Critique/help with this custom stroker combination
#907381
01/17/11 05:05 PM
01/17/11 05:05 PM
Posts: 3,415 Toronto
mshred
Toronto
Hey guys,
Thinking of this custom stroker combination, tell me what you think
BPE 4.125" crank, 360 mains, uses chevy 2.00" rod journal
Inline 6 Chevy Scat H beam connecting rod, 6.00" length with the correct 2.00" big end diameter
Mopar stroker piston with a 1.46-1.465 compression height...Only piston I have found so far that is forged with a dish is the JE piston #207420 and it is quite expensive...cheapest ive found is flatlander racing for $786 for the whole set...the big stip with using the chevy 6 cyl rods is that they use a .927 piston pin, which in terms of the compression height i need, greatly limits me to just the JE stuff
So what do you guys think? Am i on the right track here? also, has anyone done a combination like this before and used a different piston/rod combo that still works with the 2.00" rod journal on the crank
Re: Critique/help with this custom stroker combination
[Re: mshred]
#907382
01/17/11 05:27 PM
01/17/11 05:27 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
With a deck height around 9.59 ...
you will need a compression height of 1.33 on your pistons.
Do the Math...
9.59- 6.20-(4.125/2)=1.325
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: 70AARcuda]
#907383
01/17/11 05:36 PM
01/17/11 05:36 PM
mshred
Toronto
Do the Math...
im using a 6" rod, not 6.125"
[Re: mshred]
#907385
01/17/11 06:00 PM
01/17/11 06:00 PM
Posts: 2,091 Delray beach, Florida
Performance Only
i agree with the above, get rid of the 6" rod for starters. we have the longer rods and matching pistons available.
machine shop owner and engine builder
[Re: mshred]
#907386
01/17/11 06:06 PM
01/17/11 06:06 PM
Posts: 9,875 Weddington, N.C.
Streetwize
Weddington, N.C.
I'd like to see you run a 6.2/6.25/6.3-ish" SBC rod, I wouldn't build-in a sub 1.5:1 rod ratio so long as there was an economical piston choice to make it work.
Also when you add those cubes you may need to go to a custom dish in order to get the cr you want.
I'd research AndyF's 427 motor, maybe you can run the same piston/rod as he did...it's in the small block tech archives.
I have a small block ford motor that is 4.04" x 4.17" stroke with a 6.123" mopar length rod....it's fine with the shorter RR....but the 351W deck is 9.5 vs 9.6 AND my motor is built to peak right at 5500 so I never take it over 6000-6200....by design....I wanted a 427FE type torque/power curve as similar to an original 65 cobra as possible.
[Re: BPE]
#907387
01/17/11 08:20 PM
01/17/11 08:20 PM
mshred
Toronto
The piston will not clear the counterweights at BDC. This is part of the reason for the 6.200" rod.
Hey Rod, thanks for that info! Im all new to this, so i was just plugging in numbers on stuff to see what I could come up with...now im starting to understand why you are looking to do an affordable combo kit for it lol
Any guess on how soon?
[Re: Streetwize]
#907389
01/17/11 08:25 PM
01/17/11 08:25 PM
mshred
Toronto
thanks for the info man! How do i calculate rod ratio? this is all new to me so im kinda figuring things out by trying to play with numbers
Also, the only reason I went to a 6" rod was because I couldnt find a piston and 6.2 or bigger rod combo that would fit in the stock deck...or maybe i wasnt calculating properly...guess i should go back at it
If anybody has done a combo like this and would care to share what they used, please share
im gonna check out andy's thread in the meantime
[Re: mshred]
#907390
01/17/11 08:37 PM
01/17/11 08:37 PM
Posts: 52,972 Romeo MI
MR_P_BODY
thanks for the info man! How do i calculate rod ratio? this is all new to me so im kinda figuring things out by trying to play with numbers Also, the only reason I went to a 6" rod was because I couldnt find a piston and 6.2 or bigger rod combo that would fit in the stock deck...or maybe i wasnt calculating properly...guess i should go back at it If anybody has done a combo like this and would care to share what they used, please share im gonna check out andy's thread in the meantime
I had Diamond change the pin height on my pistons and it was only $35 to change the height for the set when I had them made... that was just over a month ago... mine is a 416ci but with a deck of 9.53 (I believe it is... numbers are out in the shop)
[Re: MR_P_BODY]
#907391
01/17/11 08:41 PM
01/17/11 08:41 PM
mshred
Toronto
[Re: mshred]
#907392
01/17/11 08:50 PM
01/17/11 08:50 PM
MR_P_BODY
[Re: Quicktree]
#907394
01/17/11 09:15 PM
01/17/11 09:15 PM
mshred
Toronto
you would be way ahead of the game to get with a builder and have them spec out your motor. save you a lot of trouble in the long run
your probably right about saving me the trouble, but ive always been the type to try and figure things out on my own...helps me learn something and save some money in the long run (i would hope)...Im only 21, so ive got a brain ready to soak in info, and a small wallet lol
[Re: mshred]
#907395
01/17/11 09:19 PM
01/17/11 09:19 PM
Quicktree
all the more reason to get somebody who knows what they are doing. unfortunatly learning usally cost you more money.
