evac tank... [Re: larry890] #907944
01/19/11 01:47 PM
01/19/11 01:47 PM
Cab_Burge Online work
Cab_Burge  Online Work
How about installing a drain hose ffrom the catch tank back into the motor, a gravity feed design with a real light one way check valve, say three or four pounds of vacume like a PVC valve or something like that
Re: Opinions for best no puke oil evac tank... [Re: Cab_Burge] #907945
01/19/11 02:06 PM
01/19/11 02:06 PM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
I wouldn't. Then you will have vane waste and moisture going back in.
