Re: Junking a 71 steel crank 318
[Re: QuickBpBp]
#907217
01/18/11 11:18 PM
01/18/11 11:18 PM
Posts: 8,936 Holly/MI
Dean_Kuzluzski
Holly/MI
I was looking for an inexpensive 9:1 318 piston a few weeks ago. Besides what KB has to offer there's not much on the low budget end. And the KB's aren't that cheap. Hence, the stroker crank popularity. Or what I call, the "might as well syndrome".
I still wouldn't trash a good forged crank (cast, yes). Someone will want it.
[Re: cudaman1969]
#907221
01/19/11 11:22 PM
01/19/11 11:22 PM
Posts: 159 Woodward, PA
75DART440
Woodward, PA
And you might check the rods. Seems the factory musta had some leftover 496 (340) rods. I have found them in a few untouched (date coded bearings, factory head gaskets) 70 thru 72 318s. Also, the 71 318s often used a Rochester 2GV carb. This was a one year only part. Might be somebody hunting that. And the intake if it's a single plane. The dirt track guys who are not allowed to run 4 barrels like them. Make me a deal on the whole thing.
Buy a Hybrid!! I need your gas!!! Currently spending $1,000 a month to feed the Hemis!!
Looking for that elusive CHEAP 71-72 Plymouth B-body 2 door OR 71-72 Coronet 4 door!!!