[Re: Quicktree]
#907396
01/17/11 09:24 PM
01/17/11 09:24 PM
mshred
Toronto
well the way i see it, im half way there. Ive already chosen the crank, have a sure direction for the rods now, and just need to figure out pistons...Im still trying to decide if the extra 13 cubes over the 408 that id be gaining is even worth the extra cash..once im done pricing everything out ill make my decision. Is there anybody besides Performance Only who can set me up with something like this for a good price? (ive already pm'ed him)
Another question i have though is, am I really going to be pushing the limits of the stock block with this much stroke? I am only going with a 4.030" bore size, so im hoping ill be okay..I know the longer stroke might put more stress on the walls, but i cant see this combo making more than 515hp, 550tq at absolute most with the parts im selecting
[Re: Quicktree]
#907398
01/17/11 09:48 PM
01/17/11 09:48 PM
mshred
Toronto
the cubes will help more if you have the heads to match. if not it probably wont make much difference. as far as the blocks go it depends on what your goal is. factory sb are pretty strong imo. there are lots of good builders on here. Dan is doing the machine work on my stroker now.
who are some other builders on here that I can get in touch with for this? I know Brian at IMM is one, Competition Wedge another, but who else is there?
[Re: Quicktree]
#907400
01/17/11 11:02 PM
01/17/11 11:02 PM
mshred
Toronto
the list is endless, beat machine, Dwayne Porter(fast68plynouth),BG racing I could go n for a while good luck
LOL ill look into it then...you have a pm by the way!
anybody else done something similar to this and care to share any info/ words of wisdom. I checked out Andy's article, but there is no piston info really, and the motor isnt done anyways, so its kinda hard to get a rough hp per dollar figure without some dyno numbers
[Re: mshred]
#907402
01/18/11 07:27 AM
01/18/11 07:27 AM
Quicktree
I have to be honest with you, the 2 builders you have mentioned are more than capeable of steering you in the right direction. it seems you are searching for someone who will tell you what you want to hear. you have already purchased a kit that may or may not be what you need. at your age and experience level you will be better off trusting one of these guys. they have plenty of experience. not saying it's bad to want to do it yourself but it will save you money and grief. as far as cost goes I bet there will be little differnce between all of them on a similar build.
[Re: Quicktree]
#907404
01/18/11 11:02 AM
01/18/11 11:02 AM
mshred
Toronto
Hey guys, I appreciate the advice, really....I know that going with the bigger inches my heads would possibly be strained (im going with Brians RHS offerring) for now, but atleast I know in the future if i upgrade the heads ive got the cubes to help out, combining to make some awesome power. I havent purchased anything yet. Ive refunded my cast kit that I ordered before, and before I order anything else im just trying to figure out how much extra im looking at. Ive sent some builders a few pm's, so ill wait to see what they say. Like i said, this is more for my curiosities sake...im learning things right now that I never knew or even thought about before, and I like that. If I or a builder can come up with one of these big stroke combos that fits my budget, then ill swing for it...If not, im going to go with the trusty 408 kit lol...still more than enough cubes for a young sucker like me
[Re: mshred]
#907405
01/18/11 12:36 PM
01/18/11 12:36 PM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
I got 500.00 says your right foot is heavier than your wallet. I was the same way at your age , and I still consider it a good thing. There is a wealth of great advice here........something that wasn't readily available in my day. ( here we go .......old guy stories ) After you thank them , thank whoever thought up this crazy box full of chips and wires. But even a geezer like me can learn something and appreciate the amount of wisdom being thrown at us for free. You still have a ton of options and all of them make sense on many levels. The hard part is opening the wallet and saying " I'll take it " because now you are locked on to a given path. And here is where the benefit of someone's experience will really pay off. Find a builder you are comfortable with and trust them.
[Re: tubtar]
#907406
01/18/11 01:01 PM
01/18/11 01:01 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
Matt, There are a few reasons to not bother going beyond 4". The return on investment for the expense of custom parts and shortening service life just don't make sense to me. I decided to ask a few questions of guys I consider knowledgable and the biggest seems to be the pistons with indeterminate service life as a close second. Noise will also be a factor using a piston that short in a street car. That can be addressed with offsetting the pin but you'll need to work with the piston manufacturer to get something that addresses the issues as best as could be. IMO - Build a 4" arm, forged crank setup, with reasonable heads, and worry about "bigger" and "more" when you've already maxxed what the 4" engine can do for you. If bigger wasn't better we'd all have 318s with 360 pie tins. But there comes a time when return on investment ends up making bigger less better.
[Re: moper]
#907407
01/18/11 01:47 PM
01/18/11 01:47 PM
Triple Threat
Renton Washington
I'd stick with the 4" arm and build a 408. Between the added stroke and 4 speed you're gonna be putting a lot of stress on the block.
