R5/P7 boosted motor
#907902
01/18/11 08:32 AM
01/18/11 08:32 AM
Posts: 769 Europa, Estonia
Georg
Europa, Estonia
Hi guys
As I know nobody had made Dodge R5/P7 boosted motor so I start post where I and probably some other R5/P7 guys hopefully get some good answers.
1. what path take - turbocharger or procharger? 2. blown throgh carb or injection? 3. who will make and grind right cam for R5/P7 motor 4. custom pistons ofcorse...what manufacturer may be the one to choose? JE, Diamond or someone else 5. etc.
Hope we R5/P7 guys get this post well going and get some good tips and solutions
Thanks Georg
Outlaw Plymouth Valiant
R5/P7 Powered by Liuzzo Racing
COMP Performance Group dealer in Baltic
Premium Performance
Re: R5/P7 boosted motor
[Re: Georg]
#907903
01/19/11 02:32 AM
01/19/11 02:32 AM
Georg
Europa, Estonia
strange...nobody has nothing to add?
Premium Performance
[Re: Georg]
#907906
01/19/11 07:24 PM
01/19/11 07:24 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
I'm building a p7 headed motor, but not using a r5 bottom end. It's a highly modified aluminum A8 Block. 100% dry deck. All coolant will travel through hoses. The trickiest part has been modifying the valley for the cam. Other things involve moving some head bolt holes, making rocker stands, etc...The cam core is ready for heat treat, cam will be ground to my specs. This project has been in delay mode for awhile, but will continue at the end of this $now $eason. I'm putting all I've learned into this one. Looking for a solid 7 second car this time around.
[Re: Georg]
#907909
01/21/11 11:16 AM
01/21/11 11:16 AM
Posts: 452 nc
cold85
nc
Hi guys
Thanks Georg
1. Depends on what you are looking for I like turbo because I can have several size turbos for class rules 2. injection all the way 3.we have a guy that does ours and all of nascar if you have a blank send to him. 4.ross. make sure you use a custom turbo builder not just your average machine shop 5. what kind of power are you looking for?
