383 dual point #907236
01/17/11 01:04 PM
01/17/11 01:04 PM
phx, az.
J code Chargers Offline OP
phx, az.
Can a 383 dual point be used in a 440 if you swap out the shaft for a 440 distibutor shaft? Can you use a single point 440 distributor shaft for the swap?
Re: 383 dual point [Re: J code Chargers] #907237
01/17/11 02:02 PM
01/17/11 02:02 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Can a 383 dual point be used in a 440 if you swap out the shaft for a 440 distibutor shaft? YES
Not sure but I want to say NO , different manufacturer?
Re: 383 dual point [Re: JohnRR] #907238
01/17/11 06:05 PM
01/17/11 06:05 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
John,you can be sure!
Re: 383 dual point [Re: 62maxwgn] #907239
01/18/11 03:11 PM
01/18/11 03:11 PM
phx, az.
phx, az.
So what I'm reading is that: Yes a 440 distributor shaft can be used in the 383 housing but the shaft would HAVE to be from a 440 dual point because there is a difference between the Prestolite distributors and non-Prestolite units.
Do I have this correct?
Thanks guys.
Re: 383 dual point [Re: J code Chargers] #907240
01/18/11 03:38 PM
01/18/11 03:38 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Yes you do.
Re: 383 dual point [Re: 62maxwgn] #907241
01/18/11 08:56 PM
01/18/11 08:56 PM
phx, az.
phx, az.
Thank you. That's what I needed to know.