[Re: Streetwize]
#907409
01/18/11 03:58 PM
01/18/11 03:58 PM
Posts: 458 Michigan
BPE
I like the 4" 6.123 rod combo but I don't think I'd hesitate to run the 4.125 with the 6.2 rod and the SBC journals with a set of Brian's RHS heads. spread the lobe centers out a bit (at least 110) and try to shift some of the massive torque upstairs which will also help your power curve above the peak, the curve will be more linear (less abrupt peaky) as well which should be easier on the block overall with the heads you are planning. I would lean toward a 340 victor with some plenum work, again you don't want or need a ton of help in the upper bottom range once you give it some throttle, a good single plane will actually help make the combo more tractible/predictable off idle and in rainy conditions, especially in a nose heavy 4 speed car. A Hydraulic in the 242I/248E range or a solid in the 250I/256E range should be about right for the best balance for broad flat torque and strong top end power with an 850'ish double pumper. ~18-22 initial with another ~12-14 in the distributor with a relatively slow centrifugal advance will make it a very good steet performer without it blowing off the tires around every corner like a too quick advance will do....unless you're running fat and very sticky meats.
Well Said!
[Re: BPE]
#907410
01/18/11 05:34 PM
01/18/11 05:34 PM
Streetwize
Weddington, N.C.
Rod, Thanks buddy. I find it's easy to give good advice when you've ACTUALLY DONE IT SUCCESSFULLY before Seems some forums/threads are so full of BS these days that you can't open the page without wearing Hip Waders anymore Moparts is a lot better than most of them though I think the people who know all pretty much know eachother by now and we just ignore the posers. I look who posted before I even bother to read anymore (there's some real good ones in here .)
[Re: RyanJ]
#907413
01/18/11 08:44 PM
01/18/11 08:44 PM
mshred
Toronto
Hey everybody, thank you for the opinions and words of wisdom I have spoken with a couple of builders on here, as well as a few different piston manufacturers, and it looks like going to the 4.125" arm is just out of my price range. Only other company ive found that has a kit for it besides K1 or something from Hughes is Ohio Crank...not sure the quality of their stuff, but the price is right http://ohiocrank.com/mopar_rotate.htmlLooks like im more than likely going to be sticking with the 4" arm stuff since i havent heard anybody on here mention the Ohio Crank stuff and whether or not it worked well for them 408 cubes is already going to be a handful for me lol
[Re: mshred]
#907414
01/18/11 09:02 PM
01/18/11 09:02 PM
Streetwize
Weddington, N.C.
The forged Ohio's are pretty stout, (but check all non-premium cranks first by a competent machinist) I have one in my 414 (got as a crank/rods/block package deal I couldn't pass up) but I'd seriously consider getting a crank from one of the moparts members/sponsors on here. We all help eachother out as much as we can (I've bought parts and services from 2 in this very thread ), a lot of these guys I've known for years...even the ones I 'debate' with from time to time, I think we still respect eachother's opinions and we're all still 'buds'. A lot of these guys volunteer VAST amounts of knowledge and experience and deliver the hard core content to this site, give 'em a shot
[Re: Quicktree]
#907415
01/18/11 10:26 PM
01/18/11 10:26 PM
Posts: 2,584 sycamore,ohio
BobsProFab
sycamore,ohio
i agree with Tony, im starting to gather parts for my budget R5 421" and helps to get good advice from guys that has been there and done it.
Bob
[Re: moper]
#907419
01/20/11 07:54 PM
01/20/11 07:54 PM
mshred
Toronto
Moper, im concered with the service life you are talking about.. why is it so? Also, the piston noise you are referring to- is it more when its cold upon startup, or is it constant? I can live with noise, as long as its not damaging anything
Another question I have for you guys is, with a stock block and .030" overbore, do I have anything to worry about in terms of wall thickness or block strength? I know HP/TQ is the killer, just wondering if this different rod/stroke/piston combo is detrimental as well
Ive spoken with Rod twice now and I must say i really do trust that this stuff will work good. Since he will be offerring custom pistons, im just trying to figure out if i will be okay with 7/16 cap screw I beams or if I should step up to the H beam stuff
[Re: kielbasa]
#907421
01/20/11 08:43 PM
01/20/11 08:43 PM
Streetwize
Weddington, N.C.
mshred, I respect and appreciate you at a young age asking all of these well-thought out questions. A very wise engine builder named Joe Sherman once said "$1 in the heads is worth $3 in the shortblock." I've found this to be more true than you know, don't sweat it there's plenty of 408-416's out there that crush big blocks all day long. My build the best nicest forged 408 you can afford to build and enjoy it! Take what you learn from the experience of building it and look forward to rolling that knowledge in to the next one, pretty much what I've been doing for 30-odd years now
[Re: Streetwize]
#907422
01/20/11 11:21 PM
01/20/11 11:21 PM
Performance Only
mshred,
i agree, you have neither the cylinder head nor the block you need to take advantage of the extra cubes. in other words, what's the point? no need to get into custom pistons for a combo that is limited by the block and heads anyway. we've done plenty of both size engines as well as the 4.25 strokers, so we do have some first hand knowledge about what works best for a given overall combination. the 408/416 IMO is still one of the best street/strip combo's out there. sonic check your block. i have a std. bore 340 block that needs to sleeves just to go .030 over. don't take anything for granted.
