R5/P7 boosted motor #907902
01/18/11 08:32 AM
01/18/11 08:32 AM
Europa, Estonia
Georg Offline OP
Georg  Offline OP
Europa, Estonia
Hi guys
As I know nobody had made Dodge R5/P7 boosted motor so I start post where I and probably some other R5/P7 guys hopefully get some good answers.
1. what path take - turbocharger or procharger?
2. blown throgh carb or injection?
3. who will make and grind right cam for R5/P7 motor
4. custom pistons ofcorse...what manufacturer may be the one to choose? JE, Diamond or someone else
5. etc.
Hope we R5/P7 guys get this post well going and get some good tips and solutions
Georg
Outlaw Plymouth Valiant R5/P7 Powered by Liuzzo Racing COMP Performance Group dealer in Baltic Premium Performance
Re: R5/P7 boosted motor [Re: Georg] #907903
01/19/11 02:32 AM
01/19/11 02:32 AM
Europa, Estonia
Georg Offline OP
Georg  Offline OP
Europa, Estonia
strange...nobody has nothing to add?
Re: R5/P7 boosted motor [Re: Georg] #907904
01/19/11 02:40 AM
01/19/11 02:40 AM
BX, CT, FL.
B1KILLER Offline
B1KILLER  Offline
BX, CT, FL.
I started a post like this and got zero r3piles. I'm just going to thrown twin Borg n warners on it with a mo tec system, and run a safe turn up, them later nda future go into da internal.
Re: R5/P7 boosted motor [Re: B1KILLER] #907905
01/19/11 04:17 AM
01/19/11 04:17 AM
pacific northwest
Stroker Scamp Offline
pacific northwest
i have not seen many posts on this combo so heres a
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: R5/P7 boosted motor [Re: Georg] #907906
01/19/11 07:24 PM
01/19/11 07:24 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
I'm building a p7 headed motor, but not using a r5 bottom end. It's a highly modified aluminum A8 Block. 100% dry deck. All coolant will travel through hoses. The trickiest part has been modifying the valley for the cam. Other things involve moving some head bolt holes, making rocker stands, etc...The cam core is ready for heat treat, cam will be ground to my specs. This project has been in delay mode for awhile, but will continue at the end of this $now $eason.
I'm putting all I've learned into this one. Looking for a solid 7 second car this time around.
Re: R5/P7 boosted motor [Re: TRENDZ] #907907
01/20/11 07:08 PM
01/20/11 07:08 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Are you dropping it in another Olds or are you going to be crative and grab a flat cart from Home Depot?
- Stu Harmon
Re: R5/P7 boosted motor [Re: feets] #907908
01/20/11 07:26 PM
01/20/11 07:26 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Actually it's going into a VERY ratty '53 studebaker commander... Unless I can get away with one of those carts.
Re: R5/P7 boosted motor [Re: Georg] #907909
01/21/11 11:16 AM
01/21/11 11:16 AM
nc
cold85 Offline
cold85  Offline
nc
Hi guys
5. etc.
Georg
1. Depends on what you are looking for I like turbo because I can have several size turbos for class rules
2. injection all the way
3.we have a guy that does ours and all of nascar if you have a blank send to him.
4.ross. make sure you use a custom turbo builder not just your average machine shop
5. what kind of power are you looking for?
