Aluminum spring eye bushing #907530
01/17/11 06:28 PM
01/17/11 06:28 PM
Tallmadge, Ohio
Butch Offline OP
Butch  Offline OP
Tallmadge, Ohio
Do they actually work and are the worth the cost? $98.00 at Summit.
http://www.summitracing.com/parts/DCC-4510644/
Butch
'74 Duster 440
'04 Hemi Quad Cab Ram
'06 Pacifica
'78 MGB
Re: Aluminum spring eye bushing [Re: Butch] #907531
01/17/11 07:27 PM
01/17/11 07:27 PM
FYI, Afco makes a Nylon front spring bushing available from Speedway motors for $26.99...
http://www.speedwaymotors.com
Re: Aluminum spring eye bushing #907532
01/17/11 07:49 PM
01/17/11 07:49 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
A chunk of aluminum bar stock , a lathe and a boring afternoon ( no pun intended ) was all mine cost.
For the time and work , the price isn't terrible.........but I'd bet they aren't standing there turning cranks either.
They are as simple as they look.
Re: Aluminum spring eye bushing [Re: Butch] #907533
01/17/11 08:23 PM
01/17/11 08:23 PM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
Butch,,,,
Are the dimensions you need on that link correct for your application ?
(1.5" diam, 2" length ? )
Do you have caltrac springs,,,or MP springs ( I assume they are MP given the link you provided) ,,,send me a PM....
Doug
Re: Aluminum spring eye bushing [Re: 69CHARGERMD] #907534
01/17/11 11:37 PM
01/17/11 11:37 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I could use a pair for my SS springs...
Re: Aluminum spring eye bushing [Re: topside] #907535
01/18/11 01:26 AM
01/18/11 01:26 AM
Sask, Can.
72demon416 Offline
72demon416  Offline
Sask, Can.
So are they really of much benefit? I've had a new set sitting in a box for 6 years and didn't really know if they were worth installing or not (I can't remember why I bought them in the 1'st place...LOL)
Re: Aluminum spring eye bushing [Re: 72demon416] #907536
01/19/11 02:47 PM
01/19/11 02:47 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I have Cal-Tracs with split mono's on my Challenger & made alum bushings for both the front & rear leaf spring eyelets on my car. Sorry, no pics though.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Aluminum spring eye bushing [Re: 72demon416] #907537
01/19/11 03:09 PM
01/19/11 03:09 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Their actual benefit is probably measured a couple numbers to the right of the decimal , but they do help.
I did changes to the front suspension at the same time as I did mine , so I have no real data to support this , but it definitely makes sense on paper.
Re: Aluminum spring eye bushing [Re: tubtar] #907538
01/20/11 04:41 PM
01/20/11 04:41 PM
Tallmadge, Ohio
Butch Offline OP
Butch  Offline OP
Tallmadge, Ohio
Thanks for the replies. I'm kind of on the fence. Mancini has them for $39.00. I am looking for 60 ft improvement.
Butch
'74 Duster 440
'06 Pacifica
'78 MGB
