What year did dodge truck trans get better #907119
01/17/11 10:58 AM
01/17/11 10:58 AM
Cincinnati, OH
6T6Cuda Offline OP
6T6Cuda  Offline OP
Cincinnati, OH
I know they had a lot of trouble with the dodge truck trans (overdrive). I am looking to buy a truck what year did they get better - if ever?
I am mostly looking at stuff before 2000
Re: What year did dodge truck trans get better [Re: 6T6Cuda] #907120
01/17/11 11:12 AM
01/17/11 11:12 AM
ill
dennismopar73 Offline
ill
man i hear this stuff all the time
i didnt know they built any thing bad or worse than any
other car maker
im going to say this again,,
they will all go bad if you dont care for them,
guys will run 150.000 miles never change fluid never check fluid,
couldnt tell you where the stick is to check it,,
we change are oil every 3-5000 miles never change trans fluid ,
life of the car,,
its like we got automatical stupid here,,
then after 150000 miles we have trans trouble,, MY GOD WHAT WAS MOPAR THINKING WITH THAT TRANSMISSION!!!!
oooo well the insanity will never stop!!
we really have come a long way tho,,
we used to get rid of cars that had over
100000 miles to ,,
now we are keeping cars till 200000 or more
ive got a 95 neon 300000 on it no trans trouble,
got 02 durango 160000 on it no trouble,
got 96 caravan 200000 no prob,
99 1/2 318 120000 no prob,
94 shadow 1350000 no prob
own a 99 chevey cavalier makes me walk
all the time
Re: What year did dodge truck trans get better [Re: dennismopar73] #907121
01/17/11 11:34 AM
01/17/11 11:34 AM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
I hear ya............
lots of folks have the "ain't broke, don't fix/touch it" mentality with the auto trans.
Little do they realize the filter will only flow so much as it clogs with clutch/band particles. And then the heat and lack of lubrication kills it.
I do mine at 100k or when it starts to show some brown tint.
Got 3 vehicles, all with over 180k+ miles.
Re: What year did dodge truck trans get better [Re: 6T6Cuda] #907122
01/17/11 11:35 AM
01/17/11 11:35 AM
Pittsfield, Mass.
Russ_Davis Offline
Russ_Davis  Offline
Pittsfield, Mass.
Owners manual says change fluids..Change fluids. 180,000 on my 99 Dakota shifts great and still burns the tires off.
Re: What year did dodge truck trans get better [Re: Russ_Davis] #907123
01/17/11 11:41 AM
01/17/11 11:41 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I had the tranny let go in my 99 1500 4wd,......changed fluids, still puked,....the 94, same thing....basic problem with both was the torgue converter broke up and loaded up the tranny with ground up crap
Re: What year did dodge truck trans get better [Re: DAYCLONA] #907124
01/17/11 01:07 PM
01/17/11 01:07 PM
ill
ill
i guess with a 4 wd you never pulled nothin with it ?
never got stuck?
never did nothing to warrent tranny trouble ?
there is always' something' that someone never
wants to say happen ,,happened!
anything can go bad, by the nature,
but to put the whole year ./ vehicle
in the trash is beyond realm
of reality and belief
Re: What year did dodge truck trans get better [Re: dennismopar73] #907125
01/17/11 01:23 PM
01/17/11 01:23 PM
Covington Georgia
RV2 Offline
RV2  Offline
Covington Georgia
I had a 98 5.9 ram, never had a problem with that truck then I purchased a 05 cummins 2500 the best truck Ive ever owned! pulls like a freight train.
Re: What year did dodge truck trans get better [Re: RV2] #907126
01/17/11 02:53 PM
01/17/11 02:53 PM
Rancho Cucamonga,Ca
3
392charger Offline
392charger  Offline
Rancho Cucamonga,Ca
My 2002 Ram 1500 with 360/auto has 278k on it and never had a lick of tranny trouble. I used to hear all the time that up through '02 the dodge transmissions were junk. I beg to differ. I do have the trans flushed about every 40k though. I'm a firm believer that's what keeps it alive. Great truck!!
Re: What year did dodge truck trans get better [Re: 392charger] #907127
01/17/11 03:59 PM
01/17/11 03:59 PM
North East Missouri
E
express Offline
express  Offline
E
North East Missouri
My 95 was rebuilt under warranty, my 01 was in for trans work too under warrenty. Just traded it off at 70,000 miles & trans was not right. You has to put it in neutral to circulate, if it had been sitting for a few days or it would not go.
Have a 07 now, we will see how it is.
cny25421@centurytel.net 70 Duster Turbo Charged 79 Lil Red Express Bonded Locksmith
Re: What year did dodge truck trans get better [Re: express] #907128
01/17/11 04:12 PM
01/17/11 04:12 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
That is normal for Mopars. It has always taken a few seconds for the trans to go into gear from park.
