Junking a 71 steel crank 318 #907207
01/17/11 11:45 AM
01/17/11 11:45 AM
SE PA.
Q
QuickBpBp Offline OP
Q
SE PA.
Is the crank worth keeping,how about any a/c pulleys....All my cars are BB so I have no use for it and I am getting rid of stuff that beens laying around,it's still together and I was gonna keep the steering pump and crank pulley. It's from a 71 satellite....So should I bother with the crank or junk it...
Re: Junking a 71 steel crank 318 [Re: QuickBpBp] #907208
01/17/11 11:49 AM
01/17/11 11:49 AM
Carson City, NV
babarracuda Offline
babarracuda  Offline
Carson City, NV
I used a 318 steel crank in a 340. If you save it, save the harmonic balancer since someome upgrading froma cast crank will need a steel crank balancer
Re: Junking a 71 steel crank 318 [Re: QuickBpBp] #907209
01/17/11 01:02 PM
01/17/11 01:02 PM
NY NY
3
340duster340 Offline
NY NY
its a good crank, but seems like most are opting for stroker cranks driving the price of oem steel cranks down.
problem is with most parts that size is you'll wind up shipping it and if that is a hastle for you, then just junk it. not worth the time IMO for the $50 you'll get for it.
they steel crank came in all 273's, apparently some 318's and pre-73 340's. so its not like they are super rare.
Re: Junking a 71 steel crank 318 [Re: 340duster340] #907210
01/17/11 07:33 PM
01/17/11 07:33 PM
SE PA.
Q
Q
SE PA.
Thats what I was thinking as far people using after market cranks....Also there are so many since they are easily found. I'll junk the whole thing. The funny thing will be as soon as I scrap it someone will need it.....
Re: Junking a 71 steel crank 318 [Re: QuickBpBp] #907211
01/18/11 07:18 AM
01/18/11 07:18 AM
BDW Offline
BDW  Offline
Put it on Craigslist, if it doesn't sell, you can junk it then.
Costs you nothing but a little extra time. There's always someone looking for these, just a matter of timing.
Re: Junking a 71 steel crank 318 [Re: BDW] #907212
01/18/11 02:35 PM
01/18/11 02:35 PM
Cruising!
Q
QuickDodge Offline
QuickDodge  Offline
Q
Cruising!
Rather than focus on the crank, just sell the whole engine with the crank in it. (for a few more dollars) Less hassle for you and it could help someone else out.
Re: Junking a 71 steel crank 318 [Re: QuickDodge] #907213
01/18/11 02:47 PM
01/18/11 02:47 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
I had a 68 vintage 318 that was given to me.
After I got tired of it setting on the garage floor I sent out an email to all the Mopar guys I knew stating "Free 318".
One of the guys came picked it up and gave me $10 for it.
I told him that he was the only guy that would pay for something that was offered free. He's a strange character.
Re: Junking a 71 steel crank 318 [Re: SNK-EYZ] #907214
01/18/11 09:27 PM
01/18/11 09:27 PM
Carson City, NV
babarracuda Offline
babarracuda  Offline
Carson City, NV
The early 273's had a smaller hole for the torque converter. If it won't take the later torque converter, it's worthless. In 93 I had a machine shop make the hole big enough for a late torque converter. I was a pain and expensive.
Re: Junking a 71 steel crank 318 [Re: babarracuda] #907215
01/18/11 09:38 PM
01/18/11 09:38 PM
Wichita, KS
tmef Offline
tmef  Offline
Wichita, KS
I would keep the crank with the balancer and the oil pan. Ya just never know. If you were closer I would take that crank off your hands.
Re: Junking a 71 steel crank 318 [Re: tmef] #907216
01/18/11 09:41 PM
01/18/11 09:41 PM
SE PA.
Q
Q
SE PA.
Sounds like I'll pull the crank-out and take it to Carlisle with the balancer. If it doesn't sell there THEN it can become a 'yota....
Re: Junking a 71 steel crank 318 [Re: QuickBpBp] #907217
01/18/11 11:18 PM
01/18/11 11:18 PM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
I was looking for an inexpensive 9:1 318 piston a few weeks ago. Besides what KB has to offer there's not much on the low budget end. And the KB's aren't that cheap. Hence, the stroker crank popularity. Or what I call, the "might as well syndrome".
I still wouldn't trash a good forged crank (cast, yes). Someone will want it.
Re: Junking a 71 steel crank 318 [Re: Dean_Kuzluzski] #907218
01/19/11 09:57 PM
01/19/11 09:57 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I think that's a cast crank, only 340s had steel after 67 look for the parting line on the throws sharp edge cast flattened out steel
Re: Junking a 71 steel crank 318 [Re: cudaman1969] #907219
01/19/11 11:16 PM
01/19/11 11:16 PM
Saskatchewan Canada
FrozenDuster Offline
Saskatchewan Canada
Didn't early (pre73) 318's have floating piston pins as well?
Re: Junking a 71 steel crank 318 [Re: FrozenDuster] #907220
01/19/11 11:22 PM
01/19/11 11:22 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
318 polys 273 till 66
Re: Junking a 71 steel crank 318 [Re: cudaman1969] #907221
01/19/11 11:22 PM
01/19/11 11:22 PM
Woodward, PA
75DART440 Offline
75DART440  Offline
Woodward, PA
And you might check the rods. Seems the factory musta had some leftover 496 (340) rods. I have found them in a few untouched (date coded bearings, factory head gaskets) 70 thru 72 318s. Also, the 71 318s often used a Rochester 2GV carb. This was a one year only part. Might be somebody hunting that. And the intake if it's a single plane. The dirt track guys who are not allowed to run 4 barrels like them. Make me a deal on the whole thing.
Buy a Hybrid!! I need your gas!!! Currently spending $1,000 a month to feed the Hemis!! Looking for that elusive CHEAP 71-72 Plymouth B-body 2 door OR 71-72 Coronet 4 door!!!
Re: Junking a 71 steel crank 318 [Re: 75DART440] #907222
01/20/11 05:22 AM
01/20/11 05:22 AM
SE PA.
Q
Q
SE PA.
Funny the first thing when I pulled it that was the first thing sold off it many years ago was the intake and carb,then the exhaust manifolds and motor mounts. It's been sitting under an Overhang of a barn covered for 12 years or so. I don't know if it will even spin over it ran when removed....Looks like your too far away to do a deal...