Re: What year did dodge truck trans get better [Re: stumpy] #907129
01/17/11 05:17 PM
01/17/11 05:17 PM
North East Missouri
E
express Offline
express  Offline
E
North East Missouri
I know, but this was more than a few seconds!
Re: What year did dodge truck trans get better [Re: 6T6Cuda] #907130
01/17/11 05:52 PM
01/17/11 05:52 PM
Irving, TX
feets Online tonguue
Senior Management
feets  Online Tonguue
Senior Management
Irving, TX
Pulling hard with the lock up converters would lead to converter clutch failure. That sent debris through the system and OD would fail.
I'm not sure if the problem would go away with regular servicing or if the converter clutches were simply too weak for heavy duty use.
- Stu Harmon
Re: What year did dodge truck trans get better [Re: feets] #907131
01/17/11 06:38 PM
01/17/11 06:38 PM
indiana
generallee6901 Offline
indiana
I had a 2001 that as soon as it hit 60,000 miles it started giving me problems.Had to replace all 4 switches on the valve body and at about 70,000 had to replace the torque converter.Only ever pulled a trailer once with it.Never used overdrive unless i was at 55 or above either.But i know other people with over 100,000 miles and no problems what so ever.
Re: What year did dodge truck trans get better [Re: generallee6901] #907132
01/17/11 06:46 PM
01/17/11 06:46 PM
GA
Boosted Offline
Boosted  Offline
GA
For a stock truck they where all ok.. Any HP and the best one would be the 6 speed auto. Those came out what in 06?
2011 RAM3500
1967 Fastback Barracuda with some go fast goodies.
Re: What year did dodge truck trans get better [Re: Boosted] #907133
01/17/11 07:17 PM
01/17/11 07:17 PM
Covington Georgia
RV2 Offline
RV2  Offline
Covington Georgia
My 05 has the old trans like a 727( I dont know what the new name is for it)and I pull a 24' enclosed with a B body in it and no problems.
It has 100k on it now.
Re: What year did dodge truck trans get better [Re: RV2] #907134
01/17/11 07:47 PM
01/17/11 07:47 PM
chatham, Ilinois
fox Offline
super street
fox  Offline
super street
chatham, Ilinois
I too find it hard to believe dodge gets such a rap for these trans.
YES they can do better and lost a lot of customers because of some failures, but in the early 80 chevy had the 700r4 and a dealer showed me a factory letter that stated they believed close to 100% failed before 50,000!!!!!! Then the chevy guys make such a deal about the dodge auto when maybe 15% have issues!!!
A shift kit will double the life of any dodge auto, in my opinion.
Re: What year did dodge truck trans get better [Re: fox] #907135
01/17/11 08:10 PM
01/17/11 08:10 PM
Amherst,NY
challengermike Offline
Amherst,NY
Any trans can have problems.Ive seen them go at 30,000 or last over 200,000.Doesnt matter what make or trans it is.
Re: What year did dodge truck trans get better [Re: challengermike] #907136
01/17/11 09:33 PM
01/17/11 09:33 PM
Gig Harbor,WA
Commando66 Offline
Commando66  Offline
Gig Harbor,WA
My 95 Ram had 300K on the stock trans when I sold it. Great truck.
Re: What year did dodge truck trans get better [Re: 392charger] #907137
01/17/11 09:50 PM
01/17/11 09:50 PM
Fitchburg, WI
BIGHOOK Offline
BIGHOOK  Offline
Fitchburg, WI
I agree. Lack of tranny maintenance is the core result of most tranny failures. That's not to say that there could be the occasional runt in the bunch from the factory. I had the A727 Loadflite non lock-up in my 87 W150. I pushed, pulled, hauled and climbed with that one. Sold it with 213k on the original tranny (and regular fluid/filter changes) and it still shifted like new.
Re: What year did dodge truck trans get better [Re: BIGHOOK] #907138
01/17/11 10:48 PM
01/17/11 10:48 PM
Cookeville
Chilort Offline
Will Work For Mopars
Chilort  Offline
Cookeville
The trans options got better? The poorly functioning overdrive on the auto and undersized NV3500 were two of he worst things Dodge did to handicap themselves with trucks. They had the look at that time for sure and a lot of folks jumped over only to be greeted with failure.
After my father's '94 and my '99 my plan was to never buy another new Dodge truck ever again.
A friend has a a Hemi R/T in the newest body style and it might make me change my mind. Of course, he got this after his 6.7L Cummins was traded out through the Lemon Laws.
